Home » Eclipse Projects » Rich Client Platform (RCP) » HowTo: EditorPages isDirty() and markDirty()
HowTo: EditorPages isDirty() and markDirty() [message #465888] Wed, 11 April 2007 10:32 Go to next message
Next problem
For my UI i am following the tutorial
*http://www.eclipse.org/articles/Article-Forms/article.html* which is
quite good but not complete. The part how to use the lifecycle of a
formpage is missing. I thought I can add a ModifyListener to my
controlls and just call markDirty() but this method is only used for
ContributionManagers (as far as I found out). How can I set an editor
(with multiple pages) to a dirty state which then schould show a * in
the title of this editor
Thx
-- Marc
Re: HowTo: EditorPages isDirty() and markDirty() [message #465893 is a reply to message #465888] Wed, 11 April 2007 13:44 Go to previous messageGo to next message
Originally posted by: bugjester.yahoo.com
You need to fire an PROP_DIRTY event from your editor whenever you
change the dirty state. Something like this:
public class MyEditor extends EditorPart
private boolean isDirty = false;
private void setDirty(boolean dirty) {
this.isDirty = dirty;
firePropertyChange(PROP_DIRTY);
public boolean isDirty() {
return this.isDirty();
Steve
Marc Schlegel wrote:
> Next problem
> Thx
> -- Marc
Re: HowTo: EditorPages isDirty() and markDirty() [message #465894 is a reply to message #465893] Wed, 11 April 2007 14:22 Go to previous messageGo to next message
Woops, there is an infinite loop in there. The isDirty() method should be:
return this.isDirty;
I should practice "pair newsgrouping" to avoid those kinds of problems.
Steve
> Steve
>> Next problem
>> Thx
>> -- Marc
Re: HowTo: EditorPages isDirty() and markDirty() [message #466006 is a reply to message #465894] Thu, 12 April 2007 05:30 Go to previous messageGo to next message
Thanks for your help
I had a look at the implementation of isDirty() in FormEditor and this
one checks all FormPages if there is one dirty
if (pages != null) {
for (int i = 0; i < pages.size(); i++) {
Object page = pages.get(i);
if (page instanceof IFormPage) {
IFormPage fpage = (IFormPage) page;
if (fpage.isDirty())
return true;
return super.isDirty();
so, it must be possible to set the registered FormPages to dirty...but how?
best regards
-- Marc
> Steve
Re: HowTo: EditorPages isDirty() and markDirty() [message #466040 is a reply to message #466006] Thu, 12 April 2007 13:59 Go to previous messageGo to next message
As far as I know, each form page is responsible for managing its own
dirty state. That is why I just put a setDirty() method in each page
which can get called from a ModifyListener or other listener watching
for form element changes. That setDirty() method just sets a flag that
is returned by isDirty() and it fires the PROP_DIRTY event so the
platform knows that the dirty state has changed.
Re: HowTo: EditorPages isDirty() and markDirty() [message #466056 is a reply to message #466040] Thu, 12 April 2007 17:38 Go to previous messageGo to next message
Thank you very much Steve, it works just fine. The only thing I am
missing is the * in front of editors title. Do I have to implement this
by my own?
>> how?
Re: HowTo: EditorPages isDirty() and markDirty() [message #466058 is a reply to message #466056] Thu, 12 April 2007 19:03 Go to previous messageGo to next message
You shouldn't have to. For me just calling
WorkenchPart.firePropertyChange(PROP_DIRTY) causes the * to show up in
the title.
Are you using setPartName() to set the title of the editor? If you are
overriding getPartName() instead, I think you will have to implement
putting the * on there yourself. The recommended way to do it is to
call setPartName() and let the framework handle displaying whether it is
dirty or not.
> by my own?
Re: HowTo: EditorPages isDirty() and markDirty() [message #466073 is a reply to message #466058] Fri, 13 April 2007 04:44 Go to previous messageGo to next message
You're right, it works but the * is only shown after I selected another
editor and switch back to former one. So I have to call a refresh-method
on my editor-view in the setDirty-method somehow. Do you know how?
Thanks again
-- Marc
> the title.
> dirty or not.
>> by my own?
Re: HowTo: EditorPages isDirty() and markDirty() [message #466107 is a reply to message #466073] Fri, 13 April 2007 19:48 Go to previous messageGo to next message
I've never had to do that. I just checked to make sure and as soon as I
call firePropertyChange(PROP_DIRTY), the * is added on there. Sorry I
don't have any other ideas off the top of my head.
Re: HowTo: EditorPages isDirty() and markDirty() [message #466117 is a reply to message #466107] Sat, 14 April 2007 05:31 Go to previous message
Ok, now it is working. First I modified you version as I marked the
registered FormPages dirty which was wrong but I thought the
isDirty-implementation of FormEditor is better. If I set the dirty state
NOT in the FormPages but only in my editor its working the way it should.
-- Marc
Previous Topic:RCP and SWT: how does it work
Next Topic:Help button on Macintosh laptops
Current Time: Wed Nov 05 19:01:34 EST 2025
Powered by FUDForum. Page generated in 0.05979 seconds
