The Exception when the code that swing call the code that swt [message #461840] |
Mon, 03 October 2005 02:50 |
Originally posted by: guanxiaofeng_27.126.com
i have a main class be writed by swing,in a button click event,call a swt
window,the code as follow:
button.addActionListener(new ActionListener() {
public void actionPerformed(ActionEvent e) {
SwtText sw = new SwtText();
sw.open();
swt window code as follow:
public class SwtText{
protected Shell shell;
public void open() {
final Display display = Display.getDefault();
createContents();
shell.open();
shell.layout();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
protected void createContents() {
shell = new Shell();
shell.setSize(500, 375);
shell.setText("SWT Application");
the Exception as follow:
org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:2691)
at org.eclipse.swt.SWT.error(SWT.java:2616)
at org.eclipse.swt.SWT.error(SWT.java:2587)
at org.eclipse.swt.widgets.Widget.error(Widget.java:381)
at org.eclipse.swt.widgets.Shell.<init>(Shell.java:245)
at org.eclipse.swt.widgets.Shell.<init>(Shell.java:236)
at org.eclipse.swt.widgets.Shell.<init>(Shell.java:189)
at SwtText.createContents(SwtText.java:38)
at SwtText.open(SwtText.java:28)
at SwtText.run(SwtText.java:48)
at java.lang.Thread.run(Thread.java:534)
Re: The Exception when the code that swing call the code that swt [message #461846 is a reply to message #461840] |
Mon, 03 October 2005 06:00 |
the code that you worte have exception as follow:
java.lang.IllegalStateException: Workbench has not been created yet.
at org.eclipse.ui.PlatformUI.getWorkbench(PlatformUI.java:92)
at Jpro$1.actionPerformed(Jpro.java:48)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButto n.java:1786)
at
javax.swing.AbstractButton$ForwardActionEvents.actionPerform ed(AbstractButton.java:1839)
at
javax.swing.DefaultButtonModel.fireActionPerformed(DefaultBu ttonModel.java:420)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel .java:258)
at
javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Bas icButtonListener.java:245)
at java.awt.Component.processMouseEvent(Component.java:5100)
at java.awt.Component.processEvent(Component.java:4897)
at java.awt.Container.processEvent(Container.java:1569)
at java.awt.Component.dispatchEventImpl(Component.java:3615)
at java.awt.Container.dispatchEventImpl(Container.java:1627)
at java.awt.Component.dispatchEvent(Component.java:3477)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container. java:3483)
at java.awt.LightweightDispatcher.processMouseEvent(Container.j ava:3198)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java: 3128)
at java.awt.Container.dispatchEventImpl(Container.java:1613)
at java.awt.Window.dispatchEventImpl(Window.java:1606)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:456)
at
java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventD ispatchThread.java:201)
at
java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDis patchThread.java:151)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread. java:145)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread. java:137)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:10 0)
Re: The Exception when the code that swing call the code that swt [message #461857 is a reply to message #461854] |
Mon, 03 October 2005 15:21 |
You should use asyncExec and not syncExec. That is because the Button's
action listener is running on the AWT UI thread, and then you try to run
something on a different thread (the SWT UI thread). If during the
running of thw SwtText something was required from the AWT ui (such as
loose focus!) the AWT thread is already suspended waiting on the SWT
thread, and then the SWT thread will be suspended waiting on the AWT
thread. You would have a deadlock.
snpe wrote:
> This code is for eclipse rcp
> If you have standalone swt try this
> display.syncExec(new Runnable() {
> public void run () {
> sw.open();
Rich Kulp
FUDForum. Page generated in 0.05260 seconds
