Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Knowing if my app is being used
Knowing if my app is being used [message #459028] Thu, 28 July 2005 17:06 Go to next message
I have an app which needs to automatically log a user out after a period
of inactivity. The timer stuff is easy enough. The problem is how do I
know the user is actively using my app? I am hoping to not have to hook
into every widget to know they typed in it, or selected it, or clicked
it, etc.
Any ideas?
Mike Higginbotham
Re: Knowing if my app is being used [message #459035 is a reply to message #459028] Fri, 29 July 2005 09:07 Go to previous messageGo to next message
> it, etc.
You could add an event filter to the display (Display.addFilter()) to
listen for all MouseDown and KeyPressed events that occur in your
application.
Stefan Zeiger - Developer of Novocode Application Framework
Build SWT-based MVC GUIs via XML: http://www.novocode.com/naf/
Re: Knowing if my app is being used [message #459061 is a reply to message #459035] Fri, 29 July 2005 13:35 Go to previous messageGo to next message
Originally posted by: seanmc42.hotmail.com
Well, presumably the widgets all hook into listeners, which call your
apps code - why not trigger off YOUR code?
>> period of inactivity. The timer stuff is easy enough. The problem is
>> how do I know the user is actively using my app? I am hoping to not
>> have to hook into every widget to know they typed in it, or selected
>> it, or clicked it, etc.
> application.
Re: Knowing if my app is being used [message #459066 is a reply to message #459035] Fri, 29 July 2005 17:30 Go to previous messageGo to next message
Originally posted by: bob.objfac.com
Yes, but beware of timing users out during long-running operations. They
won't be happy, especially if the "log out" triggers strange failure
modes in the operations.
Bob
> application.
Re: Knowing if my app is being used [message #459091 is a reply to message #459035] Mon, 01 August 2005 15:20 Go to previous messageGo to next message
Thanks, Stefan! This is what I was looking for. I tried addListener but
for some reason totally missed addFilter. Perfect.
- Mike
> application.
Re: Knowing if my app is being used [message #459092 is a reply to message #459061] Mon, 01 August 2005 15:23 Go to previous messageGo to next message
The problem is that there are a number of classes/views which I have to
monitor. I could do as you suggest but any new views would have to
remember to "play nice". By using addFilter, I can keep all the timeout
code in one place and new views do not have to worry about it.
- Mike
>> application.
Re: Knowing if my app is being used [message #459093 is a reply to message #459066] Mon, 01 August 2005 15:25 Go to previous messageGo to next message
Luckily, I do not have any long running operations. The timeout is 15
minutes of inactivity and is reset whenever they click the mouse
(SWT.MouseUp) or press a key (SWT.KeyUp) in the application.
- Mike
> Bob
>> application.
Re: Knowing if my app is being used [message #459094 is a reply to message #459091] Mon, 01 August 2005 15:46 Go to previous message
Look at:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=37061
It has a code snippet for exactly what you need.
-Chris
"Mike Higginbotham" <higginmi@us.ibm.com> wrote in message
news:dclsmd$jph$1@news.eclipse.org...
> - Mike
> > application.
Previous Topic:Hourglass!
Next Topic:TableViewer: Images in rows always have same size as image in column header
Current Time: Sat Nov 01 14:32:19 EDT 2025
Powered by FUDForum. Page generated in 0.11788 seconds
