Home » Eclipse Projects » Standard Widget Toolkit (SWT) » How to remove a control from a composite?
How to remove a control from a composite? [message #458926] |
Tue, 26 July 2005 17:32 |
Originally posted by: fmahjobi.enterasys.com
Is there a way to dynamically remove and add back in a control from a
composite? Imagine you have a case where you want to dynamically change
the appearance based on some conditions. I know about the stacklayout that
does work quite well. Setting visibility also does not work since the
object is actually there and it is just not displayed.
Thanks.
Re: How to remove a control from a composite? [message #458937 is a reply to message #458926] |
Tue, 26 July 2005 19:20 |
Originally posted by: sunil_kamath.nohotspammail.com
"Farzad" <fmahjobi@enterasys.com> wrote in message
news:98c4495a6fd18c010b205b06cdf61b50$1@www.eclipse.org...
> Thanks.
To remove:
dispose the control. layout the composite again.
To add back:
recreate the control. layout the composite again.
Where it shows up in the layout depends upon your layout manager.
Sunil
Re: How to remove a control from a composite? [message #458950 is a reply to message #458926] |
Wed, 27 July 2005 08:35 |
Glenn Marintes Messages: 23 Registered: July 2009 |
You can do this in two ways:
1. Dispose the control and create it again when needed.
This solution has its own disadvantage:
- it is difficult to create a control in the same place that it
was created before.. ie. your composite has 5 buttons, if you
dispose button 2, you can create a new button 2 later BUT
it will be added at the end of the composite.
- if for example, your composite contains a certain set of composites,
destroying the child composites will pose the same problem as stated
above + the fields in the child composite needs to be re-initialized.
2. Set the visibility of the control.
This solution needs the help of the layout manager. Basically,
once you setVisible(false) a control, the layout manager should
honor its invisibility and hence, the control is still there
but the layout manager won't show it and the layout manager
won't provide any space for it.
GridLayout in 3.1 and RowLayout can help you with this.
GridLayout 3.1 now supports invisible controls - that is, it won't
show invisible controls. If you want to hide a control, just
setVisible(false) it and then call parentComposite.layout(); If you
want to show it again, just call setVisible(true) it and then
You can also use RowLayout. To effectively hide the control
call, control.setVisible(false) and then
control.setLayoutData(new RowData(0,0));
If you want to shown it again, call control.setVisible(true) and then
control.setLayoutData(new RowData(controlWidth, controlHeight));
> that does work quite well. Setting visibility also does not work since
> the object is actually there and it is just not displayed.
As far as i know, stacklayout layouts components in a single stack.
that is, you can only have at most 1 control (could be a composite)
visible at any time... its pretty useless when you want to hide
just part of your composite.
Re: How to remove a control from a composite? [message #459160 is a reply to message #458950] |
Tue, 02 August 2005 19:06 |
Steve Northover Messages: 1636 Registered: July 2009 |
Actually, setVisible() alone won't do it. You'll need to also set the
exclude field in the layout data.
"Glenn Marintes" <glenn.marintes@laseritesystems.com> wrote in message
news:dc7h0s$ak0$1@news.eclipse.org...
Re: How to remove a control from a composite? [message #459208 is a reply to message #459160] |
Wed, 03 August 2005 12:14 |
ah yup.. i missed that part hehehe...
Thank you for the correction..
>>Hi,
Current Time: Fri Apr 26 22:41:24 GMT 2024
Powered by FUDForum. Page generated in 0.02850 seconds
