Home » Eclipse Projects » Standard Widget Toolkit (SWT) » TableTree
Re: TableTree [message #459614 is a reply to message #459613] |
Fri, 12 August 2005 18:53 |
Originally posted by: sunil_kamath.nohotspammail.com
"Mark M. Ingerman" <online@cs2.com> wrote in message
news:ddiov5$pre$1@news.eclipse.org...
>I am trying to work with the TableTree control. There is the viewer
>abstraction that provides content and label support for Tables and Trees,
>but I cannot find anything that provides the same level of abstraction for
>the TableTree control. I have tried to apply the TableViewer to the
>TableTree's table control -> new TableViewer(tableTree.getTable()), but it
>doesn't work. Is there such an abstraction, or do I need to create my own
>(or interface directly to the TableTree control)?
TableTree has been deprecated in 3.1- you can use Tree directly.
But if you insist, you can use org.eclipse.jface.viewers.TableTreeViewer.
Sunil
Re: TableTree [message #459615 is a reply to message #459614] |
Fri, 12 August 2005 20:03 |
online Messages: 6 Registered: July 2009 |
Okay. does this mean that the tree can support the tree and table functions
now? Can I then use the TreeViewer too? What version of SWT/JFace did the
table functions get incorporated into the Tree, or am I missing something?
Mark M. Ingerman
Creative Software Solutions, Inc.
Architect, OO-Designer, Developer, Mentor
mark.ingerman@cs2.com
617-630-2895
www.cs2.com
"Sunil Kamath" <sunil_kamath@nohotspammail.com> wrote in message
news:ddir65$s3k$1@news.eclipse.org...
> Sunil
Re: TableTree [message #459616 is a reply to message #459613] |
Fri, 12 August 2005 20:40 |
Kalman Hazins Messages: 76 Registered: July 2009 |
Member |
Sunil is right. TableTree should not be used any longer.
Below is the code for using a regular tree with columns:
import java.util.ArrayList;
import java.util.List;
import org.eclipse.jface.viewers.ILabelProviderListener;
import org.eclipse.jface.viewers.ITableLabelProvider;
import org.eclipse.jface.viewers.ITreeContentProvider;
import org.eclipse.jface.viewers.TreeViewer;
import org.eclipse.jface.viewers.Viewer;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Tree;
import org.eclipse.swt.widgets.TreeColumn;
public class TreeWithColumnsDriver {
// My computer
FileDirectory myComputer = new FileDirectory("My computer");
// C Drive
FileDirectory cDrive = new FileDirectory("C Drive");
FileDirectory file1 = new FileDirectory("Test1.txt", "John", "2 KB");
FileDirectory file2 = new FileDirectory("Testing2.html", "John", "5 KB");
FileDirectory file3 = new FileDirectory("Rest3.doc", "Marty", "10 KB");
FileDirectory file4 = new FileDirectory("Really big name.html", "Bob",
"100 KB");
cDrive.addChild(file1);
cDrive.addChild(file2);
cDrive.addChild(file3);
cDrive.addChild(file4);
myComputer.addChild(cDrive);
// D Drive
FileDirectory dDrive = new FileDirectory("D Drive");
FileDirectory downloads = new FileDirectory("Downloads");
dDrive.addChild(downloads);
FileDirectory filed1 = new FileDirectory("Whatever.txt", "John", "2 KB");
FileDirectory filed2 = new FileDirectory("Blogger.html", "John", "5 KB");
FileDirectory filed3 = new FileDirectory("something else.mp3", "Jack", "10
MB");
FileDirectory filed4 = new FileDirectory("Reality.txt", "Bryan", "100
KB");
downloads.addChild(filed1);
downloads.addChild(filed2);
downloads.addChild(filed3);
downloads.addChild(filed4);
myComputer.addChild(dDrive);
List filesDirs = new ArrayList();
filesDirs.add(myComputer);
showTree(filesDirs);
private static void showTree(List myComputer) {
// Create outside shell
Display display = new Display ();
Shell shell = new Shell(display);
shell.setText("Tree with columns sample");
shell.setLayout(new GridLayout());
shell.setSize(400, 400);
// Create treeViewer and the tree that goes inside the shell
TreeViewer fileTreeViewer = new TreeViewer(shell, SWT.FULL_SELECTION);
// Build the actual tree
Tree tree = fileTreeViewer.getTree();
tree.setHeaderVisible(true);
tree.setLinesVisible(false);
TreeColumn col1 = new TreeColumn(tree, SWT.LEFT);
col1.setText("Name");
col1.setWidth(200);
TreeColumn col2 = new TreeColumn(tree, SWT.LEFT);
col2.setText("Created By");
col2.setWidth(100);
TreeColumn col3 = new TreeColumn(tree, SWT.RIGHT);
col3.setText("File Size");
col3.setWidth(100);
tree.setLayoutData(new GridData(GridData.FILL_BOTH));
// Create content provider
fileTreeViewer.setContentProvider(new ITreeContentProvider() {
public Object[] getElements(Object inputElement) { // original input
List filesDirs = (List)inputElement;
return filesDirs.toArray();
public boolean hasChildren(Object element) {
FileDirectory fileDir = (FileDirectory)element;
return !fileDir.getChildren().isEmpty();
public Object[] getChildren(Object parentElement) { // all other children
FileDirectory fileDir = (FileDirectory)parentElement;
return fileDir.getChildren().toArray();
public Object getParent(Object element) {
return null;
public void inputChanged(Viewer viewer, Object oldInput, Object newInput)
public void dispose() {
fileTreeViewer.setLabelProvider(new ITableLabelProvider() {
public String getColumnText(Object element, int columnIndex) {
FileDirectory fileDir = (FileDirectory) element;
String colText = null;
switch (columnIndex) {
case 0:
colText = fileDir.getName();
break;
case 1:
colText = fileDir.getCreatedBy();
break;
case 2:
colText = fileDir.getSizeInBytes();
break;
default:
break;
return (colText != null) ? colText : "";
public void removeListener(ILabelProviderListener listener) {
public boolean isLabelProperty(Object element, String property) {
return false;
public void addListener(ILabelProviderListener listener) {
public Image getColumnImage(Object element, int columnIndex) {
return null;
fileTreeViewer.setInput(myComputer);
shell.open ();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
class FileDirectory {
private String name;
private String createdBy;
private String sizeInBytes;
private List children = new ArrayList();
public FileDirectory(String name, String createdBy, String sizeInBytes) {
this.name = name;
this.createdBy = createdBy;
this.sizeInBytes = sizeInBytes;
public FileDirectory(String name) {
this.name = name;
public void addChild(FileDirectory child) {
children.add(child);
public List getChildren() {
return children;
public void setChildren(List children) {
this.children = children;
public String getCreatedBy() {
return createdBy;
public void setCreatedBy(String createdBy) {
public String getName() {
return name;
public void setName(String name) {
this.name = name;
public String getSizeInBytes() {
return sizeInBytes;
public void setSizeInBytes(String sizeInBytes) {
HTH,
- Kalman (http://www.zikal.com/)
> Mark M. Ingerman
> 617-630-2895
> www.cs2.com
Re: TableTree [message #459617 is a reply to message #459615] |
Fri, 12 August 2005 20:41 |
Member |
Version 3.1
HTH,
news:ddiva4$il$1@news.eclipse.org...
> functions now? Can I then use the TreeViewer too? What version of
> SWT/JFace did the table functions get incorporated into the Tree, or am I
> missing something?
> Mark M. Ingerman
> 617-630-2895
> www.cs2.com
>>>for the TableTree control. I have tried to apply the TableViewer to the
>>>it doesn't work. Is there such an abstraction, or do I need to create my
>>>own (or interface directly to the TableTree control)?
>> Sunil
Re: TableTree [message #459618 is a reply to message #459616] |
Fri, 12 August 2005 22:02 |
Thank you for your input. I downloaded Eclipse 3.1. Installed it. Created
a project to test this. Added the necessary required libraries, but I
cannot run it due to the UnsatisfiedLinkError: no swt-win32-3138 in
java.library.path error:
I tried to:
1) add the -Djava.library.path= statement in the runtime VM arguments
2) changed my system path to point to the directory with the DLL
3) copied the DLL into my system and system32 folders, but nothing works
Did something else change in the new version of eclispe that prevents me
from setting this variable?
Mark M. Ingerman
617-630-2895
www.cs2.com
"Kalman" <kalman@zikal.com> wrote in message
news:ddj0t5$29m$1@news.eclipse.org...
> import org.eclipse.swt.widgets.Display;
> public static void main(String[] args) {
> // My computer
> // C Drive
> "100 KB");
> // D Drive
> "10 MB");
> KB");
> col1.setWidth(200);
> col2.setWidth(100);
> col3.setWidth(100);
> children
> return null;
> newInput) {
> case 0:
> break;
> case 1:
> break;
> case 2:
> break;
> default:
> break;
> return false;
> return null;
> shell.open ();
> display.dispose ();
> this.name = name;
> this.name = name;
> return children;
> return createdBy;
> return name;
> this.name = name;
> return sizeInBytes;
> HTH,
>> Mark M. Ingerman
>> 617-630-2895
>> www.cs2.com
Current Time: Fri Apr 26 21:07:38 GMT 2024
Powered by FUDForum. Page generated in 0.04279 seconds
