Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Opening a GEF editor crashes Eclipse/JVM with cairo error
Opening a GEF editor crashes Eclipse/JVM with cairo error [message #466539] |
Wed, 11 January 2006 09:37 |
Thomas Maier Messages: 117 Registered: July 2009 |
--------------030905070102090108040303
Content-Type: text/plain; charset=UTF-8
I first posted to e.t.gef but was pointed here. I found two postings
here that have to do with cairo problems but I think this is yet another
problem.
The following does not happen when I comment out this one line in my code:
// connectionLayer.setAntialias(SWT.ON);
So this is a workaround and I can continue working.
When I try to open a GEF editor (no matter whether it is one written by
me or e.g. the logic example), Eclipse crashes. The last output line I
see on the screen seems important here:
java: cairo-surface.c:273: cairo_surface_reference: Assertion
`surface->ref_count > 0' failed.
Eclipse display a last dialog:
JVM terminated. Exit code=1
/usr/bin/java
-Xmx768m
-jar /home/thm/Apps/Eclipse-3.1.1/./startup.jar
-os linux
-ws gtk
-arch x86
-launcher /home/thm/Apps/Eclipse-3.1.1/./eclipse
-name Eclipse
-showsplash 600
-exitdata 498013
-data /home/thm/Apps/Workspace
-debug
-consolelog
-vm /usr/bin/java
-vmargs
-Xmx768m
I start Eclipse like this and get the following output:
$ export MOZILLA_FIVE_HOME=/usr/lib/mozilla
$ cd ~/Apps/Eclipse-3.1.1
$ ./eclipse -data ~/Apps/Workspace -debug -consolelog -vmargs -Xmx768m
Start VM: /usr/bin/java
-Xmx768m
-os linux
-ws gtk
-arch x86
-name Eclipse
-showsplash 600
-exitdata 498013
-debug
-consolelog
-vm /usr/bin/java
-vmargs
-Xmx768m
Install location:
file:/home/thm/Apps/Eclipse-3.1.1/
Configuration file:
file:/home/thm/Apps/Eclipse-3.1.1/configuration/config.ini loaded
Configuration location:
Framework located:
file:/home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.osgi_3 .1.1.jar
Framework classpath:
Splash location:
/home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.platform_3. 1.1/splash.bmp
runCommand:
</home/thm/Apps/Eclipse-3.1.1/./eclipse><-name><Eclipse><-showsplash ><600>< /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.platform_3. 1.1/splash.bmp >
Debug options:
file:/home/thm/Apps/Eclipse-3.1.1/.options not found
Time to load bundles: 41
Starting application: 5745
System information:
Debian Sid, Linux 2.6.14
libcairo2 Debian package 1.0.2-3
I also compiled the cairo releases
http://cairographics.org/releases/cairo-1.0.2.tar.gz
and
http://cairographics.org/releases/cairo-1.0.0.tar.gz
myself (with gcc-Version 4.0.3 20060104 (prerelease) (Debian 4.0.2-6))
but I got the same error. A fresh Eclipse+GEF install (started
only with "eclipse -data /path/to/workspace") gives the same error.
I attached one of the JVM dumps.
Thanks and regards, Thomas.
Content-Type: text/x-log;
name="hs_err_pid22508.log"
Content-Disposition: inline;
filename="hs_err_pid22508.log"
# An unexpected error has been detected by HotSpot Virtual Machine:
# SIGSEGV (0xb) at pc=0xb781ecdc, pid=22508, tid=3085048128
# Java VM: Java HotSpot(TM) Client VM (1.5.0_05-b05 mixed mode, sharing)
# Problematic frame:
# V [libjvm.so+0x15fcdc]
--------------- T H R E A D ---------------
Current thread (0x0805bd48): JavaThread "main" [_thread_in_vm, id=22508]
siginfo:si_signo=11, si_errno=0, si_code=1, si_addr=0x00000005
Registers:
EAX=0x00000001, EBX=0xb7a087a8, ECX=0x0805c050, EDX=0xbfe9a1e8
ESP=0xbfe9a118, EBP=0xbfe9a1b0, ESI=0x0805bd48, EDI=0x00000000
EIP=0xb781ecdc, CR2=0x00000005, EFLAGS=0x00210246
Top of Stack: (sp=0xbfe9a118)
0xbfe9a118: b26e6448 b26ecc3e bfe9a144 bfe9a144
0xbfe9a128: b77b3045 bfe9a158 b26ecc3e 00000000
0xbfe9a138: 0805bdec b7a087a8 b26ecc3e bfe9a174
0xbfe9a148: 0805d4e0 0805d4dc 0805d4d8 0805d4d4
0xbfe9a158: bfe9a1c4 b26eaace bfe9a1e8 40240000
0xbfe9a168: bfe9a1c4 b26eaace bfe9a1e8 bfe9a1a4
0xbfe9a178: 0805bd48 b26ecc3e 0805bd48 bfe9a1a4
0xbfe9a188: 0805bd48 0805bd48 b26e69a4 91247918
Instructions: (pc=0xb781ecdc)
0xb781eccc: 00 00 00 00 8b 45 a4 c7 45 84 00 00 00 00 8b 00
0xb781ecdc: 8b 70 04 85 f6 0f 84 3b 03 00 00 8b 45 08 8b 90
Stack: [0xbfca0000,0xbfea0000), sp=0xbfe9a118, free space=2024k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
j org.eclipse.swt.internal.cairo.Cairo.cairo_create()I+0
j org.eclipse.swt.graphics.GC.initCairo()V+27
j org.eclipse.swt.graphics.GC.setAntialias(I)V+63
j org.eclipse.draw2d.SWTGraphics.reconcileHints(II)V+197
j org.eclipse.draw2d.SWTGraphics.checkGC()V+87
j org.eclipse.draw2d.SWTGraphics.checkPaint()V+1
j org.eclipse.draw2d.SWTGraphics.drawPolyline([I)V+1
j org.eclipse.draw2d.SWTGraphics.drawPolyline(Lorg/eclipse/dra w2d/geometry/PointList;)V+5
j org.eclipse.draw2d.Polyline.outlineShape(Lorg/eclipse/draw2d /Graphics;)V+5
j org.eclipse.draw2d.Shape.paintFigure(Lorg/eclipse/draw2d/Gra phics;)V+156
j org.eclipse.draw2d.Figure.paint(Lorg/eclipse/draw2d/Graphics ;)V+51
j org.eclipse.draw2d.Figure.paintChildren(Lorg/eclipse/draw2d/ Graphics;)V+60
j org.eclipse.draw2d.Figure.paintClientArea(Lorg/eclipse/draw2 d/Graphics;)V+120
j org.eclipse.draw2d.Figure.paint(Lorg/eclipse/draw2d/Graphics ;)V+60
j org.eclipse.draw2d.ConnectionLayer.paint(Lorg/eclipse/draw2d /Graphics;)V+18
j org.eclipse.draw2d.ScalableFreeformLayeredPane.paintClientAr ea(Lorg/eclipse/draw2d/Graphics;)V+24
j org.eclipse.draw2d.Figure.paintClientArea(Lorg/eclipse/draw2 d/Graphics;)V+100
j org.eclipse.draw2d.Viewport.paintClientArea(Lorg/eclipse/dra w2d/Graphics;)V+32
j org.eclipse.draw2d.DeferredUpdateManager.repairDamage()V+222
j org.eclipse.draw2d.DeferredUpdateManager.performUpdate()V+30
j org.eclipse.draw2d.LightweightSystem.controlResized()V+45
j org.eclipse.draw2d.LightweightSystem$1.controlResized(Lorg/e clipse/swt/events/ControlEvent;)V+4
j org.eclipse.swt.widgets.TypedListener.handleEvent(Lorg/eclip se/swt/widgets/Event;)V+539
J org.eclipse.swt.widgets.EventTable.sendEvent(Lorg/eclipse/sw t/widgets/Event;)V
v ~RuntimeStub::alignment_frame_return Runtime1 stub
j org.eclipse.swt.widgets.Widget.sendEvent(Lorg/eclipse/swt/wi dgets/Event;)V+25
j org.eclipse.swt.widgets.Widget.sendEvent(ILorg/eclipse/swt/w idgets/Event;Z)V+73
j org.eclipse.swt.widgets.Widget.sendEvent(I)V+4
j org.eclipse.swt.widgets.Control.setBounds(IIIIZZ)I+491
j org.eclipse.swt.widgets.Composite.setBounds(IIIIZZ)I+10
j org.eclipse.swt.widgets.Canvas.setBounds(IIIIZZ)I+46
j org.eclipse.swt.widgets.Control.setBounds(IIII)V+20
j org.eclipse.gef.ui.parts.Splitter.layout(Z)V+539
j org.eclipse.gef.ui.parts.Splitter$1.handleEvent(Lorg/eclipse /swt/widgets/Event;)V+5
j org.eclipse.swt.layout.FillLayout.layout(Lorg/eclipse/swt/wi dgets/Composite;Z)V+172
j org.eclipse.swt.widgets.Composite.updateLayout(Z)V+54
j org.eclipse.swt.widgets.Composite.setBounds(IIIIZZ)I+39
j org.eclipse.swt.widgets.Control.setBounds(Lorg/eclipse/swt/g raphics/Rectangle;)V+40
j org.eclipse.ui.internal.LayoutPart.setBounds(Lorg/eclipse/sw t/graphics/Rectangle;)V+14
j org.eclipse.ui.internal.presentations.PresentablePart.setBou nds(Lorg/eclipse/swt/graphics/Rectangle;)V+18
j org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.layoutContent()V+33
j org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.layout(Z)V+9
j org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(Lorg/eclipse/ui/presentations/IPresentablePart;) V+81
j org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(Lorg/eclipse/ui/presentations/IPresentablePart;)V+ 5
j org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(Lorg/eclipse/ui/presentations/IPresentable Part;)V+10
j org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on()V+142
j org.eclipse.ui.internal.PartStack.setSelection(Lorg/eclipse/ ui/internal/LayoutPart;)V+15
j org.eclipse.ui.internal.PartStack.showPart(Lorg/eclipse/ui/i nternal/LayoutPart;Ljava/lang/Object;)V+44
j org.eclipse.ui.internal.PartStack.add(Lorg/eclipse/ui/intern al/LayoutPart;)V+14
j org.eclipse.ui.internal.EditorStack.add(Lorg/eclipse/ui/inte rnal/LayoutPart;)V+2
j org.eclipse.ui.internal.EditorSashContainer.addEditor(Lorg/e clipse/ui/internal/EditorPane;Lorg/eclipse/ui/internal/Edito rStack;)V+2
j org.eclipse.ui.internal.EditorAreaHelper.addToLayout(Lorg/ec lipse/ui/internal/EditorPane;Lorg/eclipse/ui/internal/Editor Stack;)V+11
j org.eclipse.ui.internal.EditorAreaHelper.addEditor(Lorg/ecli pse/ui/internal/EditorReference;Ljava/lang/String;)V+81
j org.eclipse.ui.internal.EditorManager.createEditorTab(Lorg/e clipse/ui/internal/EditorReference;Ljava/lang/String;)V+6
j org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(Lorg/eclipse/ui/internal/registry/EditorDescriptor;Lorg/e clipse/ui/IEditorInput;)Lorg/eclipse/ui/IEditorReference;+16 8
j org.eclipse.ui.internal.EditorManager.openEditor(Ljava/lang/ String;Lorg/eclipse/ui/IEditorInput;Z)Lorg/eclipse/ui/IEdito rReference;+59
j org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( Lorg/eclipse/ui/IEditorInput;Ljava/lang/String;ZI)Lorg/eclip se/ui/IEditorPart;+203
j org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Lorg/ec lipse/ui/IEditorInput;Ljava/lang/String;ZI)Lorg/eclipse/ui/I EditorPart;+25
j org.eclipse.ui.internal.WorkbenchPage.access$9(Lorg/eclipse/ ui/internal/WorkbenchPage;Lorg/eclipse/ui/IEditorInput;Ljava /lang/String;ZI)Lorg/eclipse/ui/IEditorPart;+6
j org.eclipse.ui.internal.WorkbenchPage$9.run()V+25
j org.eclipse.swt.custom.BusyIndicator.showWhile(Lorg/eclipse/ swt/widgets/Display;Ljava/lang/Runnable;)V+116
j org.eclipse.ui.internal.WorkbenchPage.openEditor(Lorg/eclips e/ui/IEditorInput;Ljava/lang/String;ZI)Lorg/eclipse/ui/IEdit orPart;+57
j org.eclipse.ui.internal.WorkbenchPage.openEditor(Lorg/eclips e/ui/IEditorInput;Ljava/lang/String;Z)Lorg/eclipse/ui/IEdito rPart;+5
j org.eclipse.ui.ide.IDE.openEditor(Lorg/eclipse/ui/IWorkbench Page;Lorg/eclipse/core/resources/IFile;ZZ)Lorg/eclipse/ui/IE ditorPart;+36
j org.eclipse.ui.ide.IDE.openEditor(Lorg/eclipse/ui/IWorkbench Page;Lorg/eclipse/core/resources/IFile;Z)Lorg/eclipse/ui/IEd itorPart;+4
j org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(Lorg/eclipse/core/resources/IFile;Z)Lorg/eclipse/ui/IE ditorPart;+15
j org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(Ljava/lang/Object;Z)Lorg/eclipse/ui/IEditorPart;+12
j org.eclipse.jdt.internal.ui.actions.OpenActionUtil.open(Ljav a/lang/Object;Z)V+2
j org.eclipse.jdt.ui.actions.OpenAction.run([Ljava/lang/Object ;)V+39
j org.eclipse.jdt.ui.actions.OpenAction.run(Lorg/eclipse/jface /viewers/IStructuredSelection;)V+16
j org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(Lorg/eclipse/jface/viewers/ISelection;)V+12
j org.eclipse.jdt.ui.actions.SelectionDispatchAction.run()V+5
j org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(Lorg/eclipse/jface/viewers/OpenEvent;)V+22
....<more frames>...
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 4.open(Lorg/eclipse/jface/viewers/OpenEvent;)V+8
j org.eclipse.jface.viewers.StructuredViewer$2.run()V+8
j org.eclipse.core.internal.runtime.InternalPlatform.run(Lorg/ eclipse/core/runtime/ISafeRunnable;)V+5
j org.eclipse.core.runtime.Platform.run(Lorg/eclipse/core/runt ime/ISafeRunnable;)V+4
j org.eclipse.ui.internal.JFaceUtil$1.run(Lorg/eclipse/core/ru ntime/ISafeRunnable;)V+1
j org.eclipse.jface.util.SafeRunnable.run(Lorg/eclipse/core/ru ntime/ISafeRunnable;)V+4
j org.eclipse.jface.viewers.StructuredViewer.fireOpen(Lorg/ecl ipse/jface/viewers/OpenEvent;)V+32
j org.eclipse.jface.viewers.StructuredViewer.handleOpen(Lorg/e clipse/swt/events/SelectionEvent;)V+31
j org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Lorg /eclipse/swt/events/SelectionEvent;)V+5
j org.eclipse.jface.util.OpenStrategy.fireOpenEvent(Lorg/eclip se/swt/events/SelectionEvent;)V+38
j org.eclipse.jface.util.OpenStrategy.access$2(Lorg/eclipse/jf ace/util/OpenStrategy;Lorg/eclipse/swt/events/SelectionEvent ;)V+2
j org.eclipse.jface.util.OpenStrategy$1.handleEvent(Lorg/eclip se/swt/widgets/Event;)V+37
j org.eclipse.swt.widgets.Display.runDeferredEvents()Z+84
j org.eclipse.swt.widgets.Display.readAndDispatch()Z+22
j org.eclipse.ui.internal.Workbench.runEventLoop(Lorg/eclipse/ jface/window/Window$IExceptionHandler;Lorg/eclipse/swt/widge ts/Display;)V+9
j org.eclipse.ui.internal.Workbench.runUI()I+108
j org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Lorg /eclipse/swt/widgets/Display;Lorg/eclipse/ui/application/Wor kbenchAdvisor;)I+11
j org.eclipse.ui.PlatformUI.createAndRunWorkbench(Lorg/eclipse /swt/widgets/Display;Lorg/eclipse/ui/application/WorkbenchAd visor;)I+2
j org.eclipse.ui.internal.ide.IDEApplication.run(Ljava/lang/Ob ject;)Ljava/lang/Object;+98
j org.eclipse.core.internal.runtime.PlatformActivator$1.run(Lj ava/lang/Object;)Ljava/lang/Object;+257
j org.eclipse.core.runtime.adaptor.EclipseStarter.run(Ljava/la ng/Object;)Ljava/lang/Object;+170
j org.eclipse.core.runtime.adaptor.EclipseStarter.run([Ljava/l ang/String;Ljava/lang/Runnable;)Ljava/lang/Object;+57
v ~StubRoutines::call_stub
j sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/refl ect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/ Object;+0
j sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Objec t;[Ljava/lang/Object;)Ljava/lang/Object;+87
j sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/O bject;[Ljava/lang/Object;)Ljava/lang/Object;+6
j java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lan g/Object;)Ljava/lang/Object;+111
j org.eclipse.core.launcher.Main.invokeFramework([Ljava/lang/S tring;[Ljava/net/URL;)V+181
j org.eclipse.core.launcher.Main.basicRun([Ljava/lang/String;) V+107
j org.eclipse.core.launcher.Main.run([Ljava/lang/String;)I+4
j org.eclipse.core.launcher.Main.main([Ljava/lang/String;)V+10
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x09c58d10 JavaThread "Worker-2" daemon [_thread_blocked, id=22530]
0x09bdc0b8 JavaThread "Java indexing" daemon [_thread_blocked, id=22529]
0x09200c48 JavaThread "Worker-1" daemon [_thread_blocked, id=22528]
0x091ae960 JavaThread "Worker-0" daemon [_thread_blocked, id=22527]
0x083ae890 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=22524]
0x083a4c70 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=22523]
0x080a3398 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=22518]
0x080a1e48 JavaThread "CompilerThread0" daemon [_thread_blocked, id=22517]
0x080a0f50 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=22516]
0x0809a310 JavaThread "Finalizer" daemon [_thread_blocked, id=22515]
0x08099610 JavaThread "Reference Handler" daemon [_thread_blocked, id=22514]
=>0x0805bd48 JavaThread "main" [_thread_in_vm, id=22508]
Other Threads:
0x08096b50 VMThread [id=22509]
0x080a4828 WatcherThread [id=22519]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 2112K, used 371K [0x88a40000, 0x88c80000, 0x88f20000)
eden space 1920K, 9% used [0x88a40000, 0x88a6ccd8, 0x88c20000)
from space 192K, 100% used [0x88c20000, 0x88c50000, 0x88c50000)
to space 192K, 0% used [0x88c50000, 0x88c50000, 0x88c80000)
tenured generation total 27044K, used 18132K [0x88f20000, 0x8a989000, 0x8ca40000)
the space 27044K, 67% used [0x88f20000, 0x8a0d5110, 0x8a0d5200, 0x8a989000)
compacting perm gen total 25088K, used 25069K [0x8ca40000, 0x8e2c0000, 0x90a40000)
the space 25088K, 99% used [0x8ca40000, 0x8e2bb560, 0x8e2bb600, 0x8e2c0000)
ro space 8192K, 68% used [0x90a40000, 0x90fbb5e8, 0x90fbb600, 0x91240000)
rw space 12288K, 47% used [0x91240000, 0x917f9dc0, 0x917f9e00, 0x91e40000)
Dynamic libraries:
08048000-08056000 r-xp 00000000 03:05 30308 /usr/lib/j2sdk1.5-sun/bin/java
08056000-08058000 rwxp 0000e000 03:05 30308 /usr/lib/j2sdk1.5-sun/bin/java
08058000-09fc2000 rwxp 08058000 00:00 0 [heap]
4a816000-4a829000 r-xp 00000000 03:05 857272 /usr/lib/libz.so.1.2.3
4a829000-4a82a000 rwxp 00012000 03:05 857272 /usr/lib/libz.so.1.2.3
4a87e000-4a8e8000 r-xp 00000000 03:05 859767 /usr/lib/libfreetype.so.6.3.8
4a8e8000-4a8eb000 rwxp 0006a000 03:05 859767 /usr/lib/libfreetype.so.6.3.8
4a8ed000-4a911000 r-xp 00000000 03:05 860555 /usr/lib/libpng12.so.0.1.2.8
4a911000-4a912000 rwxp 00023000 03:05 860555 /usr/lib/libpng12.so.0.1.2.8
4a914000-4a931000 r-xp 00000000 03:05 859768 /usr/lib/libexpat.so.1.0.0
4a931000-4a934000 rwxp 0001d000 03:05 859768 /usr/lib/libexpat.so.1.0.0
4a936000-4a95f000 r-xp 00000000 03:05 859770 /usr/lib/libfontconfig.so.1.0.4
4a95f000-4a964000 rwxp 00029000 03:05 859770 /usr/lib/libfontconfig.so.1.0.4
4a964000-4a965000 rwxp 4a964000 00:00 0
4a976000-4a97e000 r-xp 00000000 03:05 861374 /usr/lib/libXcursor.so.1.0.2
4a97e000-4a97f000 rwxp 00007000 03:05 861374 /usr/lib/libXcursor.so.1.0.2
4aa4c000-4aa6b000 r-xp 00000000 03:05 860550 /usr/lib/libjpeg.so.62.0.0
4aa6b000-4aa6c000 rwxp 0001f000 03:05 860550 /usr/lib/libjpeg.so.62.0.0
4ab89000-4ab9b000 r-xp 00000000 03:05 861376 /usr/lib/libXft.so.2.1.2
4ab9b000-4ab9c000 rwxp 00011000 03:05 861376 /usr/lib/libXft.so.2.1.2
4abd0000-4abd3000 r-xp 00000000 03:05 872733 /usr/lib/libORBitCosNaming-2.so.0.0.0
4abd3000-4abd4000 rwxp 00003000 03:05 872733 /usr/lib/libORBitCosNaming-2.so.0.0.0
4abd6000-4abe6000 r-xp 00000000 03:05 872734 /usr/lib/libbonobo-activation.so.4.0.0
4abe6000-4abe9000 rwxp 0000f000 03:05 872734 /usr/lib/libbonobo-activation.so.4.0.0
4abf1000-4ac05000 r-xp 00000000 03:05 861878 /usr/lib/libgdk_pixbuf-2.0.so.0.800.9
4ac05000-4ac06000 rwxp 00014000 03:05 861878 /usr/lib/libgdk_pixbuf-2.0.so.0.800.9
4ac08000-4ac1f000 r-xp 00000000 03:05 862925 /usr/lib/libatk-1.0.so.0.1010.3
4ac1f000-4ac21000 rwxp 00016000 03:05 862925 /usr/lib/libatk-1.0.so.0.1010.3
4ac23000-4aeeb000 r-xp 00000000 03:05 862937 /usr/lib/libgtk-x11-2.0.so.0.800.9
4aeeb000-4aef4000 rwxp 002c7000 03:05 862937 /usr/lib/libgtk-x11-2.0.so.0.800.9
4aef4000-4aef7000 rwxp 4aef4000 00:00 0
4afac000-4b028000 r-xp 00000000 03:05 862917 /usr/lib/libgdk-x11-2.0.so.0.800.9
4b028000-4b02b000 rwxp 0007c000 03:05 862917 /usr/lib/libgdk-x11-2.0.so.0.800.9
4b02d000-4b042000 r-xp 00000000 03:05 861383 /usr/lib/libart_lgpl_2.so.2.3.17
4b042000-4b043000 rwxp 00014000 03:05 861383 /usr/lib/libart_lgpl_2.so.2.3.17
4b045000-4b04c000 r-xp 00000000 03:05 872688 /lib/libpopt.so.0.0.0
4b04c000-4b04d000 rwxp 00006000 03:05 872688 /lib/libpopt.so.0.0.0
4b15f000-4b1a8000 r-xp 00000000 03:05 861395 /usr/lib/libgcrypt.so.11.2.1
4b1a8000-4b1ad000 rwxp 00049000 03:05 861395 /usr/lib/libgcrypt.so.11.2.1
4b1af000-4b1b2000 r-xp 00000000 03:05 861393 /usr/lib/libgpg-error.so.0.1.4
4b1b2000-4b1b3000 rwxp 00002000 03:05 861393 /usr/lib/libgpg-error.so.0.1.4
4b1b5000-4b1c4000 r-xp 00000000 03:05 798280 /usr/lib/libtasn1.so.2.0.17
4b1c4000-4b1c5000 rwxp 0000e000 03:05 798280 /usr/lib/libtasn1.so.2.0.17
4b1d7000-4b1f8000 r-xp 00000000 03:05 874034 /usr/lib/libaudiofile.so.0.0.2
4b1f8000-4b1fb000 rwxp 00020000 03:05 874034 /usr/lib/libaudiofile.so.0.0.2
4b1fd000-4b204000 r-xp 00000000 03:05 874035 /usr/lib/libesd.so.0.2.36
4b204000-4b205000 rwxp 00007000 03:05 874035 /usr/lib/libesd.so.0.2.36
4b222000-4b27d000 r-xp 00000000 03:05 872872 /usr/lib/libgnutls.so.11.1.16
4b27d000-4b283000 rwxp 0005a000 03:05 872872 /usr/lib/libgnutls.so.11.1.16
4b285000-4b2ca000 r-xp 00000000 03:05 872701 /usr/lib/libORBit-2.so.0.0.0
4b2ca000-4b2d5000 rwxp 00045000 03:05 872701 /usr/lib/libORBit-2.so.0.0.0
4b2d5000-4b2d6000 rwxp 4b2d5000 00:00 0
4b369000-4b3b3000 r-xp 00000000 03:05 872763 /usr/lib/libbonobo-2.so.0.0.0
4b3b3000-4b3bd000 rwxp 0004a000 03:05 872763 /usr/lib/libbonobo-2.so.0.0.0
4b3bf000-4b416000 r-xp 00000000 03:05 874047 /usr/lib/libbonoboui-2.so.0.0.0
4b416000-4b419000 rwxp 00057000 03:05 874047 /usr/lib/libbonoboui-2.so.0.0.0
88a40000-88c80000 rwxp 88a40000 00:00 0
88c80000-88f20000 rwxp 88c80000 00:00 0
88f20000-8a989000 rwxp 88f20000 00:00 0
8a989000-8ca40000 rwxp 8a989000 00:00 0
8ca40000-8e2c0000 rwxp 8ca40000 00:00 0
8e2c0000-90a40000 rwxp 8e2c0000 00:00 0
90a40000-90fbc000 r-xs 00001000 03:05 30775 /usr/lib/j2sdk1.5-sun/jre/lib/i386/client/classes.jsa
90fbc000-91240000 rwxp 90fbc000 00:00 0
91240000-917fa000 rwxp 0057d000 03:05 30775 /usr/lib/j2sdk1.5-sun/jre/lib/i386/client/classes.jsa
917fa000-91e40000 rwxp 917fa000 00:00 0
91e40000-91f0f000 rwxp 00b37000 03:05 30775 /usr/lib/j2sdk1.5-sun/jre/lib/i386/client/classes.jsa
91f0f000-92240000 rwxp 91f0f000 00:00 0
92240000-92244000 r-xs 00c06000 03:05 30775 /usr/lib/j2sdk1.5-sun/jre/lib/i386/client/classes.jsa
92244000-92640000 rwxp 92244000 00:00 0
ace7e000-ace94000 r-xp 00000000 03:05 179380 /usr/lib/libpixman.so.1.0.0
ace94000-ace95000 rwxp 00016000 03:05 179380 /usr/lib/libpixman.so.1.0.0
ace95000-aceb8000 r-xp 00000000 03:05 46997 /usr/lib/libcairo.so.1.0.0
aceb8000-aceb9000 rwxp 00023000 03:05 46997 /usr/lib/libcairo.so.1.0.0
aced4000-acf47000 r-xp 00000000 03:05 30765 /usr/lib/j2sdk1.5-sun/jre/lib/i386/libfontmanager.so
acf47000-acf51000 rwxp 00073000 03:05 30765 /usr/lib/j2sdk1.5-sun/jre/lib/i386/libfontmanager.so
acf51000-acf55000 rwxp acf51000 00:00 0
acf55000-acf8b000 r-xp 00000000 03:05 30753 /usr/lib/j2sdk1.5-sun/jre/lib/i386/xawt/libmawt.so
acf8b000-acf8e000 rwxp 00035000 03:05 30753 /usr/lib/j2sdk1.5-sun/jre/lib/i386/xawt/libmawt.so
acf8e000-acf8f000 rwxp acf8e000 00:00 0
acf8f000-ad055000 r-xp 00000000 03:05 30776 /usr/lib/j2sdk1.5-sun/jre/lib/i386/libmlib_image.so
ad055000-ad056000 rwxp 000c5000 03:05 30776 /usr/lib/j2sdk1.5-sun/jre/lib/i386/libmlib_image.so
ad056000-ad0cb000 r-xp 00000000 03:05 30800 /usr/lib/j2sdk1.5-sun/jre/lib/i386/libawt.so
ad0cb000-ad0d1000 rwxp 00074000 03:05 30800 /usr/lib/j2sdk1.5-sun/jre/lib/i386/libawt.so
ad0d1000-ad0f5000 rwxp ad0d1000 00:00 0
ad0f5000-ad14c000 r-xs 00000000 03:07 19026 /home/thm/Apps/Workspace/Janus/lib/log4j-1.2.8.jar
ad14c000-ad21f000 r-xp 00000000 03:05 30235 /usr/lib/libstdc++.so.6.0.7
ad21f000-ad224000 rwxp 000d3000 03:05 30235 /usr/lib/libstdc++.so.6.0.7
ad224000-ad229000 rwxp ad224000 00:00 0
ad236000-ad23e000 r-xp 00000000 03:07 85702 /home/thm/Apps/Workspace/.metadata/.plugins/org.eclipse.pde. core/Janus/org.eclipse.osgi/bundles/198/1/.cp/libswt-cairo-g tk-3139.so
ad23e000-ad23f000 rwxp 00007000 03:07 85702 /home/thm/Apps/Workspace/.metadata/.plugins/org.eclipse.pde. core/Janus/org.eclipse.osgi/bundles/198/1/.cp/libswt-cairo-g tk-3139.so
ad23f000-ad244000 r-xp 00000000 03:05 46834 /usr/share/locale/de/LC_MESSAGES/glib20.mo
ad244000-ad24e000 r-xp 00000000 03:05 250033 /usr/lib/libpangox-1.0.so.0.1001.1
ad24e000-ad24f000 rwxp 00009000 03:05 250033 /usr/lib/libpangox-1.0.so.0.1001.1
ad24f000-ad254000 r-xp 00000000 03:05 265234 /usr/lib/libpangoxft-1.0.so.0.1001.1
ad254000-ad255000 rwxp 00005000 03:05 265234 /usr/lib/libpangoxft-1.0.so.0.1001.1
ad255000-ad269000 r-xp 00000000 03:05 14311 /usr/X11R6/lib/libICE.so.6.4
ad269000-ad26a000 rwxp 00014000 03:05 14311 /usr/X11R6/lib/libICE.so.6.4
ad26a000-ad26c000 rwxp ad26a000 00:00 0
ad26c000-ad273000 r-xp 00000000 03:05 535099 /usr/X11R6/lib/libSM.so.6.0
ad273000-ad274000 rwxp 00007000 03:05 535099 /usr/X11R6/lib/libSM.so.6.0
ad274000-ad27e000 r-xp 00000000 03:05 13600 /usr/lib/libgnome-keyring.so.0.0.1
ad27e000-ad27f000 rwxp 00009000 03:05 13600 /usr/lib/libgnome-keyring.so.0.0.1
ad27f000-ad2a9000 r-xp 00000000 03:05 141743 /usr/lib/libgnomecanvas-2.so.0.1200.0
ad2a9000-ad2aa000 rwxp 00029000 03:05 141743 /usr/lib/libgnomecanvas-2.so.0.1200.0
ad2aa000-ad2b0000 r-xp 00000000 03:05 1279435 /lib/tls/librt-2.3.5.so
ad2b0000-ad2b2000 rwxp 00006000 03:05 1279435 /lib/tls/librt-2.3.5.so
ad2b2000-ad2c1000 r-xp 00000000 03:05 1279434 /lib/tls/libresolv-2.3.5.so
ad2c1000-ad2c3000 rwxp 0000f000 03:05 1279434 /lib/tls/libresolv-2.3.5.so
ad2c3000-ad2c5000 rwxp ad2c3000 00:00 0
ad2c5000-ad3ce000 r-xp 00000000 03:05 388981 /usr/lib/libxml2.so.2.6.23
ad3ce000-ad3d7000 rwxp 00108000 03:05 388981 /usr/lib/libxml2.so.2.6.23
ad3d7000-ad406000 r-xp 00000000 03:05 439109 /usr/lib/libgconf-2.so.4.1.0
ad406000-ad409000 rwxp 0002e000 03:05 439109 /usr/lib/libgconf-2.so.4.1.0
ad409000-ad48e000 r-xp 00000000 03:05 102092 /usr/lib/libgnomeui-2.so.0.1200.0
ad48e000-ad492000 rwxp 00084000 03:05 102092 /usr/lib/libgnomeui-2.so.0.1200.0
ad492000-ad4a5000 r-xp 00000000 03:05 152811 /usr/lib/libgnome-2.so.0.1200.0
ad4a5000-ad4a6000 rwxp 00012000 03:05 152811 /usr/lib/libgnome-2.so.0.1200.0
ad4a6000-ad4ff000 r-xp 00000000 03:05 105741 /usr/lib/libgnomevfs-2.so.0.1200.2
ad4ff000-ad504000 rwxp 00059000 03:05 105741 /usr/lib/libgnomevfs-2.so.0.1200.2
ad504000-ad50e000 r-xp 00000000 03:05 65898 /lib/libgcc_s.so.1
ad50e000-ad50f000 rwxp 00009000 03:05 65898 /lib/libgcc_s.so.1
ad50f000-ad516000 r-xp 00000000 03:05 861389 /usr/lib/libfam.so.0.0.0
ad516000-ad517000 rwxp 00007000 03:05 861389 /usr/lib/libfam.so.0.0.0
ad517000-ad51e000 r-xp 00000000 03:05 107505 /usr/lib/gnome-vfs-2.0/modules/libfile.so
ad51e000-ad51f000 rwxp 00006000 03:05 107505 /usr/lib/gnome-vfs-2.0/modules/libfile.so
ad51f000-ad522000 r-xp 00000000 03:07 85026 /home/thm/Apps/Workspace/.metadata/.plugins/org.eclipse.pde. core/Janus/org.eclipse.osgi/bundles/198/1/.cp/libswt-gnome-g tk-3139.so
ad522000-ad523000 rwxp 00002000 03:07 85026 /home/thm/Apps/Workspace/.metadata/.plugins/org.eclipse.pde. core/Janus/org.eclipse.osgi/bundles/198/1/.cp/libswt-gnome-g tk-3139.so
ad523000-ad526000 r-xs 00000000 03:07 17722 /home/thm/Apps/Eclipse-Plugins/ru.nlmk.editors.position_1.0. 0/position.jar
ad526000-ad529000 ---p ad526000 00:00 0
ad529000-ad5a6000 rwxp ad529000 00:00 0
ad5a6000-ad606000 rwxs 00000000 00:07 4423710 /SYSV00000000 (deleted)
ad606000-ad625000 r-xs 00000000 03:07 14640 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.team.exampl es.filesystem_3.1.0/teamfilesystem.jar
ad625000-ad636000 r-xp 00000000 03:05 507424 /usr/share/fonts/truetype/ttf-bitstream-vera/Vera.ttf
ad636000-ad638000 r-xp 00000000 03:05 249960 /usr/lib/pango/1.4.0/modules/pango-basic-fc.so
ad638000-ad639000 rwxp 00001000 03:05 249960 /usr/lib/pango/1.4.0/modules/pango-basic-fc.so
ad639000-ad699000 rwxs 00000000 00:07 4358163 /SYSV00000000 (deleted)
ad699000-ad6b8000 r-xp 00000000 03:05 329887 /usr/share/locale/de/LC_MESSAGES/libc.mo
ad6b8000-ad6de000 r-xp 00000000 03:07 64348 /home/thm/Apps/Workspace/.metadata/.plugins/org.eclipse.pde. core/Janus/org.eclipse.osgi/bundles/198/1/.cp/libswt-gtk-313 9.so
ad6de000-ad6e0000 rwxp 00025000 03:07 64348 /home/thm/Apps/Workspace/.metadata/.plugins/org.eclipse.pde. core/Janus/org.eclipse.osgi/bundles/198/1/.cp/libswt-gtk-313 9.so
ad6e0000-ad6e1000 rwxp ad6e0000 00:00 0
ad6e1000-ad6fd000 r-xp 00000000 03:05 306673 /usr/share/locale/de/LC_MESSAGES/gtk20-properties.mo
ad6fd000-ad6fe000 r-xp 00000000 03:05 1282973 /usr/lib/gconv/ISO8859-1.so
ad6fe000-ad700000 rwxp 00000000 03:05 1282973 /usr/lib/gconv/ISO8859-1.so
ad700000-ad70b000 r-xp 00000000 03:05 306670 /usr/share/locale/de/LC_MESSAGES/gtk20.mo
ad70b000-ad72f000 r-xp 00000000 03:05 264542 /usr/lib/libpangoft2-1.0.so.0.1001.1
ad72f000-ad730000 rwxp 00024000 03:05 264542 /usr/lib/libpangoft2-1.0.so.0.1001.1
ad730000-ad778000 r-xp 00000000 03:07 82543 /home/thm/scratch/cairo-1.0.0/src/.libs/libcairo.so.2.2.2
ad778000-ad779000 rwxp 00048000 03:07 82543 /home/thm/scratch/cairo-1.0.0/src/.libs/libcairo.so.2.2.2
ad779000-ad7fc000 r-xp 00000000 03:05 54525 /usr/lib/libglib-2.0.so.0.800.5
ad7fc000-ad7fd000 rwxp 00083000 03:05 54525 /usr/lib/libglib-2.0.so.0.800.5
ad7fd000-ad7ff000 r-xp 00000000 03:05 71403 /usr/lib/libgmodule-2.0.so.0.800.5
ad7ff000-ad800000 rwxp 00002000 03:05 71403 /usr/lib/libgmodule-2.0.so.0.800.5
ad800000-ad837000 r-xp 00000000 03:05 71156 /usr/lib/libgobject-2.0.so.0.800.5
ad837000-ad838000 rwxp 00037000 03:05 71156 /usr/lib/libgobject-2.0.so.0.800.5
ad838000-ad86d000 r-xp 00000000 03:05 250018 /usr/lib/libpango-1.0.so.0.1001.1
ad86d000-ad86f000 rwxp 00035000 03:05 250018 /usr/lib/libpango-1.0.so.0.1001.1
ad86f000-ad875000 r-xp 00000000 03:05 250021 /usr/lib/libpangocairo-1.0.so.0.1001.1
ad875000-ad876000 rwxp 00005000 03:05 250021 /usr/lib/libpangocairo-1.0.so.0.1001.1
ad876000-ad93e000 r-xp 00000000 03:05 843992 /usr/X11R6/lib/libX11.so.6.2
ad93e000-ad942000 rwxp 000c7000 03:05 843992 /usr/X11R6/lib/libX11.so.6.2
ad942000-ad94f000 r-xp 00000000 03:05 540953 /usr/X11R6/lib/libXext.so.6.4
ad94f000-ad950000 rwxp 0000d000 03:05 540953 /usr/X11R6/lib/libXext.so.6.4
ad950000-ad952000 r-xp 00000000 03:05 388986 /usr/X11R6/lib/libXinerama.so.1.0
ad952000-ad953000 rwxp 00001000 03:05 388986 /usr/X11R6/lib/libXinerama.so.1.0
ad953000-ad95a000 r-xp 00000000 03:05 11534 /usr/X11R6/lib/libXi.so.6.0
ad95a000-ad95b000 rwxp 00006000 03:05 11534 /usr/X11R6/lib/libXi.so.6.0
ad95b000-ad963000 r-xp 00000000 03:05 44333 /usr/lib/libXrender.so.1.3.0
ad963000-ad964000 rwxp 00007000 03:05 44333 /usr/lib/libXrender.so.1.3.0
ad964000-ad967000 r-xp 00000000 03:05 367674 /usr/X11R6/lib/libXrandr.so.2.0
ad967000-ad968000 rwxp 00002000 03:05 367674 /usr/X11R6/lib/libXrandr.so.2.0
ad968000-ad96d000 r-xp 00000000 03:05 141981 /usr/X11R6/lib/libXtst.so.6.1
ad96d000-ad96e000 rwxp 00004000 03:05 141981 /usr/X11R6/lib/libXtst.so.6.1
ad96e000-ad971000 r-xp 00000000 03:05 71153 /usr/lib/libgthread-2.0.so.0.800.5
ad971000-ad972000 rwxp 00002000 03:05 71153 /usr/lib/libgthread-2.0.so.0.800.5
ad973000-ad976000 rwxs 00000000 00:07 4390941 /SYSV00000000 (deleted)
ad976000-ad978000 r-xp 00000000 03:07 82521 /home/thm/Apps/Workspace/.metadata/.plugins/org.eclipse.pde. core/Janus/org.eclipse.osgi/bundles/24/1/.cp/os/linux/x86/li bcore_3_1_0.so
ad978000-ad979000 rwxp 00001000 03:07 82521 /home/thm/Apps/Workspace/.metadata/.plugins/org.eclipse.pde. core/Janus/org.eclipse.osgi/bundles/24/1/.cp/os/linux/x86/li bcore_3_1_0.so
ad979000-ad98a000 r-xp 00000000 03:05 17221 /usr/lib/gtk-2.0/2.4.0/engines/libclearlooks.so
ad98a000-ad98b000 rwxp 00011000 03:05 17221 /usr/lib/gtk-2.0/2.4.0/engines/libclearlooks.so
ad98b000-ad98c000 r-xp 00000000 03:05 843988 /usr/X11R6/lib/X11/locale/lib/common/xlcUTF8Load.so.2
ad98c000-ad98d000 rwxp 00000000 03:05 843988 /usr/X11R6/lib/X11/locale/lib/common/xlcUTF8Load.so.2
ad98d000-ad9cf000 r-xp 00000000 03:07 63835 /home/thm/Apps/Workspace/.metadata/.plugins/org.eclipse.pde. core/Janus/org.eclipse.osgi/bundles/198/1/.cp/libswt-pi-gtk- 3139.so
ad9cf000-ad9d1000 rwxp 00042000 03:07 63835 /home/thm/Apps/Workspace/.metadata/.plugins/org.eclipse.pde. core/Janus/org.eclipse.osgi/bundles/198/1/.cp/libswt-pi-gtk- 3139.so
ad9d1000-ad9d2000 r-xs 00000000 03:07 17526 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.ui.workbenc h.compatibility_3.1.0/compatibility.jar
ad9d2000-ad9d5000 ---p ad9d2000 00:00 0
ad9d5000-ada52000 rwxp ad9d5000 00:00 0
ada52000-ada55000 ---p ada52000 00:00 0
ada55000-adad2000 rwxp ada55000 00:00 0
adad2000-adaec000 r-xs 00000000 03:05 958206 /tmp/jar_cache3307.tmp (deleted)
adaec000-adb00000 r-xs 00000000 03:07 14772 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.xsd.editor_ 2.1.0.jar
adb00000-adb30000 r-xs 00000000 03:07 15984 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.xsd.edit_2. 1.0.jar
adb30000-adb36000 r-xs 00000000 03:07 16987 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.xsd.ecore.i mporter_2.1.0.jar
adb36000-adbec000 r-xs 00000000 03:07 15306 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.xsd_2.1.1.j ar
adbec000-adbfd000 r-xs 00000000 03:07 84929 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.xsdedit or.doc.user_1.0.0.jar
adbfd000-adce0000 r-xs 00000000 03:07 84928 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.xsd.ui_ 1.0.0.jar
adce0000-adcee000 r-xs 00000000 03:07 84927 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.xsd.cor e_1.0.0.jar
adcee000-adcfd000 r-xs 00000000 03:07 84926 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.xmledit or.doc.user_1.0.0.jar
adcfd000-adcff000 r-xs 00000000 03:07 84923 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.xml.ui. infopop_1.0.0.jar
adcff000-add9e000 r-xs 00000000 03:07 84925 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.xml.ui_ 1.0.0.jar
add9e000-ade29000 r-xs 00000000 03:07 84922 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.xml.cor e_1.0.0.jar
ade29000-ade32000 r-xs 00000000 03:07 84911 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.wsi.ui. doc.user_1.0.0.jar
ade32000-ade40000 r-xs 00000000 03:07 84917 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.wsi.ui_ 1.0.0.jar
ade40000-adf03000 r-xs 00000000 03:07 84921 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.wsi_1.0 .0.jar
adf03000-adf29000 r-xs 00000000 03:07 84905 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.wsdl.va lidation_1.0.0.jar
adf29000-adf3a000 r-xs 00000000 03:07 84892 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.wsdl.ui .doc.user_1.0.0.jar
adf3a000-adffa000 r-xs 00000000 03:07 84902 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.wsdl.ui _1.0.0.jar
adffa000-ae0aa000 r-xs 00000000 03:07 84910 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.wsdl_1. 0.0.jar
ae0aa000-ae0ae000 r-xs 00000000 03:07 84886 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.ws.ui_1 .0.0.jar
ae0ae000-ae0b9000 r-xs 00000000 03:07 84871 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.ws.pars er_1.0.0.jar
ae0b9000-ae0ba000 r-xs 00000000 03:07 84870 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.ws.info pop_1.0.0.jar
ae0ba000-ae0e9000 r-xs 00000000 03:07 84891 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.ws_1.0. 0.jar
ae0e9000-ae0f7000 r-xs 00000000 03:07 84684 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.webtool s.doc.user_1.0.0.jar
ae0f7000-ae100000 r-xs 00000000 03:07 84669 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.web.ui_ 1.0.0.jar
ae100000-ae10a000 r-xs 00000000 03:07 84675 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.web_1.0 .0.jar
ae10a000-ae11b000 r-xs 00000000 03:07 84665 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.validat ion.ui_1.0.0.jar
ae11b000-ae143000 r-xs 00000000 03:07 84667 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.validat ion_1.0.0.jar
ae143000-ae145000 r-xs 00000000 03:07 84594 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.sse.ui. infopop_1.0.0.jar
ae145000-ae1e2000 r-xs 00000000 03:07 84647 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.sse.ui_ 1.0.0.jar
ae1e2000-ae1f5000 r-xs 00000000 03:07 84593 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.sse.doc .user_1.0.0.jar
ae1f5000-ae24e000 r-xs 00000000 03:07 84591 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.sse.cor e_1.0.0.jar
ae24e000-ae252000 r-xs 00000000 03:07 84573 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.sqledit or.doc.user_1.0.0.jar
ae252000-ae254000 r-xs 00000000 03:07 84569 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.server. ui.infopop_7.0.0.jar
ae254000-ae25b000 r-xs 00000000 03:07 84530 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.server. ui.doc.user_1.0.0.jar
ae25b000-ae2ea000 r-xs 00000000 03:07 84572 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.server. ui_1.0.0.jar
ae2ea000-ae325000 r-xs 00000000 03:07 84517 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.server. core_1.0.0.jar
ae325000-ae32d000 r-xs 00000000 03:07 84502 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.rdb.sql scrapbook_1.0.0.jar
ae32d000-ae32e000 r-xs 00000000 03:07 84464 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.rdb.sql editor.infopop_1.0.0.jar
ae32e000-ae32f000 r-xs 00000000 03:07 84462 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.rdb.ser ver.ui.infopop_1.0.0.jar
ae32f000-ae355000 r-xs 00000000 03:07 84463 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.rdb.ser ver.ui_1.0.0.jar
ae355000-ae356000 r-xs 00000000 03:07 84349 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.rdb.out putview.infopop_1.0.0.jar
ae356000-ae360000 r-xs 00000000 03:07 84330 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.rdb.mys ql_1.0.0.jar
ae360000-ae39d000 r-xs 00000000 03:07 84328 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.rdb.mod els.sql.edit_1.0.0.jar
ae39d000-ae43a000 r-xs 00000000 03:07 84329 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.rdb.mod els.sql_1.0.0.jar
ae43a000-ae461000 r-xs 00000000 03:07 84326 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.rdb.mod els.dbdefinition_1.0.0.jar
ae461000-ae462000 r-xs 00000000 03:07 84321 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.rdb.fe. ui.infopop_1.0.0.jar
ae462000-ae464000 r-xs 00000000 03:07 84316 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.rdb.fe. ui.actions_1.0.0.jar
ae464000-ae46e000 r-xs 00000000 03:07 84322 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.rdb.fe. ui_1.0.0.jar
ae46e000-ae475000 r-xs 00000000 03:07 84313 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.rdb.der by.ui_1.0.0.jar
ae475000-ae486000 r-xs 00000000 03:07 84314 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.rdb.der by_1.0.0.jar
ae486000-ae488000 r-xs 00000000 03:07 84312 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.rdb.dbd efinition.sybase_1.0.0.jar
ae488000-ae48a000 r-xs 00000000 03:07 84306 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.rdb.dbd efinition.sqlserver_1.0.0.jar
ae48a000-ae48f000 r-xs 00000000 03:07 84305 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.rdb.dbd efinition.oracle_1.0.0.jar
ae48f000-ae491000 r-xs 00000000 03:07 84303 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.rdb.dbd efinition.mysql_1.0.0.jar
ae491000-ae496000 r-xs 00000000 03:07 84301 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.rdb.dbd efinition.informix_1.0.0.jar
ae496000-ae499000 r-xs 00000000 03:07 84298 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.rdb.dbd efinition.derby_1.0.0.jar
ae499000-ae49e000 r-xs 00000000 03:07 84297 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.rdb.dbd efinition.db2.zseries_1.0.0.jar
ae49e000-ae4a2000 r-xs 00000000 03:07 84296 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.rdb.dbd efinition.db2.luw_1.0.0.jar
ae4a2000-ae4a4000 r-xs 00000000 03:07 84294 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.rdb.dbd efinition.db2.iseries_1.0.0.jar
ae4a4000-ae4b9000 r-xs 00000000 03:07 84291 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.rdb.dat a.ui_1.0.0.jar
ae4b9000-ae4c5000 r-xs 00000000 03:07 84289 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.rdb.dat a.core_1.0.0.jar
ae4c5000-ae4e7000 r-xs 00000000 03:07 84288 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.rdb.cor e_1.0.0.jar
ae4e7000-ae4e8000 r-xs 00000000 03:07 82579 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.rdb.con nection.ui.infopop_1.0.0.jar
ae4e8000-ae510000 r-xs 00000000 03:07 82580 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.rdb.con nection.ui_1.0.0.jar
ae510000-ae511000 r-xs 00000000 03:07 82577 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.javascr ipt.ui.infopop_1.0.0.jar
ae511000-ae58f000 r-xs 00000000 03:07 82578 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.javascr ipt.ui_1.0.0.jar
ae58f000-ae59c000 r-xs 00000000 03:07 82575 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.javascr ipt.core_1.0.0.jar
ae59c000-ae59d000 r-xs 00000000 03:07 82562 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.interne t.proxy.infopop_1.0.0.jar
ae59d000-ae5a6000 r-xs 00000000 03:07 82564 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.interne t.proxy_1.0.0.jar
ae5a6000-ae5be000 r-xs 00000000 03:07 82538 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.interne t.monitor.ui_1.0.0.jar
ae5be000-ae5cd000 r-xs 00000000 03:07 82537 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.interne t.monitor.core_1.0.0.jar
ae5cd000-ae5d6000 r-xs 00000000 03:07 82532 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.interne t.cache_1.0.0.jar
ae5d6000-ae5d8000 r-xs 00000000 03:07 82519 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.html.ui .infopop_1.0.0.jar
ae5d8000-ae602000 r-xs 00000000 03:07 82525 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.html.ui _1.0.0.jar
ae602000-ae61c000 r-xs 00000000 03:07 82515 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.html.st andard.dtds_1.0.0.jar
ae61c000-ae6a2000 r-xs 00000000 03:07 82487 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.html.co re_1.0.0.jar
ae6a2000-ae6a7000 r-xs 00000000 03:07 82465 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.dtdedit or.doc.user_1.0.0.jar
ae6a7000-ae6c2000 r-xs 00000000 03:07 82464 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.dtd.ui_ 1.0.0.jar
ae6c2000-ae721000 r-xs 00000000 03:07 82434 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.dtd.cor e_1.0.0.jar
ae721000-ae7de000 r-xs 00000000 03:07 82433 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.doc.use r_1.0.0.jar
ae7de000-ae7e0000 r-xs 00000000 03:07 82432 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.datatoo ls.server.ui.doc.user_1.0.0.jar
ae7e0000-ae7e2000 r-xs 00000000 03:07 82431 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.datatoo ls.fe.ui.doc.user_1.0.0.jar
ae7e2000-ae7ea000 r-xs 00000000 03:07 82430 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.datatoo ls.connection.ui.doc.user_1.0.0.jar
ae7ea000-ae817000 r-xs 00000000 03:07 82429 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.css.ui_ 1.0.0.jar
ae817000-ae88b000 r-xs 00000000 03:07 82428 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.css.cor e_1.0.0.jar
ae88b000-ae893000 r-xs 00000000 03:07 82427 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.common. uriresolver_1.0.0.jar
ae893000-ae8ac000 r-xs 00000000 03:07 82424 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.common. ui.properties_1.0.0.jar
ae8ac000-ae8bb000 r-xs 00000000 03:07 82426 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.common. ui_1.0.0.jar
ae8bb000-ae8f6000 r-xs 00000000 03:07 82423 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.common. snippets_1.0.0.jar
ae8f6000-ae912000 r-xs 00000000 03:07 82422 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.common. project.facet.ui_1.0.0.jar
ae912000-ae930000 r-xs 00000000 03:07 82421 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.common. project.facet.core_1.0.0.jar
ae930000-ae942000 r-xs 00000000 03:07 82420 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.common. navigator.workbench_1.0.0.jar
ae942000-ae977000 r-xs 00000000 03:07 82419 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.common. navigator.views_1.0.0.jar
ae977000-ae9ac000 r-xs 00000000 03:07 82418 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.common. modulecore_1.0.0.jar
ae9ac000-ae9ad000 r-xs 00000000 03:07 82416 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.common. infopop_1.0.0.jar
ae9ad000-ae9cc000 r-xs 00000000 03:07 82414 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.common. frameworks.ui_1.0.0.jar
ae9cc000-ae9e7000 r-xs 00000000 03:07 82415 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.common. frameworks_1.0.0.jar
ae9e7000-ae9f0000 r-xs 00000000 03:07 82413 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.common. environment_1.0.0.jar
ae9f0000-aea0e000 r-xs 00000000 03:07 82412 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.common. emfworkbench.integration_1.0.0.jar
aea0e000-aea3a000 r-xs 00000000 03:07 82411 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.common. emf_1.0.0.jar
aea3a000-aea50000 r-xs 00000000 03:07 82396 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.command .env.ui_1.0.0.jar
aea50000-aea5c000 r-xs 00000000 03:07 82395 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst.command .env.core_1.0.0.jar
aea5c000-aea5f000 r-xs 00000000 03:07 84930 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.wst_1.0.0.j ar
aea5f000-aeacf000 r-xs 00000000 03:07 16707 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.update.ui_3 .1.1.jar
aeacf000-aead5000 r-xs 00000000 03:07 15344 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.update.sche duler_3.1.0.jar
aead5000-aead6000 r-xs 00000000 03:07 16921 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.update.core .linux_3.1.0.jar
aead6000-aeb4e000 r-xs 00000000 03:07 15010 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.update.core _3.1.1.jar
aeb4e000-aeb60000 r-xs 00000000 03:07 15019 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.uml2.resour ces_1.1.0.jar
aeb60000-aeb7e000 r-xs 00000000 03:07 17354 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.uml2.exampl es.ui_1.1.1.jar
aeb7e000-aeb82000 r-xs 00000000 03:07 15280 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.uml2.exampl es.emof2ecore_1.1.1.jar
aeb82000-aeb89000 r-xs 00000000 03:07 16000 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.uml2.exampl es_1.1.1.jar
aeb89000-aeb9b000 r-xs 00000000 03:07 16196 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.uml2.editor _1.1.1.jar
aeb9b000-aec47000 r-xs 00000000 03:07 17388 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.uml2.edit_1 .1.1.jar
aec47000-aec4b000 r-xs 00000000 03:07 15247 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.uml2.ecore. importer_1.1.1.jar
aec4b000-aec50000 r-xs 00000000 03:07 14834 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.uml2.common .edit_1.1.1.jar
aec50000-aec59000 r-xs 00000000 03:07 15303 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.uml2.common _1.1.1.jar
aec59000-aec60000 r-xs 00000000 03:07 15072 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.uml2.codege n.ecore.ui_1.1.1.jar
aec60000-aec96000 r-xs 00000000 03:07 14635 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.uml2.codege n.ecore_1.1.1.jar
aec96000-aee6d000 r-xs 00000000 03:07 15970 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.uml2_1.1.1. jar
aee6d000-aeed7000 r-xs 00000000 03:07 14748 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.ui.workbenc h.texteditor_3.1.1.jar
aeed7000-af196000 r-xs 00000000 03:07 15878 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.ui.workbenc h_3.1.1.jar
af196000-af1a6000 r-xs 00000000 03:07 15713 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.ui.views_3. 1.1.jar
af1a6000-af1bd000 r-xs 00000000 03:07 15998 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.ui.presenta tions.r21_3.1.0.jar
af1bd000-af201000 r-xs 00000000 03:07 15971 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.ui.intro_3. 1.1.jar
af201000-af379000 r-xs 00000000 03:07 15307 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.ui.ide_3.1. 1.jar
af379000-af3ac000 r-xs 00000000 03:07 14771 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.ui.forms_3. 1.0.jar
af3ac000-af3ca000 r-xs 00000000 03:07 17016 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.ui.external tools_3.1.1.jar
af3ca000-af3d5000 r-xs 00000000 03:07 16988 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.ui.examples .undo_3.1.0.jar
af3d5000-af43c000 r-xs 00000000 03:07 14637 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.ui.editors_ 3.1.1.jar
af43c000-af45d000 r-xs 00000000 03:07 15862 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.ui.console_ 3.1.0.jar
af45d000-af485000 r-xs 00000000 03:07 14833 /home/thm/Apps/Eclipse-3.1.1/plugins/org.eclipse.u
Current Time: Fri Apr 26 23:08:22 GMT 2024
Powered by FUDForum. Page generated in 0.02927 seconds
