Re: Can not select JavaHL 1.6 Connector [message #47100 is a reply to message #47070] |
Fri, 05 June 2009 13:10 |
sNop Messages: 281 Registered: July 2009 |
Igor Burilo napsal(a):
> Hello Simon,
> For more details, please see
> http://dev.eclipse.org/newslists/news.eclipse.technology.sub versive/msg01125.html
> It's not a Subversive bug, it's JVM bug.
>> sNop wrote:
>>> this is bug, igor wrote that it`s somehow relate with java machine, that
>>> could be loaded only one dll
>>> But i mean that because this there should be two dll`s which are needed
>> Thank you for your reply. Do you know is there a Bug-Report about this
>> issue? I didn't find one.
>> It's very interesting for me to know when this bug is solved.
>> Thanks,
Hi Igor,
I want to ask you only one question, it's possible handle older repos < 1.6, so 1.4.x and
1.5.x with JavaHL 1.6 connector ?
Or from another side, which repos can I administrate with JavaHL 1.6 ?
Thank you for advices
Re: Can not select JavaHL 1.6 Connector [message #47300 is a reply to message #47100] |
Mon, 15 June 2009 07:49 |
Igor Burilo Messages: 435 Registered: July 2009 |
Hello sNop,
You can work with 1.6, 1.5, 1.4 repositories using JavaHL 1.6 connector. You
can imagine that working with SVN connector is the same as working with svn
command client.
>> Hello Simon,
>>>> that
>>> Thanks,
> Hi Igor,
> 1.6, so 1.4.x and
FUDForum. Page generated in 0.03796 seconds
