java and swt libs compatibility [message #460514] |
Tue, 30 August 2005 16:52 |
Andreas Niemeyer Messages: 40 Registered: July 2009 |
Member |
Hi all,
I'm looking for a list, which swt version requires which java version, e.g.
swt 3.01(3064) -> 1.4.2_03
swt 3.1(3138) -> 1.4.2_06
to define a minimum and acceptable jre version/subversions for a swt
application.
For instance, one of our customers used hardware/software combination is
a HP c8000 workstation with HP-UX 11.11 and a installed Java 1.4.2_00 .
For this env we have problems to launch an SWT application with swt libs
like 3064 or above and I guess there is a version conflict which force
us to use a newer java version or to downgrade the used swt libs.
The application starts first, a user is able to login about a shell
dialog box and then, nothing happens - the main app window doesn't
appear, a process is just running - the app hangs; no idea to find out
what's going wrong.
Exists there a debug capability to pin down those kinds of problems?
If we try it with an own jre 1.4.2_03, the app starts without problems.
Many thanks for some suggestions!
ANdreas
Re: java and swt libs compatibility [message #460517 is a reply to message #460514] |
Tue, 30 August 2005 18:30 |
Member |
Hi all,
i read the older release notes of
http://www.eclipse.org/eclipse/development/readme_eclipse_3_ 0.html up to
http://www.eclipse.org/eclipse/development/readme_eclipse_3_ 0_2.html
and see that eclipse has been tested and validated with hp-ux and the
jre 1.4.2.00.
Then I see following note, probably is this the problem we have and will
be checked tomorrow:
Missing permissions for SWT native libraries in workspace (HP-UX only)
When retrieving the SWT Motif fragment into an Eclipse workspace, the
permissions of the native libraries are reset. This creates a problem on
HP-UX because shared libraries need to have execute permission.
Attempting to self-host with this fragment throws an
UnsatisfiedLinkError...Permission Denied error. You must manually change
the permissions to make these libraries accessible (assume the workspace
is at /workspace):
cd /workspace/org.eclipse.swt.motif/os/hpux/PA_RISC
chmod 555 *.sl
ANdreas
Andreas Niemeyer wrote:
> Hi all,
> application.
> what's going wrong.
> Regards,
> ANdreas
Re: java and swt libs compatibility [message #460749 is a reply to message #460517] |
Tue, 06 September 2005 16:45 |
Grant Gayed Messages: 2150 Registered: July 2009 |
As a side note, swt itself only requires a jre >= 1.1.8, but eclipse
requires the newer versions that you listed.
Grant
"Andreas Niemeyer" <andreas.niemeyer@gutzmann.com> wrote in message
news:df28jl$k1p$1@news.eclipse.org...
> Hi all,
> jre 1.4.2.00.
> is at /workspace):
> chmod 555 *.sl
> Regards,
> ANdreas
> > Hi all,
e.g.
> > application.
> > what's going wrong.
> > Regards,
> > ANdreas
FUDForum. Page generated in 0.03128 seconds
