EXCEPTION_ACCESS_VIOLATION [message #462844] |
Thu, 20 October 2005 11:45 |
Originally posted by: frederic.lebeau.websurf.be
My application uses SWT and sometimes, it shuts down when the user click
on toolbar, menu, ... in this case some oleautomation are called...
Is it a well known problem?
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : EXCEPTION_ACCESS_VIOLATION (0xc0000005) occurred at
PC=0x77F7D814
Function=RtlDestroyHeap+0x518
Library=C:\NTWKS\System32\ntdll.dll
Current Java thread:
at org.eclipse.swt.internal.ole.win32.COM.VariantClear(Native Method)
at org.eclipse.swt.ole.win32.OleAutomation.invoke(OleAutomation .java:449)
at org.eclipse.swt.ole.win32.OleAutomation.invoke(OleAutomation .java:397)
Re: EXCEPTION_ACCESS_VIOLATION [message #462969 is a reply to message #462901] |
Mon, 24 October 2005 08:30 |
After some researches, here is the problem...
1) my applications jar files is on the network(also the swt.jar)
2) i'm launching the application from my workstation 'java.exe -cp blabla'
3) the network shuts down
4) i continue the navigation into my application (click button, open tabs,
5) the network is available
6) hs_err_pid created in the application folder(on the network)
PC=0x77F64DBA
Function=RtlFreeHeap+0x2A
at java.util.zip.InflaterInputStream.read(InflaterInputStream.j ava:134)
at
org.eclipse.swt.internal.image.LEDataInputStream.readData(LE DataInputStream.java:136)
at
org.eclipse.swt.internal.image.LEDataInputStream.read(LEData InputStream.java:86)
at java.io.InputStream.read(InputStream.java:89)
at
org.eclipse.swt.internal.image.WinBMPFileFormat.isFileFormat (WinBMPFileFormat.java:325)
at org.eclipse.swt.internal.image.FileFormat.load(FileFormat.ja va:63)
at org.eclipse.swt.graphics.ImageLoader.load(ImageLoader.java:1 24)
at org.eclipse.swt.graphics.ImageData.<init>(ImageData.java:308)
FUDForum. Page generated in 0.04208 seconds
