Access restriction: The type <type> is not accessible ... [message #464277] |
Thu, 01 March 2007 08:58  |
Originally posted by: nagel.trium.de
Hi all,
I get error messages of the form "Access restriction: The type <type> is
not accessible due to restriction on required project <project>", although
all packages of the <project> are exported. I get no such error messages
in comparable situations, adressing types of other plug-ins.
Have you any idea, what the reason could be?
Lars
Re: Access restriction: The type <type> is not accessible ... [message #464293 is a reply to message #464285] |
Thu, 01 March 2007 11:59   |
Andrew Niefer wrote:
> Is the required <project> listed in your Manifest.mf Require-Bundle header?
(or
> Import-Package).
Yes, it is listed in it. The project is de.dimd.ctk.util.
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Permissionhandler Plug-in
Bundle-SymbolicName: de.dimdi.ctk.permissionhandler;singleton:=true
Bundle-Version: 1.0.0
Bundle-Activator: de.dimdi.ctk.permissionhandler.PermissionHandlerPlugin
Bundle-Localization: plugin
Require-Bundle: org.eclipse.ui,
org.eclipse.core.runtime,
de.dimdi.ctk.dbconnector,
org.eclipse.jface.text,
de.dimdi.ctk.util
Eclipse-LazyStart: true
Export-Package: de.dimdi.ctk.permissionhandler,
de.dimdi.ctk.permissionhandler.control
Bundle-ClassPath: library.jar
> Lars Nagel wrote:
>> Hi all,
>> although all packages of the <project> are exported. I get no such error
>> messages in comparable situations, adressing types of other plug-ins.
>> Thanks,
>> Lars
Re: Access restriction: The type <type> is not accessible ... [message #464299 is a reply to message #464293] |
Thu, 01 March 2007 12:48   |
If the de.dimdi.ctk.util plug-in is one that you wrote check the open
the manifest editor for that plug-in and make sure you are exporting the
package for the type you are trying to use. The package exports are
listed under the runtime tab of the editor.
>> header?
> (or
>> Import-Package).
> de.dimdi.ctk.util
>> Lars Nagel wrote:
>>> Hi all,
>>> is not accessible due to restriction on required project <project>",
>>> error messages in comparable situations, adressing types of other
>>> plug-ins.
>>> Thanks,
>>> Lars
Re: Access restriction: The type <type> is not accessible ... [message #464303 is a reply to message #464299] |
Thu, 01 March 2007 15:12  |
As I wrote, I export all packages. And other plug-ins have no problem to
access the type.
>>> header?
>> (or
>>> Import-Package).
>> de.dimdi.ctk.util
>>> Lars Nagel wrote:
>>>> Hi all,
>>>> plug-ins.
>>>> Thanks,
>>>> Lars
FUDForum. Page generated in 0.26064 seconds
