JFace outside eclipse still needs eclipse core runtime? [message #463896] |
Tue, 15 November 2005 15:51 |
Originally posted by: brigitte.ilsanker.gi-de.com
I'm trying to develop a standalone application, which should be a wizard
that users can use as a GUI without using Eclipse.
I understand from the documentation and from the article
"Developing JFace wizards Using the JFace toolkit" by Jeff Gunter found at
the IBM site
http://www-128.ibm.com/developerworks/java/library/os-ecjfw
that this should be possible.
Now I try to run the example provided at that site with the following
Error:
java.lang.NoClassDefFoundError: org/eclipse/core/runtime/IProgressMonitor
This sounds to me, that I do need eclipse core runtime classes. Is that
true?
Or do I simply use an outdated example and should change to newer
resources? If so, where to find it (I searched the eclipse site already
and even IBM's).
Bridget
FUDForum. Page generated in 0.05560 seconds
