Re: SwingWorker equivalent in SWT [message #459079 is a reply to message #459076] |
Mon, 01 August 2005 12:54 |
Originally posted by: sunil_kamath.nohotspammail.com
"Mohit" <mohit.jhawar@gmail.com> wrote in message
news:d654cd64e704fbf4a35be16c85d60645$1@www.eclipse.org...
> Hi All,
> I need to put my heavy GUI processes in a separate thread. I heard that
> Swing has a SwingWorker class dedicated for the same. Do SWT also provides
> some or other thing to achieve this cause?
SWT only allows UI updates in the UI thread. So I don't know how much use
your separate thread will be- unless it is also a UI thread (in which case
it will use a separate Display, etc., from the main UI thread- which may not
even be allowed by the platform). From the SWT javadocs:
"Applications which are built with SWT will almost always require only a
single display. In particular, some platforms which SWT supports will not
allow more than one active display. In other words, some platforms do not
support creating a new display if one already exists that has not been sent
the dispose() message. "
Sunil
Re: SwingWorker equivalent in SWT [message #459145 is a reply to message #459141] |
Tue, 02 August 2005 14:31 |
news:ba2ccc6a71af402488cbd80c0cfa9420$1@www.eclipse.org...
> Thanks a lot Philip. I was actually putting the whole process inside
> syncExec().
Also consider using UIJob.
That way, if two GUI modifications of the same type occur in quick
succession, you can cancel the first UIJob and run just the second one.
Sunil
FUDForum. Page generated in 0.03915 seconds
