Home » Eclipse Projects » Rich Client Platform (RCP) » help,problem with adding console viewer to my rcp
help,problem with adding console viewer to my rcp [message #460845] Sat, 30 December 2006 06:50 Go to next message
i want add a console viewer to my rcp application ,so i follow the following
code:
1st,add
private MessageConsole myConsole;
private MessageConsoleStream msgStream;
myConsole = new MessageConsole("My Console", null);
ConsolePlugin.getDefault().getConsoleManager().addConsoles(n ew IConsole[]
{ myConsole });
msgStream = myConsole.newMessageStream();
to my
Activator extends AbstractUIPlugin
class
2nd,
add
layout.addView(IConsoleConstants.ID_CONSOLE_VIEW, IPageLayout.BOTTOM, .5f,
NavigationView.ID);
to my Perspective class
but after all this , i got the error
invalid Activator!
who can help me?
Re: help,problem with adding console viewer to my rcp [message #460846 is a reply to message #460845] Sat, 30 December 2006 07:02 Go to previous message
the detail error is :
org.eclipse.core.runtime.CoreException: Plug-in MyExcel was unable to load
class myexcel.Application.
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(RegistryStrategyOSGI.java:165)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:149)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:759)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:74)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
org.eclipse.core.runtime.CoreException[1]: java.lang.ClassNotFoundException:
myexcel.Application
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:402)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:347)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:278)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1245)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:147)
Previous Topic:Running JasperViewer inside an Eclipse RCP plugin crashes client
Next Topic:Problem restoring the treeViewer state.
Current Time: Wed Oct 29 01:12:46 EDT 2025
Powered by FUDForum. Page generated in 0.02767 seconds
