Re: SWT_AWT vs. SwingWT [message #458276 is a reply to message #458258] |
Tue, 12 July 2005 18:46 |
Theo Messages: 3 Registered: July 2009 |
I managed to integrate a JLabel and a JButton together with some listeners
into a standard view within eclipse. I wonder what SwingWT provides that
the SWT_AWT bridge can not provide.
Are there any restrictions in using the bridge which made SwingWT
necessary?
Hi Ricky,
I am trying too to stuff some Swing into a view.
SwingWT was my first choice. Admitedly it comes with plenty
of slick examples, so I thought I've scored.
However soon it became clear that SwingWT deals only with the
GUI sub-area of .awt., for instance there is nothing in
swingwt.awt.geom
or
swingwt.awt.image
So it would be very hard to port a whole working application or applet
to SWT.
I guess the main benefit of using SwingWT is that one would be
able to use familiar Swing snippets and patterns, but again only
as far as it is about GUI components.
Anyway, next I tryed SWT_AWT, but unlike you I wasn't that lucky.
Yes, I can show a button, and the button can even respond with
message(wow),
but every time I change the focus from / to that view an informative
error msg appears: "An error has ocurred when activating that view"
and there is an exception in Eclipse's comsole:
Unhandled event loop exception
Reason:
This is what I do:
public void createPartControl(Composite parent) {
if ( parent == null) return;
Composite comp = new Composite( parent, SWT.EMBEDDED );
Frame frm = SWT_AWT.new_Frame( comp);
final Panel panel = new Panel();
java.awt.Button btn = new java.awt.Button( "OLE !!!");
btn.addActionListener( new ActionListener() {
public void actionPerformed(ActionEvent arg0) {
JOptionPane.showMessageDialog( panel, "Thanks");
panel.add( btn);
frm.add( panel);
Have you experienced such an exception?
Would you mind sharing a snippet?
Theo
Re: SWT_AWT vs. SwingWT [message #458417 is a reply to message #458276] |
Wed, 13 July 2005 12:41 |
Ricky Messages: 204 Registered: July 2009 |
Hi Theo,
> message(wow),
I got an error message too but beeing happy that swing is working within
eclipse, errors will not put me down :)
My code is:
java.awt.Frame locationFrame = SWT_AWT.new_Frame(new
Composite(parent,parent.getStyle()|SWT.EMBEDDED));
this.label = new JLabel("Hallo Welt");
this.label.addMouseListener(new MouseAdapter() {
public void mouseClicked(MouseEvent mouseEvent) {
SampleView.this.label.setText("Hallo Welt
"+mouseEvent.getPoint());
locationFrame.add(this.label);
.... (time flies like an arrow)
The nature of my error was self made as I used the SampleView template to
test the bridge. Like you my createPartControl did not instantiate a
viewer object but the setFocus method accessed one. Hence the Null Pointer
Exception. After commenting out the method, everything worked fine. This
should be read as: No errors in the log. But I still dont know if this
bridge has some big but hidden holes, though.
May this hint help you with your problem? If not the your stacktrace of
the exception would be interesting.
Ricky
FUDForum. Page generated in 0.02758 seconds
