Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Is this a resource leak bug?
Is this a resource leak bug? [message #466061] |
Fri, 30 December 2005 09:52 |
Zhiqiang Qian Messages: 76 Registered: July 2009 |
Member |
--------------040301050003000500010205
Hi All,
We are currently working on some SWT graphics applications. But when I
use some of the new features of GC since 3.1, it often pops up a "No
More Handle" exception. After investigation, I found this is caused by
the GC.getClipping(Region) routine when under advanced mode.
My environment: WindowsXP Pro, JDK1.4.2, Eclipse3.1(also tested in 3.2).
Here is the code snippet I used to reproduce:
Region rg1, rg2;
rg1 = new Region( Display.getDefault( ) );
// gc.setClipping( 0, 0, 300, 1000 );
gc.getClipping( rg1 );
// ==Enter Advanced Mode
gc.setAdvanced( false );
gc.setAntialias( 1 );
gc.setTextAntialias( 1 );
gc.setAlpha( 127 );
gc.setClipping( rg1 );
gc.drawRectangle( 220, 10, 200, 100 );
gc.drawArc( 220, 10, 200, 100, -45, 45 );
gc.fillArc( 220, 10, 200, 100, 45, 90 );
// A:
rg2 = new Region( Display.getDefault( ) );
gc.getClipping( rg2 );
// B:
// rg2 = rg1;
// ====Leave Advanced Mode
gc.setClipping( rg2 );
gc.drawRectangle( 430, 10, 200, 100 );
rg1.dispose( );
rg1 = null;
rg2.dispose( );
rg2 = null;
Everytime you run this code(I put it in a method loop), the windows
GDIHandle keeps increasing(You can watch it from the windows
TaskManager). And the strange thing is, if you comment out the code
block A, and use code block B, everything is fine.
So I guess is this a bug for SWT? Since this causes a resource leak, so
its level should be critical.
Any comments are highly appreciated, and also a full test code snippet
is enclosed. Thanks.
name="TestAdvance.java"
Content-Disposition: inline;
filename="TestAdvance.java"
* Copyright (c) 2004 Actuate Corporation.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* Actuate Corporation - initial API and implementation
package org.eclipse.birt.chart.demo.samples;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.PaintEvent;
import org.eclipse.swt.events.PaintListener;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.events.SelectionListener;
import org.eclipse.swt.graphics.GC;
import org.eclipse.swt.graphics.Region;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Shell;
public class TestAdvance
private static boolean blue = true;
public static void main( String[] args )
swt( );
static void swt( )
// DeviceData dd = new DeviceData( );
// dd.tracking = true;
// Display disp = new Display( dd );
Display disp = Display.getDefault( );
// Sleak sl = new Sleak( );
// sl.open( );
Shell shl = new Shell( disp );
shl.setSize( 700, 200 );
drawArc( shl );
shl.open( );
while ( !shl.isDisposed( ) )
if ( !disp.readAndDispatch( ) )
disp.sleep( );
disp.dispose( );
private static void drawArc( Shell shl )
shl.setLayout( new GridLayout( ) );
Button btn = new Button( shl, SWT.PUSH );
btn.setText( "repaint" ); //$NON-NLS-1$
GridData gd = new GridData( );
gd.widthHint = 100;
gd.heightHint = 20;
btn.setLayoutData( gd );
final Composite comp = new Composite( shl, SWT.NONE );
comp.setLayoutData( new GridData( GridData.FILL_BOTH ) );
comp.addPaintListener( new PaintListener( ) {
public void paintControl( PaintEvent e )
GC gc = e.gc;
gc.setBackground( blue ? Display.getDefault( )
.getSystemColor( SWT.COLOR_BLUE )
: Display.getDefault( ).getSystemColor( SWT.COLOR_RED ) );
blue = !blue;
gc.drawRectangle( 10, 10, 200, 100 );
gc.drawArc( 10, 10, 200, 100, -45, 45 );
gc.fillArc( 10, 10, 200, 100, 45, 90 );
Region rg1, rg2;
gc.setAlpha( 127 );
// rg2 = rg1;
rg1.dispose( );
rg1 = null;
rg2.dispose( );
rg2 = null;
btn.addSelectionListener( new SelectionListener( ) {
public void widgetDefaultSelected( SelectionEvent e )
public void widgetSelected( SelectionEvent e )
comp.redraw( );
--------------040301050003000500010205--
Re: Is this a resource leak bug? [message #466144 is a reply to message #466061] |
Tue, 03 January 2006 19:27 |
Veronika Irvine Messages: 1272 Registered: July 2009 |
I filed the following bug report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=122550
"Zhiqiang Qian" <zqian@actuate.com> wrote in message
news:dp2vvc$pu3$1@utils.eclipse.org...
> Hi All,
> Region rg1, rg2;
> gc.setAlpha( 127 );
> // A:
> // B:
> // rg2 = rg1;
> rg1.dispose( );
> rg1 = null;
> rg2.dispose( );
> rg2 = null;
> * Contributors:
> import org.eclipse.swt.widgets.Display;
> swt( );
> static void swt( )
> // sl.open( );
> drawArc( shl );
> shl.open( );
> disp.sleep( );
> disp.dispose( );
> gd.widthHint = 100;
> gd.heightHint = 20;
> GC gc = e.gc;
> blue = !blue;
> Region rg1, rg2;
> gc.setAlpha( 127 );
> // rg2 = rg1;
> rg1.dispose( );
> rg1 = null;
> rg2.dispose( );
> rg2 = null;
> comp.redraw( );
Re: Is this a resource leak bug? [message #466147 is a reply to message #466144] |
Tue, 03 January 2006 20:21 |
By the way, the code presented is not running under advanced mode:
>>gc.setAlpha( 127 );
>>// A:
>>// B:
>>// rg2 = rg1;
This doesn't cause advanced mode to be entered. Because the first line
says gc.setAdvanced(false) NOT gc.setAdvanced(true)!
So the bug is really with not advanced mode. Though this isn't to say
there isn't a problem in advanced mode too!
Rich Kulp
Re: Is this a resource leak bug? [message #466154 is a reply to message #466149] |
Tue, 03 January 2006 22:21 |
Ok. But that means the gc.setAdvanced(false) is unneeded because you
would be turning it off and then turning it back on if it was already on
because setAntialias automatically turns it on if it was not already on.
Veronika Irvine wrote:
> Calling gc.setAntialias( 1 ) uses GDI+ on Windows. So calling the following
> code will print out "true":
> gc.getAdvanced(false);
> gc.setAntialias(1);
> System.out.println(gc.getAdvanced());
> To recreate the bug, you do need to cause the GC to use GDI+.
> "Rich Kulp" <richkulp@us.NO_SPAM.ibm.com> wrote in message
> news:dpemc4$lv0$1@utils.eclipse.org...
Rich Kulp
Re: Is this a resource leak bug? [message #466162 is a reply to message #466144] |
Wed, 04 January 2006 02:48 |
Member |
Thanks Veronika, I've added myself to the CC list.
>> Hi All,
>> Region rg1, rg2;
>> gc.setAlpha( 127 );
>> // A:
>> // B:
>> // rg2 = rg1;
>> rg1.dispose( );
>> rg1 = null;
>> rg2.dispose( );
>> rg2 = null;
>> * Contributors:
>> swt( );
>> static void swt( )
>> // sl.open( );
>> drawArc( shl );
>> shl.open( );
>> disp.sleep( );
>> disp.dispose( );
>> gd.widthHint = 100;
>> gd.heightHint = 20;
>> GC gc = e.gc;
>> blue = !blue;
>> Region rg1, rg2;
>> gc.setAlpha( 127 );
>> // rg2 = rg1;
>> rg1.dispose( );
>> rg1 = null;
>> rg2.dispose( );
>> rg2 = null;
>> comp.redraw( );
Re: Is this a resource leak bug? [message #466163 is a reply to message #466154] |
Wed, 04 January 2006 02:55 |
Member |
Hi Rich,
Since calling gc.setAdvanced(true) will turn on all the advanced
features for all graphics operations, and what we want is just one or a
few of them, so we call setAdvance(false) first before those specific
advanced callings.
Here is what the JavaDoc of GC.setAdvanced() says:
* Sets the receiver to always use the operating system's advanced graphics
* subsystem for all graphics operations if the argument is
<code>true</code>.
* If the argument is <code>false</code>, the advanced graphics
subsystem is
* no longer used, advanced graphics state is cleared and the normal
graphics
* subsystem is used from now on.
* <p>
* Normally, the advanced graphics subsystem is invoked automatically when
* any one of the alpha, antialias, patterns, interpolation, paths,
clipping
* or transformation operations in the receiver is requested. When the
receiver
* is switched into advanced mode, the advanced graphics subsystem
performs both
* advanced and normal graphics operations. Because the two subsystems are
* different, their output may differ. Switching to advanced graphics
before
* any graphics operations are performed ensures that the output is
consistent.
* </p>
>> following code will print out "true":
>> gc.setAntialias(1);
Current Time: Sat Apr 27 05:17:12 GMT 2024
Powered by FUDForum. Page generated in 0.03604 seconds
