Home » Eclipse Projects » Standard Widget Toolkit (SWT) » 2 trees in sync with one scrollbar
2 trees in sync with one scrollbar [message #460656] Fri, 02 September 2005 09:53 Go to next message
Hi - I have 2 trees side by side in a composite. I want both to use only
the composite (vertical) scrollbar as oppose to each using their own. I've
tried setVisible(false) but as soon as a resizing takes place the
scrollbar appears plus this does not force it to use its parent. Is there
a way of forcing a Tree Widget to use its Parent scrollBar. Any help
appreciated.
Re: 2 trees in sync with one scrollbar [message #460720 is a reply to message #460656] Mon, 05 September 2005 08:24 Go to previous message
You could try to put the two trees into a ScrolledComposite.
This way they should always have enough space available and probably
won't display their own scrollbar.
See the SWT teams Snippets page for an exmaple how to use ScrolledComposite.
Yves
> I've tried setVisible(false) but as soon as a resizing takes place the
> there a way of forcing a Tree Widget to use its Parent scrollBar. Any
> help appreciated.
Previous Topic:Propagating changes from ContentProvider to JFace View
Next Topic:Customizing TreeItem ?
Current Time: Wed Oct 29 00:25:15 EDT 2025
Powered by FUDForum. Page generated in 0.03382 seconds
