problem with forms [message #464496] |
Wed, 23 November 2005 13:59 |
Carmelo Messages: 224 Registered: July 2009 |
Hi all
hope this is the right forum to talk about that ....
i'm having problem with my example using forms ...
here is a little example ...
if you try the little bit it looks working fine ...
now if you remove from the stringbuffer all the "here" word (leave just one)
you can see that the size of the section has big enough to keep paint the
"create" word.
the description information (ie: Creates a command) will be splitted in two
rows :-(
i'm a doing something wrong?
i have tried even to use section .setLayoutData(new
TableWrapData(TableWrapData.FILL));
force in the main container a grid layout with fill both property ... but
still no luck ?
Ciao
Kar
Section section = toolkit.createSection(form.getBody(), Section.DESCRIPTION
Section.TITLE_BAR | Section.EXPANDED);
section.setText("create");
toolkit.createCompositeSeparator(section);
section.setDescription("Creates a command.");
StringBuffer buf = new StringBuffer();
buf.append("<form>");
buf.append("<p>");
buf.append("Here Here Here Here Here Here Here Here Here Here Here ");
buf.append("</p>");
buf.append("</form>");
FormText rtext = toolkit.createFormText(section, true);
rtext.setFont("header", JFaceResources.getHeaderFont());
rtext.setText(buf.toString(), true, false);
rtext.addHyperlinkListener(new HyperlinkAdapter() {
public void linkActivated(HyperlinkEvent e) {
System.out.println("Link active: "+e.getHref());
section.setClient(rtext);
FUDForum. Page generated in 0.03187 seconds
