| Simple FormLayout question [message #460950] |
Mon, 12 September 2005 18:23  |
Originally posted by: ondrej.kucera.centrum.cz
------------ek49XoUjSp799uDOVR0eM1
Content-Type: text/plain; format=flowed; delsp=yes; charset=utf-8
I'm trying to have following layout: three composites vertically filling
the whole shell, where composite1 has its height taken from its content
and composite2 and composite3 equally share the rest of the space. What I
can't achieve is changing heights of composite2 and composite3 when height
of composite1 changes (either by gaining some content or by user changing
size of the shell) - so that they still take 50% and 50% of the remaining
space. I think the right way is catching SWT.Resize event on composite1
but I'm not quite sure what to do in the handler - I've tried a couple of
things but none of them have worked. I hope the code snippet will help to
understand what I mean.
Regards, Ondrej
Content-Disposition: attachment; filename=ResizeSnippet.java
Content-Type: application/octet-stream; name=ResizeSnippet.java
Content-Transfer-Encoding: Base64
aW1wb3J0IG9yZy5lY2xpcHNlLnN3dC4qOwppbXBvcnQgb3JnLmVjbGlwc2Uu c3d0
LmN1c3RvbS4qOwppbXBvcnQgb3JnLmVjbGlwc2Uuc3d0LmV2ZW50cy4qOwpp bXBv
cnQgb3JnLmVjbGlwc2Uuc3d0LmxheW91dC4qOwppbXBvcnQgb3JnLmVjbGlw c2Uu
c3d0LndpZGdldHMuKjsKCnB1YmxpYyBjbGFzcyBSZXNpemVTbmlwcGV0IHsK ICAg
IHB1YmxpYyBzdGF0aWMgdm9pZCBtYWluKFN0cmluZ1tdIGFyZ3MpIHsKCURp c3Bs
YXkgZGlzcGxheSA9IG5ldyBEaXNwbGF5KCk7CglTaGVsbCBzaGVsbCA9IG5l dyBT
aGVsbChkaXNwbGF5KTsKCXNoZWxsLnNldFRleHQoIlJlc2l6ZVNuaXBwZXQi KTsK
CXNoZWxsLnNldExheW91dChuZXcgRmlsbExheW91dCgpKTsKCVNhc2hGb3Jt IGZv
cm0gPSBuZXcgU2FzaEZvcm0oc2hlbGwsIFNXVC5IT1JJWk9OVEFMKTsKCUNv bXBv
c2l0ZSBsZWZ0Q29tcG9zaXRlID0gbmV3IENvbXBvc2l0ZShmb3JtLCBTV1Qu Qk9S
REVSKTsKCWxlZnRDb21wb3NpdGUuc2V0TGF5b3V0KG5ldyBSb3dMYXlvdXQo KSk7
CglmaW5hbCBDb21wb3NpdGUgcmlnaHRDb21wb3NpdGUgPSBuZXcgQ29tcG9z aXRl
KGZvcm0sIFNXVC5CT1JERVIpOwoJcmlnaHRDb21wb3NpdGUuc2V0TGF5b3V0 KG5l
dyBGb3JtTGF5b3V0KCkpOwoJZmluYWwgQ29tcG9zaXRlIGNvbXBvc2l0ZTEg PSBu
ZXcgQ29tcG9zaXRlKHJpZ2h0Q29tcG9zaXRlLCBTV1QuQk9SREVSKTsKCWNv bXBv
c2l0ZTEuc2V0TGF5b3V0KG5ldyBSb3dMYXlvdXQoKSk7CglGb3JtRGF0YSBj b21w
b3NpdGUxRm9ybURhdGEgPSBuZXcgRm9ybURhdGEoKTsKCWNvbXBvc2l0ZTFG b3Jt
RGF0YS5sZWZ0ID0gbmV3IEZvcm1BdHRhY2htZW50KDAsIDQpOwoJY29tcG9z aXRl
MUZvcm1EYXRhLnJpZ2h0ID0gbmV3IEZvcm1BdHRhY2htZW50KDEwMCwgLTQp OwoJ
Y29tcG9zaXRlMUZvcm1EYXRhLnRvcCA9IG5ldyBGb3JtQXR0YWNobWVudCgw LCA0
KTsKCWNvbXBvc2l0ZTEuc2V0TGF5b3V0RGF0YShjb21wb3NpdGUxRm9ybURh dGEp
OwoJY29tcG9zaXRlMS5zZXRMYXlvdXQobmV3IFJvd0xheW91dCgpKTsKCUNv bXBv
c2l0ZSBjb21wb3NpdGUyID0gbmV3IENvbXBvc2l0ZShyaWdodENvbXBvc2l0 ZSwg
U1dULkJPUkRFUik7CglGb3JtRGF0YSBjb21wb3NpdGUyRm9ybURhdGEgPSBu ZXcg
Rm9ybURhdGEoKTsKCWNvbXBvc2l0ZTJGb3JtRGF0YS5sZWZ0ID0gbmV3IEZv cm1B
dHRhY2htZW50KDAsIDQpOwoJY29tcG9zaXRlMkZvcm1EYXRhLnJpZ2h0ID0g bmV3
IEZvcm1BdHRhY2htZW50KDEwMCwgLTQpOwoJY29tcG9zaXRlMkZvcm1EYXRh LnRv
cCA9IG5ldyBGb3JtQXR0YWNobWVudChjb21wb3NpdGUxLCA0LCBTV1QuQk9U VE9N
KTsKCWNvbXBvc2l0ZTJGb3JtRGF0YS5ib3R0b20gPSBuZXcgRm9ybUF0dGFj aG1l
bnQoNTAsIC00KTsKCWNvbXBvc2l0ZTIuc2V0TGF5b3V0RGF0YShjb21wb3Np dGUy
Rm9ybURhdGEpOwoJY29tcG9zaXRlMi5zZXRMYXlvdXQobmV3IFJvd0xheW91 dCgp
KTsKCUNvbXBvc2l0ZSBjb21wb3NpdGUzID0gbmV3IENvbXBvc2l0ZShyaWdo dENv
bXBvc2l0ZSwgU1dULkJPUkRFUik7CglGb3JtRGF0YSBjb21wb3NpdGUzRm9y bURh
dGEgPSBuZXcgRm9ybURhdGEoKTsKCWNvbXBvc2l0ZTNGb3JtRGF0YS5sZWZ0 ID0g
bmV3IEZvcm1BdHRhY2htZW50KDAsIDQpOwoJY29tcG9zaXRlM0Zvcm1EYXRh LnJp
Z2h0ID0gbmV3IEZvcm1BdHRhY2htZW50KDEwMCwgLTQpOwoJY29tcG9zaXRl M0Zv
cm1EYXRhLnRvcCA9IG5ldyBGb3JtQXR0YWNobWVudChjb21wb3NpdGUyLCA0 LCBT
V1QuQk9UVE9NKTsKCWNvbXBvc2l0ZTNGb3JtRGF0YS5ib3R0b20gPSBuZXcg Rm9y
bUF0dGFjaG1lbnQoMTAwLCAtNCk7Cgljb21wb3NpdGUzLnNldExheW91dERh dGEo
Y29tcG9zaXRlM0Zvcm1EYXRhKTsKCUJ1dHRvbiBidXR0b24gPSBuZXcgQnV0 dG9u
KGxlZnRDb21wb3NpdGUsIFNXVC5QVVNIKTsKCWJ1dHRvbi5zZXRUZXh0KCJB ZGQg
MjAgbGFiZWxzIik7CglidXR0b24ucGFjaygpOwoJYnV0dG9uLmFkZFNlbGVj dGlv
bkxpc3RlbmVyKG5ldyBTZWxlY3Rpb25BZGFwdGVyKCkgewoJCXB1YmxpYyB2 b2lk
IHdpZGdldFNlbGVjdGVkKFNlbGVjdGlvbkV2ZW50IGV2ZW50KSB7CgkJICAg IGZv
ciAoaW50IGkgPSAwOyBpIDwgMjA7IGkrKykgbmV3IExhYmVsKGNvbXBvc2l0 ZTEs
IFNXVC5OT05FKS5zZXRUZXh0KCJMYWJlbF8iICsgaSk7CgkJICAgIGNvbXBv c2l0
ZTEubGF5b3V0KCk7CgkJICAgIHJpZ2h0Q29tcG9zaXRlLmxheW91dCgpOwoJ CX0K
CSAgICB9KTsKCWZvcm0uc2V0V2VpZ2h0cyhuZXcgaW50W10gezMwLCA3MH0p OwoJ
c2hlbGwuc2V0U2l6ZSg4MDAsIDYwMCk7CglzaGVsbC5vcGVuKCk7Cgl3aGls ZSAo
IXNoZWxsLmlzRGlzcG9zZWQoKSkgewoJICAgIGlmICghZGlzcGxheS5yZWFk QW5k
RGlzcGF0Y2goKSkgewoJCWRpc3BsYXkuc2xlZXAoKTsKCSAgICB9Cgl9Cglk aXNw
bGF5LmRpc3Bvc2UoKTsKICAgIH0KfQo=
------------ek49XoUjSp799uDOVR0eM1--
| Re: Simple FormLayout question [message #460971 is a reply to message #460950] |
Tue, 13 September 2005 09:10   |
Originally posted by: ddana78ar.yahoo.com.ar
------=_Part_372_6712913.1126617157753
Content-Type: text/plain; charset=ISO-8859-1
Content-Disposition: inline
I don't know if it's that you want, but I hope that.
Best regards.
* Created on 12-sep-2005
* by DDana
package testing;
import org.eclipse.swt.*;
import org.eclipse.swt.custom.*;
import org.eclipse.swt.events.*;
import org.eclipse.swt.layout.*;
import org.eclipse.swt.widgets.*;
public class ResizeSnippet {
Display display = new Display();
Shell shell = new Shell(display);
shell.setText("ResizeSnippet");
shell.setLayout(new FillLayout());
SashForm form = new SashForm(shell, SWT.HORIZONTAL);
Composite leftComposite = new Composite(form, SWT.BORDER);
leftComposite.setLayout(new RowLayout());
final Composite rightComposite = new Composite(form, SWT.BORDER);
rightComposite.setLayout(new FormLayout());
final Composite composite1 = new Composite(rightComposite, SWT.BORDER);
composite1.setLayout(new RowLayout());
FormData composite1FormData = new FormData();
composite1FormData.left = new FormAttachment(0, 4);
composite1FormData.right = new FormAttachment(100, -4);
composite1FormData.top = new FormAttachment(0, 4);
composite1.setLayoutData(composite1FormData);
Composite compositeTheNEW = new Composite(rightComposite, SWT.NONE);
FormData compositeFormDataTheNEW = new FormData();
compositeFormDataTheNEW.left = new FormAttachment(0, 0);
compositeFormDataTheNEW.right = new FormAttachment(100, 0);
compositeFormDataTheNEW.top = new FormAttachment(composite1, 0);
compositeFormDataTheNEW.bottom = new FormAttachment(100, 0);
compositeTheNEW.setLayoutData(compositeFormDataTheNEW);
compositeTheNEW.setLayout(new FormLayout());
Composite composite2 = new Composite(compositeTheNEW, SWT.BORDER);
FormData composite2FormData = new FormData();
composite2FormData.left = new FormAttachment(0, 4);
composite2FormData.right = new FormAttachment(100, -4);
composite2FormData.top = new FormAttachment(0, 4);
composite2FormData.bottom = new FormAttachment(50, -4);
composite2.setLayoutData(composite2FormData);
//composite2.setLayout(new RowLayout());
Composite composite3 = new Composite(compositeTheNEW, SWT.BORDER);
FormData composite3FormData = new FormData();
composite3FormData.left = new FormAttachment(0, 4);
composite3FormData.right = new FormAttachment(100, -4);
composite3FormData.top = new FormAttachment(composite2, 4);
composite3FormData.bottom = new FormAttachment(100, -4);
composite3.setLayoutData(composite3FormData);
Button button = new Button(leftComposite, SWT.PUSH);
button.setText("Add 20 labels");
button.pack();
button.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent event) {
for (int i = 0; i < 20; i++) new Label(composite1, SWT.NONE).setText("Label_" + i);
composite1.layout();
rightComposite.layout();
form.setWeights(new int[] {30, 70});
shell.setSize(800, 600);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) {
display.sleep();
display.dispose();
------=_Part_372_6712913.1126617157753--
| Re: Simple FormLayout question [message #460988 is a reply to message #460971] |
Tue, 13 September 2005 18:24  |
yes, that's what I meant, thanks, I didn't think of it that way. I still
don't know what's wrong with trying to catch the resize event and re-set
top and bottom formattachments for composite2 and composite3 though. But
never mind that now.
Regards, Ondrej
> Best regards.
FUDForum. Page generated in 0.04984 seconds
