doubts about draw2d [message #464343] |
Mon, 21 November 2005 20:40 |
Originally posted by: hdsn82.yahoo.com.br
When I execute the code bellow, if I minimize the window run the figure
dissappear...Do you guys know why is it happen? What code changes should I
do in this case?
Thanks a bunch!
import java.awt.Color;
import org.eclipse.draw2d.ChopboxAnchor;
import org.eclipse.draw2d.Figure;
import org.eclipse.draw2d.LightweightSystem;
import org.eclipse.draw2d.PolygonDecoration;
import org.eclipse.draw2d.PolylineConnection;
import org.eclipse.draw2d.XYLayout;
import org.eclipse.draw2d.geometry.PointList;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.GC;
import org.eclipse.swt.widgets.Canvas;
import org.eclipse.swt.widgets.Shell;
public class DrawExample {
Display display = new Display();
Shell shell = new Shell(display);
shell.setText("Drawing Example");
Canvas canvas = new Canvas(shell, SWT.NULL);
canvas.setSize(600, 400); //espaço interno onde está inserido o desenho
canvas.setLocation(-40, -30);
//canvas.addPaintListener(this);
canvas.setVisible(true);
shell.open();
shell.setSize(600, 400); //tamanho da tela que contém o desenho
GC gc = new GC(canvas);
gc.drawArc(200,156,150,130,180, -180);
//3º - largura da elipse,
//4º - altura da elipse
gc.drawArc(200,156,150,130,-180, 180);
gc.drawText("lk;fasjdfl;sda", 220,190);
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.getCurrent().dispose();
Re: doubts about draw2d [message #464347 is a reply to message #464343] |
Mon, 21 November 2005 21:05 |
Originally posted by: sunil_kamath.nohotspammail.com
> figure dissappear...Do you guys know why is it happen? What code
> changes should I do in this case?
> Thanks a bunch!
[snip]
Ask this question in the GEF newsgroup. news:eclipse.tools.gef
Sunil
Re: doubts about draw2d [message #464372 is a reply to message #464343] |
Tue, 22 November 2005 09:21 |
Originally posted by: friederich.kupzog.de
As far as I can see you need to put your drawing code into a paint
listener otherwise it will only be executed once.
Friederich
> I do in this case?
> Thanks a bunch!
> import org.eclipse.swt.widgets.Display;
> public static void main(String[] args) {
> shell.open();
> //4º - altura da elipse gc.drawArc(200,156,150,130,-180, 180);
> display.sleep();
Friederich Kupzog
Elektronik & Software
Neusser Str. 5-7
50670 Köln
Tel 0241 160696-1
Fax 0221 726670
www.kupzog.de/fkmk
FUDForum. Page generated in 0.02915 seconds
