Re: Catching key pressing [message #458891 is a reply to message #458875] |
Mon, 25 July 2005 16:46 |
Originally posted by: sunil_kamath.nohotspammail.com
"Alex" <rashevsky@gmail.com> wrote in message
news:651a2d9a2f7a7db70288b1ff9c24299e$1@www.eclipse.org...
> Hello. Please, tell me, how can I catch Enter key pressing in my
> TextEditor class? I'm try to add auto indent to my editor.
To add auto indent, you don't need to catch key presses yourself.
Consider using the org.eclipse.jface.text.IAutoEditStrategy interface
instead.
Specifically, you could extend
org.eclipse.jface.text.DefaultIndentLineAutoEditStrategy
(org.eclipse.jface.text.DefaultAutoIndentStrategy in Eclipse 3.0).
You can then call prependAutoEditStrategy() on your TextViewer to install
your strategy.
Sunil
Re: Catching key pressing [message #458925 is a reply to message #458910] |
Tue, 26 July 2005 17:05 |
news:bc7296c2153a2994745037ace78c6597$1@www.eclipse.org...
> Tnx.
> So, I wrote XMLAutoIndentStrategy class, register it in the
> XMLSourceViewerConfiguration class:
> public IAutoIndentStrategy getAutoIndentStrategy(ISourceViewer
> sourceViewer,
> String contentType)
> return new
> XMLAutoIndentStrategy(UIPlugin.getDefault().getPreferenceSto re());
> Then, I set configuration in the Editor class:
> setSourceViewerConfiguration(new XMLConfiguration(colorManager));
> But when I press "Enter" key method
> XMLAutoIndentStrategy.customizeDocumentCommand does'n calls...
> Sorry for my english...
Have you set up document partitioning?
Without document partitioning, auto indent will not work.
If you have, then all I can recommend is debugging to make sure your auto
indent strategy is being installed, and then check what happens when a key
is pressed on the editor styledtext widget.
Sunil
FUDForum. Page generated in 0.03060 seconds
