TableViewer ICellModifier not working on Dialog [message #459954] |
Sun, 21 August 2005 14:04 |
ddd Messages: 33 Registered: July 2009 |
Member |
I created a dialog for editing prefered propertys for added component in my
Graphical Editor, but when I want to edit cells it seems like ICellModifier
is not present. Should I add some Listeners...
My code:
public class PreferedProperyInputDialog extends Dialog
private AbstractComponentModel m_abstractComponentModel;
private TableViewer m_tableViewer;
public PreferedProperyInputDialog(Shell parent, AbstractComponentModel
abstractComponentModel)
super(parent);
m_abstractComponentModel = abstractComponentModel;
protected Control createDialogArea(Composite parent)
Composite area = (Composite) super.createDialogArea(parent);
m_tableViewer = new TableViewer(area);
Table table = m_tableViewer.getTable();
table.setHeaderVisible(true);
table.setLinesVisible(true);
TableColumn name = new TableColumn(table, SWT.NONE, 0);
name.setText("Property name");
name.setWidth(150);
TableColumn value = new TableColumn(table, SWT.NONE, 1);
value.setText("Property value");
value.setWidth(400);
final CellEditor[] editors = new CellEditor[2];
TextCellEditor editor = new TextCellEditor(table);
editor.activate();
editors[1] = editor;
m_tableViewer.setLabelProvider(new
PreferedPropertyTableLabelProvider());
m_tableViewer.setContentProvider(new ArrayContentProvider());
m_tableViewer.setCellEditors(editors);
m_tableViewer.setCellModifier(new PreferedPropertyTableCellModifier());
m_tableViewer.getCellModifier();
initContent();
return area;
private void initContent()
List content = new ArrayList();
Collections.addAll(content,
m_abstractComponentModel.getAbstractValuePropertyDataManager ()
.getPropertyDescriptors());
m_tableViewer.setInput(content);
private class PreferedPropertyTableLabelProvider implements
ITableLabelProvider
public Image getColumnImage(Object element, int columnIndex)
return null;
public String getColumnText(Object element, int columnIndex)
PropertyDescriptor propertyDescriptor = (PropertyDescriptor) element;
if (columnIndex == 0)
return propertyDescriptor.getDisplayName();
return
m_abstractComponentModel.getPropertyValue(propertyDescriptor .getId())
.toString();
public void addListener(ILabelProviderListener listener)
public void dispose()
public boolean isLabelProperty(Object element, String property)
return false;
public void removeListener(ILabelProviderListener listener)
private class PreferedPropertyTableCellModifier implements ICellModifier
public boolean canModify(Object element, String property)
return property.equals(m_tableViewer.getColumnProperties()[1]);
public Object getValue(Object element, String property)
if (property.equals(m_tableViewer.getColumnProperties()[1]))
element;
return
.toString();
return null;
public void modify(Object element, String property, Object value)
element;
m_abstractComponentModel.setPropertyValue(propertyDescriptor .getId(),
value);
Thank you,
Danijel
FUDForum. Page generated in 0.03164 seconds
