| Problem with the Selection Service [message #464456] |
Wed, 07 March 2007 09:59  |
Originally posted by: fe.cetic.be
In a RCP application, I want to trigger an action in a (target) view
when a selection is made in the TableViewer another (source) view.
Here is (the skeleton of) my source view :
public class ResultsView extends ViewPart {
private TableViewer resultsViewer;
public void createPartControl(Composite parent) {
resultsViewer = new TableViewer(parent, SWT.MULTI | SWT.H_SCROLL |
SWT.V_SCROLL);
resultsViewer.setContentProvider(new ViewContentProvider());
resultsViewer.setLabelProvider(new ViewLabelProvider());
getSite().setSelectionProvider(resultsViewer);
Here is (the skeleton of) my target view :
public class DocumentView extends ViewPart implements ISelectionListener {
getSite().getWorkbenchWindow().getSelectionService().addSele ctionListener(this);
public void selectionChanged(IWorkbenchPart part, ISelection selection) {
System.out.println("OK");
....but "OK" does not display
What's wrong ? Do I have to use a ISelectionChangedListener ? (what's
the difference with a ISelectionListener ?)
Thanks for this useful newsgroup,
Fabrice
| Re: Problem with the Selection Service [message #464484 is a reply to message #464480] |
Thu, 08 March 2007 11:20  |
>> SWT.H_SCROLL | SWT.V_SCROLL);
>> selection) {
> I guess you forgot to call the super method in the derived
> createPartControl method.
> Btw: You should also call
> getSite().getWorkbenchWindow().getSelectionService().removeS electionListener(this);
> in your dispose() function.
> Greetings from Bremen,
> Daniel Krügler
Hello and thanks for your suggestion, but still coping with my problem.
I have tried to embbed the action to trigger in an "Action" rather than
in a "View" :
public class ShowDocumentAction extends Action implements
ISelectionListener, IWorkbenchAction {
private final static String ID = "actions.showdocument";
private final IWorkbenchWindow window;
public ShowDocumentAction(IWorkbenchWindow window)
this.window = window;
setId(ID);
window.getSelectionService().addSelectionListener(this);
System.out.println("OK-changed");
public void run()
System.out.println("OK-run");
public void dispose() {
window.getSelectionService().removeSelectionListener(this);
....but without success :-(
Fabrice
FUDForum. Page generated in 0.03522 seconds
