| Home » Eclipse Projects » Rich Client Platform (RCP) » logger starting
 Goto Forum:|
| logger starting [message #463441] | Mon, 12 February 2007 08:03  |  |
| Eclipse User  |  |  |  |  | Originally posted by: peter_ossipov.mail.ru
 Hello everybody!
 I am using log4j for logging. Quite nice. the problem is that I cannot
 figure out where to initialize the logger. I am thinking of putting it into:
 org.eclipse.ui.plugin.AbstractUIPlugin#start(org.osgi.framew ork.BundleContext)
 but not sure. It seems that logger should start as soon as possible, but
 when start method is called, I can see that some threads are already
 working which means that if something goes wrong before I initialize the
 log4j library, those errors will not be logged.
 Thanks very much in advance for your support, folks!
| Re: logger starting [message #463457 is a reply to message #463451] | Mon, 12 February 2007 09:15   |  |
 <html>
 <head>
 </head>
 Hi Tom!<br>
 Well, I did read it. So, what are you saying? I just did not understand
 all the bits in your reply to my post:<br>
 <pre wrap=""><i>first 2nd thing</i></pre>
 How should I  understand that one? <span class="moz-smiley-s7"><span>
 :-\ </span></span><br>
 Tom Schindl wrote:
 <blockquote cite="mideqpr7n$n4t$1@utils.eclipse.org" type="cite">
 <pre wrap="">Hi,
 start is the first 2nd thing called (after the constructor) when you
 have set the LazyStart-bit in MANIFEST. Even getDefault() will fail in
 other cases see my thread about BundleActivation from today ;-)
 Tom
 Peter Osipov schrieb:
 </pre>
 <blockquote type="cite">
 <pre wrap="">Hello Stefan.
 It seems that ILog might be an alternative. Do you know any articles
 (pros and cons) for eclipse logging system?
 Stefan Zugal wrote:
 </pre>
 <pre wrap="">Hi,
 I think the start() method should be the first method called when your
 plugin is loaded (although I'm not quite sure ...).
 Alternatively, you could use the logging system provided by Eclipse:
 MyPlugin.getDefault().getLog()
 HTH,
 Stefan
 </pre>
 <pre wrap="">Hello everybody!
 cannot figure out where to initialize the logger. I am thinking of
 putting it into:
 but when start method is called, I can see that some threads are
 already working which means that if something goes wrong before I
 initialize the log4j library, those errors will not be logged.
 </pre>
 </blockquote>
 </blockquote>
 </blockquote>
 </blockquote>
 <br>
 </body>
 </html>
| Re: logger starting [message #463459 is a reply to message #463457] | Mon, 12 February 2007 09:22   |  |
| Eclipse User  |  |  |  |  | Peter Osipov schrieb: > Hi Tom!
 > Well, I did read it. So, what are you saying? I just did not understand all the
 > /first 2nd thing/
 Sorry the process is the following:
 1. Constructor is called of Activator defined in MANIFEST is called
 2. Start is called of this Activator
 3. Class loaded, instantiated, method called
 4. ...
 The key is that start() is the first method in your plugin which is
 called before any other code runs (under the assumption that your
 MANIFEST holds "Eclipse-LazyStart: true").
 Tom
 > How should I  understand that one? :-\
 > Tom Schindl wrote:
 >> Tom
 >>> Hello Stefan.
 >>> Stefan Zugal wrote:
 >>>> Hi,
 >>>> HTH,
 >>>> Stefan
 >>>>> Hello everybody!
 >>>>> putting it into:
| Re: logger starting [message #463461 is a reply to message #463459] | Mon, 12 February 2007 09:27   |  |
 Okay, now it is clear. Thanks Tom! 8-)
 Well, so I should put that logger initialization in start method, eh?
 In that case I am not logging the situation when the application does
 not start(more precisely - the "initializing" bundle is not started) for
 some reason, which I want to log, as well, actually. If that is
 possible, of course.
 >> Hi Tom!
 >> understand all the bits in your reply to my post:
 >> /first 2nd thing/
 > 4. ...
 > Tom
 >> Tom Schindl wrote:
 >>> Hi,
 >>> Tom
 >>>> Hello Stefan.
 >>>> Stefan Zugal wrote:
 >>>>> Hi,
 >>>>> your
 >>>>> HTH,
 >>>>> Stefan
 >>>>>> Hello everybody!
 >>>>>> putting it into:
| Re: logger starting [message #463465 is a reply to message #463461] | Mon, 12 February 2007 09:41   |  |
| Eclipse User  |  |  |  |  | Hi,
 Well that's nothing you could do in your own plugin. I don't have a clue
 if this could be done but I think you'll always have to same problem
 that if you want to inject custom code if the loading of it fails you
 can't intercept this (the platform of course logs into the log-file).
 If the chicken is behead before it could lay the egg, the egg is out of
 luck ;-) Sorry for the rude analogy.
 Tom
 >>> Hi Tom!
 >>> /first 2nd thing/
 >> 4. ...
 >> Tom
 >>> Tom Schindl wrote:
 >>>> Hi,
 >>>> Tom
 >>>>> Hello Stefan.
 >>>>> Stefan Zugal wrote:
 >>>>>> Hi,
 >>>>>> your
 >>>>>> HTH,
 >>>>>> Stefan
 >>>>>>> Hello everybody!
 >>>>>>> putting it into:
| Re: logger starting [message #463467 is a reply to message #463465] | Mon, 12 February 2007 10:00   |  |
 Thanks, Tom.  :-) Yep, there will always be a problem when integrating.
 Well, if platform logs that into the log-file, where can I find the one
 in the situation, when log4j was not able to intercept the error event?
 Tom Schindl wrote:
 > clue if this could be done but I think you'll always have to same
 > problem that if you want to inject custom code if the loading of it
 > fails you can't intercept this (the platform of course logs into the
 > log-file).
 > of luck ;-) Sorry for the rude analogy.
 > Tom
 >> for some reason, which I want to log, as well, actually. If that is
 >>>> Hi Tom!
 >>>> /first 2nd thing/
 >>> 4. ...
 >>> Tom
 >>>> Tom Schindl wrote:
 >>>>> Hi,
 >>>>> fail in
 >>>>> Tom
 >>>>>> Hello Stefan.
 >>>>>> Stefan Zugal wrote:
 >>>>>>> Hi,
 >>>>>>> when your
 >>>>>>> Eclipse:
 >>>>>>> HTH,
 >>>>>>> Stefan
 >>>>>>>> Hello everybody!
 >>>>>>>> putting it into:
 >>>>>>>> possible,
| Re: logger starting [message #463469 is a reply to message #463467] | Mon, 12 February 2007 10:03   |  |
| Eclipse User  |  |  |  |  | Platform always logs into workspace/.metadata/.log
 by the what you really want to to have a generic logger services. Make
 sure you read this article at eclipsezone.
 http://www.eclipsezone.com/articles/extensions-vs-services/
 Tom
 > Tom Schindl wrote:
 >> log-file).
 >> Tom
 >>>>> Hi Tom!
 >>>>> /first 2nd thing/
 >>>> 4. ...
 >>>> Tom
 >>>>> Tom Schindl wrote:
 >>>>>> Hi,
 >>>>>> fail in
 >>>>>> Tom
 >>>>>>> Hello Stefan.
 >>>>>>> Stefan Zugal wrote:
 >>>>>>>> Hi,
 >>>>>>>> when your
 >>>>>>>> Eclipse:
 >>>>>>>> HTH,
 >>>>>>>> Stefan
 >>>>>>>>> Hello everybody!
 >>>>>>>>> putting it into:
 >>>>>>>>> possible,
| Re: logger starting [message #463471 is a reply to message #463469] | Mon, 12 February 2007 10:03   |  |
 Okay, Tom. Let me go and read that article. Thanks so much for your
 help! 8-)
 > Tom
 >> one in the situation, when log4j was not able to intercept the error
 >> event?
 >> Tom Schindl wrote:
 >>> Hi,
 >>> log-file).
 >>> Tom
 >>>> does not start(more precisely - the "initializing" bundle is not
 >>>> started) for some reason, which I want to log, as well, actually.
 >>>> If that is possible, of course.
 >>>>>> Hi Tom!
 >>>>>> /first 2nd thing/
 >>>>> 4. ...
 >>>>> is called before any other code runs (under the assumption that
 >>>>> your MANIFEST holds "Eclipse-LazyStart: true").
 >>>>> Tom
 >>>>>> Tom Schindl wrote:
 >>>>>>> Hi,
 >>>>>>> you
 >>>>>>> fail in
 >>>>>>> Tom
 >>>>>>>> Hello Stefan.
 >>>>>>>> articles
 >>>>>>>> Stefan Zugal wrote:
 >>>>>>>>> Hi,
 >>>>>>>>> when your
 >>>>>>>>> Eclipse:
 >>>>>>>>> HTH,
 >>>>>>>>> Stefan
 >>>>>>>>>> Hello everybody!
 >>>>>>>>>> thinking of
 >>>>>>>>>> putting it into:
 >>>>>>>>>> possible,
 >>>>>>>>>> before I
| Re: logger starting [message #463473 is a reply to message #463469] | Mon, 12 February 2007 10:11   |  |
 I am reading the article right now. It is just that it does not have
 anything about logger services, eh?
 > Tom
 >> event?
 >> Tom Schindl wrote:
 >>> Hi,
 >>> log-file).
 >>> Tom
 >>>>>> Hi Tom!
 >>>>>> /first 2nd thing/
 >>>>> 4. ...
 >>>>> Tom
 >>>>>> Tom Schindl wrote:
 >>>>>>> Hi,
 >>>>>>> you
 >>>>>>> fail in
 >>>>>>> Tom
 >>>>>>>> Hello Stefan.
 >>>>>>>> articles
 >>>>>>>> Stefan Zugal wrote:
 >>>>>>>>> Hi,
 >>>>>>>>> when your
 >>>>>>>>> Eclipse:
 >>>>>>>>> HTH,
 >>>>>>>>> Stefan
 >>>>>>>>>> Hello everybody!
 >>>>>>>>>> thinking of
 >>>>>>>>>> putting it into:
 >>>>>>>>>> possible,
 >>>>>>>>>> before I
| Re: logger starting [message #463474 is a reply to message #463473] | Mon, 12 February 2007 10:38   |  |
 well but that's exactly what you need you need a central plugin started
 up very early which configures log4j and provides possibilities to other
 plugins to log. Not every plugin configures its own logger but they are
 all loging through one central Log-Service. I only wanted to point you
 to this article to get familiar how you could create your log-service.
 Which looks similar to the ILog-Service provided by eclipse. I think you
 can inject your own log-service into eclipse maybe this article provides
 pointers how to that:
 http://eclipsezone.com/articles/franey-logging/?source=archi ves
 Tom
 >> Tom
 >>> event?
 >>> Tom Schindl wrote:
 >>>> Hi,
 >>>> log-file).
 >>>> Tom
 >>>>>>> Hi Tom!
 >>>>>>> /first 2nd thing/
 >>>>>> 4. ...
 >>>>>> Tom
 >>>>>>> Tom Schindl wrote:
 >>>>>>>> Hi,
 >>>>>>>> you
 >>>>>>>> fail in
 >>>>>>>> Tom
 >>>>>>>>> Hello Stefan.
 >>>>>>>>> articles
 >>>>>>>>> Stefan Zugal wrote:
 >>>>>>>>>> Hi,
 >>>>>>>>>> when your
 >>>>>>>>>> Eclipse:
 >>>>>>>>>> HTH,
 >>>>>>>>>> Stefan
 >>>>>>>>>>> Hello everybody!
 >>>>>>>>>>> thinking of
 >>>>>>>>>>> putting it into:
 >>>>>>>>>>> possible,
 >>>>>>>>>>> before I
| Re: logger starting [message #463476 is a reply to message #463474] | Mon, 12 February 2007 10:39   |  |
 Huh, Tom. It seems like you are splitting the hair. But, nevertheless, I
 am with you. Thanks so much for it! You are star. I am telling you. 8-)
 Tom Schindl wrote:
 > started up very early which configures log4j and provides
 > possibilities to other plugins to log. Not every plugin configures its
 > own logger but they are all loging through one central Log-Service. I
 > only wanted to point you to this article to get familiar how you could
 > create your log-service. Which looks similar to the ILog-Service
 > provided by eclipse. I think you can inject your own log-service into
 > eclipse maybe this article provides pointers how to that:
 > Tom
 >>> Make sure you read this article at eclipsezone.
 >>> Tom
 >>>> integrating.
 >>>> error event?
 >>>> Tom Schindl wrote:
 >>>>> Hi,
 >>>>> a clue if this could be done but I think you'll always have to
 >>>>> same problem that if you want to inject custom code if the loading
 >>>>> of it fails you can't intercept this (the platform of course logs
 >>>>> into the log-file).
 >>>>> out of luck ;-) Sorry for the rude analogy.
 >>>>> Tom
 >>>>>> eh?
 >>>>>>>> Hi Tom!
 >>>>>>>> /first 2nd thing/
 >>>>>>> 4. ...
 >>>>>>> Tom
 >>>>>>>> Tom Schindl wrote:
 >>>>>>>>> Hi,
 >>>>>>>>> when you
 >>>>>>>>> fail in
 >>>>>>>>> Tom
 >>>>>>>>>> Hello Stefan.
 >>>>>>>>>> articles
 >>>>>>>>>> Stefan Zugal wrote:
 >>>>>>>>>>> Hi,
 >>>>>>>>>>> when your
 >>>>>>>>>>> Eclipse:
 >>>>>>>>>>> HTH,
 >>>>>>>>>>> Stefan
 >>>>>>>>>>>> Hello everybody!
 >>>>>>>>>>>> that I
 >>>>>>>>>>>> thinking of
 >>>>>>>>>>>> putting it into:
 >>>>>>>>>>>> possible,
 >>>>>>>>>>>> threads are
 >>>>>>>>>>>> before I
| Re: logger starting [message #463525 is a reply to message #463474] | Tue, 13 February 2007 05:59   |  |
 Hello Tom. I read the articles yesterday.
 They are really useful. But it does not give full details on hot to
 inject my own log-service. Do you have any other articles to read? :-)
 Tom Schindl wrote:
 > Tom
 >>> Tom
 >>>> integrating.
 >>>> error event?
 >>>> Tom Schindl wrote:
 >>>>> Hi,
 >>>>> into the log-file).
 >>>>> Tom
 >>>>>> eh?
 >>>>>>>> Hi Tom!
 >>>>>>>> /first 2nd thing/
 >>>>>>> 4. ...
 >>>>>>> Tom
 >>>>>>>> Tom Schindl wrote:
 >>>>>>>>> Hi,
 >>>>>>>>> when you
 >>>>>>>>> fail in
 >>>>>>>>> Tom
 >>>>>>>>>> Hello Stefan.
 >>>>>>>>>> articles
 >>>>>>>>>> Stefan Zugal wrote:
 >>>>>>>>>>> Hi,
 >>>>>>>>>>> when your
 >>>>>>>>>>> Eclipse:
 >>>>>>>>>>> HTH,
 >>>>>>>>>>> Stefan
 >>>>>>>>>>>> Hello everybody!
 >>>>>>>>>>>> that I
 >>>>>>>>>>>> thinking of
 >>>>>>>>>>>> putting it into:
 >>>>>>>>>>>> possible,
 >>>>>>>>>>>> threads are
 >>>>>>>>>>>> before I
| Re: logger starting [message #463528 is a reply to message #463525] | Tue, 13 February 2007 06:29   |  |
| Eclipse User  |  |  |  |  | Well if you ask me I'd do the following:
 I'd write dedicated plugin which does the logging via Log4J for me which
 i can require in any of my plugins and e.g. inject configuration using
 extension points. As you have discovered this doesn't resolve the
 problem when the Platform internally catches errors, ...  => so to also
 log those informations via log4j you simply register yourself as a
 Platform.addLogListener() and log those informations via log4j.
 The only question which remains is whether the Log4J-Plugin should allow
 logging directly or only over the ILog-API. Another thing I'm not sure
 whether it can be used is this new ErrorHandler-API introduce in 3.3
 ( https://bugs.eclipse.org/bugs/buglist.cgi?query_format=advan ced&short_desc_type=allwordssubstr&short_desc=%5BErr orHandling%5D&classification=Eclipse&product=Platfor m&target_milestone=3.3&target_milestone=3.3+M1&t arget_milestone=3.3+M2&target_milestone=3.3+M3&targe t_milestone=3.3+M4&target_milestone=3.3+M5&target_mi lestone=3.3+M6&long_desc_type=allwordssubstr&long_de sc=&bug_file_loc_type=allwordssubstr&bug_file_loc=&a mp;status_whiteboard_type=allwordssubstr&status_whiteboa rd=&keywords_type=allwords&keywords=&emailtype1= substring&email1=&emailtype2=substring&email2=&a mp;bugidtype=include&bug_id=&votes=&chfieldfrom= &chfieldto=Now&chfieldvalue=&cmdtype=doit&or der=Reuse+same+sort+as+last+time&field0-0-0=noop&typ e0-0-0=noop&value0-0-0=)
 The only thing you need to make sure is that Log4J plugin starts at the
 very beginning so that you receive all errors in the early stages. I
 think this can be done using the org.ui.startup-Extension point. But I'd
 certainly take a look at this status-handler API maybe it provides new
 possibilities to you e.g. (log to file, display error to user, ...).
 Tom
 > Tom Schindl wrote:
 >> Tom
 >>>> Tom
 >>>>> integrating.
 >>>>> error event?
 >>>>> Tom Schindl wrote:
 >>>>>> Hi,
 >>>>>> into the log-file).
 >>>>>> Tom
 >>>>>>> eh?
 >>>>>>>>> Hi Tom!
 >>>>>>>>> /first 2nd thing/
 >>>>>>>> 4. ...
 >>>>>>>> Tom
 >>>>>>>>> Tom Schindl wrote:
 >>>>>>>>>> Hi,
 >>>>>>>>>> when you
 >>>>>>>>>> fail in
 >>>>>>>>>> Tom
 >>>>>>>>>>> Hello Stefan.
 >>>>>>>>>>> articles
 >>>>>>>>>>> Stefan Zugal wrote:
 >>>>>>>>>>>> Hi,
 >>>>>>>>>>>> when your
 >>>>>>>>>>>> Eclipse:
 >>>>>>>>>>>> HTH,
 >>>>>>>>>>>> Stefan
 >>>>>>>>>>>>> Hello everybody!
 >>>>>>>>>>>>> that I
 >>>>>>>>>>>>> thinking of
 >>>>>>>>>>>>> putting it into:
 >>>>>>>>>>>>> possible,
 >>>>>>>>>>>>> threads are
 >>>>>>>>>>>>> before I
| Re: logger starting [message #463530 is a reply to message #463528] | Tue, 13 February 2007 07:08   |  |
 Thanks Tom very much for your answer.
 Well, org.ui.startup-Extension point is of no use.
 IStartup#earlyStartup() method is called according to this comment:
 "Will be called in a separate thread after the workbench initializes".
 So, it is a bit late to initialize the log4j there I think, because
 there might me errors during the workbench initialization process which
 I will not be able to catch. So, I still cannot figure out how to early
 start the log4j plug-in.
 Should I download eclipse 3.3 to explore all the new features added?
 > which i can require in any of my plugins and e.g. inject configuration
 > using extension points. As you have discovered this doesn't resolve
 > the problem when the Platform internally catches errors, ...  => so to
 > also log those informations via log4j you simply register yourself as
 > a Platform.addLogListener() and log those informations via log4j.
 > allow logging directly or only over the ILog-API. Another thing I'm
 > not sure whether it can be used is this new ErrorHandler-API introduce
 > in 3.3
 > the very beginning so that you receive all errors in the early stages.
 > I think this can be done using the org.ui.startup-Extension point. But
 > I'd certainly take a look at this status-handler API maybe it provides
 > new possibilities to you e.g. (log to file, display error to user, ...).
 > Tom
 >> Tom Schindl wrote:
 >>> Hi,
 >>> its own logger but they are all loging through one central
 >>> Log-Service. I only wanted to point you to this article to get
 >>> familiar how you could create your log-service. Which looks similar
 >>> to the ILog-Service provided by eclipse. I think you can inject your
 >>> own log-service into eclipse maybe this article provides pointers
 >>> how to that:
 >>> Tom
 >>>> have anything about logger services, eh?
 >>>>> Tom
 >>>>>> integrating.
 >>>>>> the one in the situation, when log4j was not able to intercept
 >>>>>> the error event?
 >>>>>> Tom Schindl wrote:
 >>>>>>> Hi,
 >>>>>>> have a clue if this could be done but I think you'll always have
 >>>>>>> to same problem that if you want to inject custom code if the
 >>>>>>> loading of it fails you can't intercept this (the platform of
 >>>>>>> Tom
 >>>>>>>> method, eh?
 >>>>>>>> application does not start(more precisely - the "initializing"
 >>>>>>>> bundle is not started) for some reason, which I want to log, as
 >>>>>>>> well, actually. If that is possible, of course.
 >>>>>>>>>> Hi Tom!
 >>>>>>>>>> /first 2nd thing/
 >>>>>>>>> called
 >>>>>>>>> 4. ...
 >>>>>>>>> which is called before any other code runs (under the
 >>>>>>>>> assumption that your MANIFEST holds "Eclipse-LazyStart: true").
 >>>>>>>>> Tom
 >>>>>>>>>> Tom Schindl wrote:
 >>>>>>>>>>> Hi,
 >>>>>>>>>>> when you
 >>>>>>>>>>> will fail in
 >>>>>>>>>>> Tom
 >>>>>>>>>>>> Hello Stefan.
 >>>>>>>>>>>> articles
 >>>>>>>>>>>> Stefan Zugal wrote:
 >>>>>>>>>>>>> Hi,
 >>>>>>>>>>>>> called when your
 >>>>>>>>>>>>> by Eclipse:
 >>>>>>>>>>>>> HTH,
 >>>>>>>>>>>>> Stefan
 >>>>>>>>>>>>>> Hello everybody!
 >>>>>>>>>>>>>> that I
 >>>>>>>>>>>>>> thinking of
 >>>>>>>>>>>>>> putting it into:
 >>>>>>>>>>>>>> as possible,
 >>>>>>>>>>>>>> threads are
 >>>>>>>>>>>>>> before I
 >>>>>>>>>>>>>> logged.
| Re: logger starting [message #463531 is a reply to message #463474] | Tue, 13 February 2007 07:09   |  |
 It just seems that there is not much documentation on services for now.
 Tom Schindl wrote:
 > Tom
 >>> Tom
 >>>> integrating.
 >>>> error event?
 >>>> Tom Schindl wrote:
 >>>>> Hi,
 >>>>> into the log-file).
 >>>>> Tom
 >>>>>> eh?
 >>>>>>>> Hi Tom!
 >>>>>>>> /first 2nd thing/
 >>>>>>> 4. ...
 >>>>>>> Tom
 >>>>>>>> Tom Schindl wrote:
 >>>>>>>>> Hi,
 >>>>>>>>> when you
 >>>>>>>>> fail in
 >>>>>>>>> Tom
 >>>>>>>>>> Hello Stefan.
 >>>>>>>>>> articles
 >>>>>>>>>> Stefan Zugal wrote:
 >>>>>>>>>>> Hi,
 >>>>>>>>>>> when your
 >>>>>>>>>>> Eclipse:
 >>>>>>>>>>> HTH,
 >>>>>>>>>>> Stefan
 >>>>>>>>>>>> Hello everybody!
 >>>>>>>>>>>> that I
 >>>>>>>>>>>> thinking of
 >>>>>>>>>>>> putting it into:
 >>>>>>>>>>>> possible,
 >>>>>>>>>>>> threads are
 >>>>>>>>>>>> before I
| Re: logger starting [message #463532 is a reply to message #463530] | Tue, 13 February 2007 07:22   |  |
 Well then you need to dig into Equinox and find out how you specify that
 your plugin is enabled as the first one after Equinox and Platform
 (which you need to be started because you want to call
 Platform#addLogListener()) ;-). The best idea is to ask at their
 mailling list/newsgroup. I could swear this can be done, maybe through a
 setting an option in the config.ini, ... .
 Tom
 >> in 3.3
 >> Tom
 >>> Tom Schindl wrote:
 >>>> Hi,
 >>>> how to that:
 >>>> Tom
 >>>>>> Tom
 >>>>>>> integrating.
 >>>>>>> the error event?
 >>>>>>> Tom Schindl wrote:
 >>>>>>>> Hi,
 >>>>>>>> Tom
 >>>>>>>>> method, eh?
 >>>>>>>>>>> Hi Tom!
 >>>>>>>>>>> /first 2nd thing/
 >>>>>>>>>> called
 >>>>>>>>>> 4. ...
 >>>>>>>>>> Tom
 >>>>>>>>>>> Tom Schindl wrote:
 >>>>>>>>>>>> Hi,
 >>>>>>>>>>>> when you
 >>>>>>>>>>>> will fail in
 >>>>>>>>>>>> Tom
 >>>>>>>>>>>>> Hello Stefan.
 >>>>>>>>>>>>> articles
 >>>>>>>>>>>>> Stefan Zugal wrote:
 >>>>>>>>>>>>>> Hi,
 >>>>>>>>>>>>>> called when your
 >>>>>>>>>>>>>> by Eclipse:
 >>>>>>>>>>>>>> HTH,
 >>>>>>>>>>>>>> Stefan
 >>>>>>>>>>>>>>> Hello everybody!
 >>>>>>>>>>>>>>> that I
 >>>>>>>>>>>>>>> thinking of
 >>>>>>>>>>>>>>> putting it into:
 >>>>>>>>>>>>>>> as possible,
 >>>>>>>>>>>>>>> threads are
 >>>>>>>>>>>>>>> before I
 >>>>>>>>>>>>>>> logged.
| Re: logger starting [message #463533 is a reply to message #463532] | Tue, 13 February 2007 07:26  |  |
 Thanks Tom a million!
 Let me go on there mailing list and ask them
 Tom Schindl wrote:
 > that your plugin is enabled as the first one after Equinox and
 > Platform (which you need to be started because you want to call
 > a setting an option in the config.ini, ... .
 > Tom
 >> initializes". So, it is a bit late to initialize the log4j there I
 >> think, because there might me errors during the workbench
 >> initialization process which I will not be able to catch. So, I still
 >> cannot figure out how to early start the log4j plug-in.
 >>> configuration using extension points. As you have discovered this
 >>> doesn't resolve the problem when the Platform internally catches
 >>> errors, ...  => so to also log those informations via log4j you
 >>> simply register yourself as a Platform.addLogListener() and log
 >>> introduce in 3.3
 >>> stages. I think this can be done using the org.ui.startup-Extension
 >>> point. But I'd certainly take a look at this status-handler API
 >>> maybe it provides new possibilities to you e.g. (log to file,
 >>> Tom
 >>>> Tom Schindl wrote:
 >>>>> Hi,
 >>>>> similar to the ILog-Service provided by eclipse. I think you can
 >>>>> Tom
 >>>>>>> services. Make sure you read this article at eclipsezone.
 >>>>>>> Tom
 >>>>>>>> integrating.
 >>>>>>>> the error event?
 >>>>>>>> Tom Schindl wrote:
 >>>>>>>>> Hi,
 >>>>>>>>> have to same problem that if you want to inject custom code if
 >>>>>>>>> the loading of it fails you can't intercept this (the platform
 >>>>>>>>> is out of luck ;-) Sorry for the rude analogy.
 >>>>>>>>> Tom
 >>>>>>>>>> method, eh?
 >>>>>>>>>> "initializing" bundle is not started) for some reason, which
 >>>>>>>>>> I want to log, as well, actually. If that is possible, of
 >>>>>>>>>> course.
 >>>>>>>>>>>> Hi Tom!
 >>>>>>>>>>>> not understand all the bits in your reply to my post:
 >>>>>>>>>>>> /first 2nd thing/
 >>>>>>>>>>> called
 >>>>>>>>>>> 4. ...
 >>>>>>>>>>> Tom
 >>>>>>>>>>>> Tom Schindl wrote:
 >>>>>>>>>>>>> Hi,
 >>>>>>>>>>>>> will fail in
 >>>>>>>>>>>>> today ;-)
 >>>>>>>>>>>>> Tom
 >>>>>>>>>>>>>> Hello Stefan.
 >>>>>>>>>>>>>> any articles
 >>>>>>>>>>>>>> Stefan Zugal wrote:
 >>>>>>>>>>>>>>> Hi,
 >>>>>>>>>>>>>>> called when your
 >>>>>>>>>>>>>>> by Eclipse:
 >>>>>>>>>>>>>>> HTH,
 >>>>>>>>>>>>>>> Stefan
 >>>>>>>>>>>>>>>> Hello everybody!
 >>>>>>>>>>>>>>>> is that I
 >>>>>>>>>>>>>>>> thinking of
 >>>>>>>>>>>>>>>> putting it into:
 >>>>>>>>>>>>>>>> as possible,
 >>>>>>>>>>>>>>>> threads are
 >>>>>>>>>>>>>>>> wrong before I
 >>>>>>>>>>>>>>>> logged.
 Current Time: Fri Oct 31 18:48:45 EDT 2025
 Powered by FUDForum . Page generated in 0.06894 seconds |
