Home » Eclipse Projects » Standard Widget Toolkit (SWT) » showColumn() bug?
Re: showColumn() bug? [message #462523 is a reply to message #462512] |
Thu, 13 October 2005 13:11 |
Grant Gayed Messages: 2150 Registered: July 2009 |
Hi Tim,
I've logged https://bugs.eclipse.org/bugs/show_bug.cgi?id=112463 , and tried
to add you as a CC but couldn't because bugzilla did not know of your email
address. Interestingly I see the opposite problem to what you describe (my
snippet shows it failing when the column's LEFT edge is out of view). I
added a second comment to the report specifying that both cases should be
checked.
Regarding workarounds, I can make my snippet in the bug report show column 2
by first showing column 1 and then column 2 (so just add
"tree.showColumn(column1);" as the first line in the Button selection
listener). On win2000 this did not show any extra flash for me. It's just
an idea, as I can't think of any other workarounds at the moment.
Grant
"Tim Shelley" <tim_j_shelley@hotmail.com> wrote in message
news:dile7g$jn0$1@news.eclipse.org...
> I have a tree with treecolumns. The width of the tree often means some of
> the treecolumns appear offscreen, outside of the client area.
> I've tried to use showColumn() but it seems to have a bug that makes it
> difficult for cell editing where you want the column to be fully visible.
If
> the columns left edge appears off screen it scrolls correctly and makes
this
> column fully visible. If a columns left edge appears on the screen, but
its
> right edge is off the screen, it thinks the column is visible and does not
> scroll to it (even though there may be only a few pixels of the column on
> screen).
> I cannot extend the Tree class and there seems no way to work around this
> problem because the scrolling functionality of Tree seems to be all
private
> or package local.
> Is there a work around for this problem?
> Regards,
> Tim.
Re: showColumn() bug? [message #462550 is a reply to message #462523] |
Thu, 13 October 2005 14:31 |
Tim Shelley Messages: 60 Registered: July 2009 |
Member |
Hi Grant,
Thanks for the quick reply.
I've implemented your workaround, but have not tested it with lots of data
in the tree. I had to write another workaround for if it was the last
column, cause there are no columns after it :) I just added a hidden column,
zero width and not resizable. That seems to work ok.
The problem I am having now is with the cellEditor that opens on the column.
If the column is partially showing, the showColumn now displays it
correctly. When the cellEditor appears, its width is based on the partial
column width, not the full column that is now displayed.
I do -
showColumn()
treeEditor.setEditor()
It's as if the treeEditor is using the old column width and has not
refreshed with the new view with the fully displayed column.
Tim.
"Grant Gayed" <grant_gayed@ca.ibm.com> wrote in message
news:dilmen$v1v$1@news.eclipse.org...
> Hi Tim,
> tried
> email
> (my
> checked.
> 2
> just
> Grant
>> Hi,
> If
> this
> its
>> not
>> screen).
> private
>> or package local.
>> Regards,
>> Tim.
Re: showColumn() bug? [message #462595 is a reply to message #462550] |
Fri, 14 October 2005 13:17 |
I've looked into this and it appears to be another (more general) Tree bug.
I've logged https://bugs.eclipse.org/bugs/show_bug.cgi?id=112622 .
news:dilr47$643$1@news.eclipse.org...
> Hi Grant,
column,
column.
> I do -
> showColumn()
> Regards,
> Tim.
> > Hi Tim,
> > tried
> > email
> > (my
be
> > checked.
column
> > 2
> > just
> > Grant
> >> Hi,
of
visible.
> > If
> > this
> > its
> >> not
on
> >> screen).
this
> > private
> >> or package local.
> >> Regards,
> >> Tim.
Current Time: Fri Apr 26 22:30:19 GMT 2024
Powered by FUDForum. Page generated in 0.02648 seconds
