Running SWT application outside Eclipse [message #464564] |
Thu, 24 November 2005 22:15 |
Originally posted by: mwilli.iastate.edu
I'm trying to create a redistributable jar file for an application I am
working on. The application uses SWT for the grapical interface. I am able
to run the jar file using the java -classpath
swt.jar;helloworld.jar -Djava.library.path="C:\SWT" helloworld command-line
parameters, but when the application starts, I don't get any text on the
buttons, I don't get any text in a list, and I don't get any images or text
on CLabels that are part of a sub-class of composite. The program works fine
within Eclipse. Any ideas of how to get this to work outside of eclipse?
P.S. The library is complete.
Re: Running SWT application outside Eclipse [message #464570 is a reply to message #464568] |
Fri, 25 November 2005 02:05 |
>> command-line parameters, but when the application starts, I don't get any
>> text on the buttons, I don't get any text in a list, and I don't get any
>> images or text on CLabels that are part of a sub-class of composite. The
>> program works fine within Eclipse. Any ideas of how to get this to work
>> outside of eclipse? P.S. The library is complete.
> you use any i18n text and images from swt plugin, probably
> this text/images isn't in swt.jar - you have to find where they are
I can't even get just text to display on a regular button though. How
could that not be a part of swt.jar? This is on the windows platform by
the way.
Re: Running SWT application outside Eclipse [message #464572 is a reply to message #464570] |
Fri, 25 November 2005 02:30 |
>>> able
>>> any
> the way.
Nevermind. I read a post from earlier that solved my problem. Running
with javaw.exe instead of java.exe solved my problem.
FUDForum. Page generated in 0.03330 seconds
