Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Get table data from SWT app to EXCEL
Get table data from SWT app to EXCEL [message #466745] Tue, 17 January 2006 05:51 Go to next message
Originally posted by: tyler.scott.gmx.com
Hi all,
I wrote an application in SWT that displays a big amound of data within a
table. Now I want that this table data can be used in Microsoft Excel for
further analysis. In the current version of the tool you can export the SWT
table in an CSV file and then open this file in Excel. This is a little bit
circuitous and I want to estabilish a direct connection between SWT and
Excel via OLE or something. So I push a Button in the SWT app, Excel opens
and the data appears in a new spreadsheet. This would be perfect!
Does anybody know how this could be done?
thx in advance,
volker
Re: Get table data from SWT app to EXCEL [message #466747 is a reply to message #466745] Tue, 17 January 2006 06:03 Go to previous messageGo to next message
Use POI.
SY, Konstantin.
Advanced Eclipse SWT Designer (http://www.swt-designer.com)
Re: Get table data from SWT app to EXCEL [message #466791 is a reply to message #466747] Tue, 17 January 2006 14:06 Go to previous message
>> SWT table in an CSV file and then open this file in Excel. This is a
>> little bit circuitous and I want to estabilish a direct connection
>> between SWT and Excel via OLE or something. So I push a Button in the SWT
>> app, Excel opens and the data appears in a new spreadsheet. This would be
>> perfect!
> Use POI.
you can open external Excel with Program or internal with Ole (or
wit OfficeBean in OpenOffice - this wokr on linux, too)
for making excel output you can use POI (like Konstantin's advice) or
jexcelapi - jasperreport use both
Previous Topic:Java SWT Minimized-Shell RAM Usage
Next Topic:How to set gradient color from left-top to right-bottom??
Current Time: Sun Aug 10 02:01:17 EDT 2025
Powered by FUDForum. Page generated in 0.28064 seconds
