Home » Eclipse Projects » Standard Widget Toolkit (SWT) » tree layout
Re: tree layout [message #454293 is a reply to message #454231] |
Tue, 19 April 2005 18:50 |
Christian Sell Messages: 77 Registered: July 2009 |
Member |
hmm, I dont think I understand the conclusion. Right now, Tree is not
able to fully replace TableTree, as there are no similar layout
facilites (in fact, there seem to be none). So, in order to avoid API
change, the only way would be to remove the deprecation IMO..
chris
Grant Gayed wrote:
> I don't think so since api is frozen for 3.1. This was logged recently, see
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=91662 .
> Grant
> "Christian Sell" <christian.sell@netcologne.de> wrote in message
> news:d4135f$hcr$1@news.eclipse.org...
>>I just copied TableLayout into a TreeLayout class and changed the
>>(Table) casts to (Tree) casts. All was well afterwards. I assume there
>>will be some change before 3.1 GA that makes the same class usable in
>>both cases?!
>>chris
>>Christian Sell wrote:
>>>Hello,
>>>after migrating to Eclipse 3.1M6, I switched my app from
>>>TableTree(Viewer) to Tree(Viewer) because the forme has become
>>>deprecated. However, I am now looking for a layout to attach to the Tree
>>>in the same way that a TableLayout is attached to a Table. In
>>>particular, I am looking for ways to specify the relative weight of the
>>>columns, and the automatic resizing that is performed by TableLayout.
>>>Can anybody help?
>>>thanks,
>>>christian
Re: tree layout [message #454689 is a reply to message #454293] |
Wed, 27 April 2005 14:02 |
Veronika Irvine Messages: 1272 Registered: July 2009 |
TableLayout is not really a satisfactory answer for Table or Tree. The idea
of TableLayout is probably going to be rethought post 3.1 and therefore it
does not make too much sense for a copy of TableLayout to be created for
Tree. The work being done in TableLayout can quite simply be done with a
resize listener. For example, the PropertySheet view does the following:
tree.addControlListener(new ControlAdapter() {
public void controlResized(ControlEvent e) {
Rectangle area = tree.getClientArea();
TreeColumn[] columns = tree.getColumns();
if (area.width > 0 && columns[0].getWidth() == 0) {
columns[0].setWidth(area.width * 40 / 100);
columns[1].setWidth(area.width - columns[0].getWidth() - 4);
tree.removeControlListener(this);
news:d43kd3$tb7$1@news.eclipse.org...
> hmm, I dont think I understand the conclusion. Right now, Tree is not able
> to fully replace TableTree, as there are no similar layout facilites (in
> fact, there seem to be none). So, in order to avoid API change, the only
> chris
>> see
>> Grant
>>>both cases?!
>>>chris
>>>>Hello,
>>>>Can anybody help?
>>>>thanks,
>>>>christian
Current Time: Wed Sep 25 03:43:03 GMT 2024
Powered by FUDForum. Page generated in 0.03443 seconds
