Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Shift-Tab + Key Listeners
| Shift-Tab + Key Listeners [message #463580] |
Wed, 09 November 2005 11:54  |
Hello.
I've experienced a problem with Shift+Tab when working with custom widgets
that extend Composite and that have a key listener (using either addListener
or addKeyListener) attached. For example: Let's say I have a custom widget
and a button. When I start the application, the focus goes to the custom
widget. If I press Tab, focus goes to the button. If I press Tab again, the
focus goes back to the custom widget, as it should.
However, if I press "Shift+Tab", and the focus is in on the custom widget,
the focus does not go back to the button. If I click on the button, then
press Shift+Tab, focus returns to the custom widget, as it should. Of
course, pressing Shift+Tab again does nothing. The traversal event does
fire, though. Attached is a code sample to demonstrate this problem. Any
help would be greatly appreciated.
Also, if I remove the key listener from the custom widget, Shift+Tab works
(lines 104-109 in sample) . This, however, is not a possiblilty because we
need to add key listeners to our widgets.
Scott
| Re: Shift-Tab + Key Listeners [message #463602 is a reply to message #463580] |
Thu, 10 November 2005 11:14   |
CAn you paste in the code? My stupid mailer has removed your attachment.
"Scott Myron" <samyron@gmail.com> wrote in message
news:dkt9kf$s7h$1@news.eclipse.org...
> Hello.
addListener
the
> Scott
| Re: Shift-Tab + Key Listeners [message #463603 is a reply to message #463602] |
Thu, 10 November 2005 11:24   |
Sure. Here is the code:
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.layout.RowLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Event;
import org.eclipse.swt.widgets.Listener;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Text;
class ExtendedText extends Composite
private Composite parent;
private Text text;
private Listener defaultListener = new Listener() {
public void handleEvent(Event event)
switch(event.type) {
case SWT.KeyUp:
case SWT.KeyDown:
Event newEvent = new Event();
newEvent.type = event.type;
newEvent.keyCode = event.keyCode;
newEvent.character = event.character;
newEvent.stateMask = event.stateMask;
newEvent.doit = event.doit;
ExtendedText.this.notifyListeners(event.type, newEvent);
break;
case SWT.Traverse:
event.doit = true;
ExtendedText.this.notifyListeners(event.type, event);
break;
public ExtendedText(Composite parent, int style)
super(parent, SWT.NONE);
this.parent = parent;
setLayout(new FillLayout());
text = new Text(this, style);
text.addListener(SWT.KeyDown, defaultListener);
text.addListener(SWT.KeyUp, defaultListener);
text.addListener(SWT.Traverse, defaultListener);
public String getText()
return text.getText();
public void setText(String str)
text.setText(str);
public boolean forceFocus()
return text.forceFocus();
public boolean setFocus()
return text.setFocus();
public class TestTabBug
private Display display;
private Shell shell;
public TestTabBug()
display = new Display();
shell = new Shell(display);
shell.setLayout(new RowLayout(SWT.HORIZONTAL));
createControls();
public void run()
shell.pack();
shell.open();
while (!shell.isDisposed())
if (!display.readAndDispatch())
display.sleep();
display.dispose();
public void createControls()
ExtendedText text = new ExtendedText(shell, SWT.BORDER);
text.addListener(SWT.KeyDown, new Listener() {
System.out.println("Key Down: " + event);
text.addListener(SWT.Traverse, new Listener(){
System.out.println("Traverse event in parent: " + event);
event.doit = true;
Button button = new Button(shell, SWT.PUSH);
button.setText("Push me");
public static void main(String[] args)
new TestTabBug().run();
"Steve Northover" <steve_northover@ca.ibm.com> wrote in message
news:dkvrln$b1b$1@news.eclipse.org...
>> Hello.
>> widgets
> addListener
>> widget
> the
>> widget,
>> works
>> we
>> Thanks,
>> Scott
| Re: Shift-Tab + Key Listeners [message #463611 is a reply to message #463580] |
Thu, 10 November 2005 12:37   |
What is happening is that by adding a key listener to ExtendedText, it is
assumed that ExtendedText can take keyboard focus and it is therefore
included in the tab order. When you Shift+Tab, you are going backwards in
tab order and the ExtendedText composite is the previous guy in the tab
order so it is taking focus. However, you overrode setFocus() so focus is
being forced back to the Text widget inside.
I have modified your code below so that it will work. Note that this is
required because Text is the first child of ExtendedText. If you have
multiple children, you would only need this for the first child.
class ExtendedText extends Composite {
private Text text;
case SWT.KeyUp:
case SWT.KeyDown:
newEvent);
break;
case SWT.Traverse:
event.doit = true;
event);
break;
text.addListener(SWT.Traverse, new Listener() {
public void handleEvent(Event event) {
if (event.detail ==
SWT.TRAVERSE_TAB_PREVIOUS) {
ExtendedText.this.traverse(event.detail);
event.detail = SWT.TRAVERSE_NONE;
event.doit = true;
this.addListener(SWT.FocusIn, new Listener() {
public void handleEvent(Event e) {
text.setFocus();
text.setText(str);
// DO NOT override these guys
// public boolean forceFocus()
// return text.forceFocus();
// public boolean setFocus()
// return text.setFocus();
| Re: Shift-Tab + Key Listeners [message #463617 is a reply to message #463611] |
Thu, 10 November 2005 14:47  |
Thank you very much!
Scott
"Veronika Irvine" <veronika_irvine@oti.com> wrote in message
news:dl00fu$jjj$1@news.eclipse.org...
> private Text text;
> case SWT.KeyUp:
> case SWT.KeyDown:
> break;
> case SWT.Traverse:
> event.doit = true;
> break;
> if (event.detail ==
> event.doit = true;
> text.setFocus();
> text.setText(str);
Current Time: Sat Nov 01 16:28:39 EDT 2025
Powered by FUDForum. Page generated in 0.29156 seconds
