Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT.VIRTUAL TableViewer not sorting
SWT.VIRTUAL TableViewer not sorting [message #462908] Thu, 20 October 2005 18:22 Go to next message
Originally posted by: mark_z.charter.net
I'm having an issue getting a TableViewer using SWT.VIRTUAL to properly sort
the items. What I've noticed is that in TableViewer, the
indexForElement(Object) method always ends up comparing the element to be
inserted against null ("data").
I've gotten this to work as expected using a non-virtual TableViewer. I've
can also get a virtual Table to work, similar to Snippet151, without the use
of a TableViewer.
I posted a sample demonstrating the issue:
http://www.ziesemer.com/SwtSortedVirtualTableViewerIssue.jav a . Hopefully
everything was written correctly - I was unable to find any documentation
regarding SWT.VIRTUAL support on the TableViewer other than in the source
code. (Another snippet on the SWT site for this would probably be useful!)
I'm making use of an ILazyContentProvider, however my updateElement(int)
method is never even being called. Not even an explicit refresh() against
the viewer after the additions helps.
Is this my problem, or bug-worthy? Thanks!
Mark A. Ziesemer
Re: SWT.VIRTUAL TableViewer not sorting [message #463396 is a reply to message #462908] Fri, 04 November 2005 14:40 Go to previous message
TableViewer is JFAce. Try asking the question again in eclipse.platform.
"Mark A. Ziesemer" <mark_z@charter.net> wrote in message
news:dj95ag$5a7$1@news.eclipse.org...
sort
I've
use
> of a TableViewer.
useful!)
> Mark A. Ziesemer
Previous Topic:clipboard content not up to date
Next Topic:Root TreeITem without Expand-Button and Lines
Current Time: Thu Nov 06 15:17:35 EST 2025
Powered by FUDForum. Page generated in 0.02872 seconds
