Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Column editable in a Tree
Column editable in a Tree [message #460513] Tue, 30 August 2005 12:15 Go to next message
Originally posted by: OE_PROMOS.TERRA.ES
Hello I have a tree with 3 columns
I have right the code to edit a column : TreeEditor, Events... etc..
The problem :
I don't know the way to "detect" in which column the user has done "click".
I have
tree.addListener(SWT.Selection, new Listener ()
public void handleEvent (Event event)
final TreeItem item = (TreeItem) event.item;
// in this point I have all the row... but How could detect in which
column the user has "throw" the event?
Re: Column editable in a Tree [message #460748 is a reply to message #460513] Tue, 06 September 2005 12:42 Go to previous message
SWT.Selection is a higher-level event than you want to use here. Instead
you should listen for SWT.MouseDown, and compute the column, as demonstrated
in:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet3.java?rev=HEAD&am p;content-type=text/vnd.viewcvs-markup
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet110.java?rev=HEAD& amp;content-type=text/vnd.viewcvs-markup
Grant
"Oscar Escudero" <OE_PROMOS@TERRA.ES> wrote in message
news:3b7258f52a4c4f9fa13ac7751989fc82$1@www.eclipse.org...
> The problem :
"click".
> I have
Previous Topic:CCombo issues...
Next Topic:java and swt libs compatibility
Current Time: Sun Oct 26 17:45:45 EDT 2025
Powered by FUDForum. Page generated in 0.04605 seconds
