Re: Using SWT to create an advanced ListView type control [message #464353 is a reply to message #464352] |
Mon, 21 November 2005 23:18 |
Originally posted by: Vincent.Black.evhr.net
Hello, i have not exactly an idea for this, but i can give you a
interressant link :
www.swtplus.com/
It is several component derivated from the canvas class of swt and i
think that an exemple of list that you describe is present.
The code is free and downloadable.
I hope that is will be help you.
Good night !
Vinz
Joseph a écrit :
> Hi all,
> I'm looking to make something with similar functionality to that seen
> when you are viewing your inbox in Pocket Outlook.
> The items are listed something like this:
> Item 1 title Field1 Field2
> more details (A field that spans the entire column..
> Item 2 title Field1 Field2
> more details........................................
> etc.
> Any idea where I should start? I was thinking that maybe using Table and
> extending TableItem might be a good start.. but then i read that
> TableItem is not intended to be subclassed..
> Does anyone have a suggestion on where to start to build such a control
> or any idea where I can find a similar open source control for SWT?
> Thanks in advance,
> Joe
Re: Using SWT to create an advanced ListView type control [message #464375 is a reply to message #464355] |
Tue, 22 November 2005 09:38 |
Originally posted by: friederich.kupzog.de
This is what KTable was written for. See
http://sourceforge.net/projects/ktable
Friederich
Joseph Rignanese wrote:
> Thanks for the reply,
> Unfortunately it didn't help. I guess a better way to describe what i'm
> looking for is a table that allows for table item that can span multiple
> columns of a table (without separating) and can be separated over multiple
> rows.
> ie.
> A single table item can be split over 2 lines and three columns as follows:
> Col1 Col2
> Col3
> TableItem1 string1 string2
> string3
> string4whichisaverylongstringandiwanttocoverall3columns
> end of TableItem1
> TableItem2...etc
> Any ideas?
> "Vinz" <Vincent.Black@evhr.net> wrote in message
> news:dltkjq$ntp$1@news.eclipse.org...
>>interressant link :
>>www.swtplus.com/
>>It is several component derivated from the canvas class of swt and i think
>>Good night !
>>Vinz
>>Joseph a écrit :
>>>Hi all,
>>>etc.
>>>Thanks in advance,
>>>Joe
Friederich Kupzog
Elektronik & Software
Neusser Str. 5-7
50670 Köln
Tel 0241 160696-1
Fax 0221 726670
www.kupzog.de/fkmk
FUDForum. Page generated in 0.03752 seconds
