| JNI in RCP [message #465604] | Tue, 03 April 2007 01:40  |  |
| Eclipse User  |  |  |  |  | Hi,
 I have a problem with loading some DLL files in my RCP application.
 My RCP application contains several different plugins. One of them uses JNI
 and depends on several DLL files. When I run the product from Eclipse IDE
 everything works fine with modifying the java.library.path-value in the
 launch configuration and adding the dll files to the PATH variable in the
 project properties.
 But when I export my product I get several problems:
 - How to add the java.library.path-value to the config.ini without needing
 the absolute path of the DLL location???
 - How to add the path of the DLL location to System-variable PATH without
 having to start Eclipse via a .bat file???
 Please excuse my fragmentary knowledge of JNI, my task is to combine the RCP
 application with the classes using JNI.
 Thanks in advance!
 Greetz,
 Carsten
FUDForum. Page generated in 0.04379 seconds
