Exception in thread "main" java.lang.NoClassDefFoundError: org/eclipse/swt/widgets/Display [message #465546] |
Wed, 14 December 2005 20:56  |
Originally posted by: invalid.invalid.invalid
I have a problem with starting my SWT application from a jar file
under Windows XP. In Eclipse everything works fine. But when I
run the jar file I get this error:
I have copied swt.jar and swt-win32-3064.dll to the jars
directory. And I have added the swt.jar to the manifest file.
I tried this when I started with my project and it worked. Now I
get the above error.
Nick
Re: Exception in thread "main" java.lang.NoClassDefFoundError: org/eclipse/swt/widgets/Dis [message #465609 is a reply to message #465591] |
Thu, 15 December 2005 14:57  |
Thank you, I have found the error. The manifest file was wrong.
I separated the jars with a ',' and not with a space.
With "Class-Path: swt.jar, jdom.jar" only jdom.jar was used. With
"Class-Path: swt.jar jdom.jar" everything works fine.
Thanks again,
Nick
Stefan Langer wrote:
> Have you tried starting your application using jar in the classpath and
> specifiing the startup class manually? Do you get the same result?
> Regards
> Stefan
>>>>Yes, I started with
>>>>java -Djava.lirary.path="D:\path_to_dll_and_jars" -jar myjar.jar
>>>Hope this is just a cut & paste error but you spelled -Djava.lirary not
>>>-Djava.library
>> Yes, it is just a cut&paste error. It was on two lines. Sorry.
FUDForum. Page generated in 0.03561 seconds
