Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Drawing a polygon doughnut.
| Drawing a polygon doughnut. [message #453206] |
Thu, 31 March 2005 14:24  |
Originally posted by: waynetg.telkomsa.net
Hi all
I have two or more arrays of integers. I need to draw a "doughnut" with
one or more holes in the middle and not loose the detail behind the
doughnut that can be seen through the holes.
Does anyone have any idea as to how I can do this? I am totally at a loss...
Any pointers, help, reading material would be appreciated.
| Re: Drawing a polygon doughnut. [message #453299 is a reply to message #453210] |
Mon, 04 April 2005 16:26   |
On Thu, 31 Mar 2005 20:12:13 +0000, Rohit Colaço wrote:
> You need to work with Regions defined in 'org.eclipse.swt.graphics.Region'
> Create a new Region instance R1.
> Add your outer polygon to R1 using add(int[]).
> Subtract all inner polygons from R1 using subtract(int[]).
> Hold the existing GC clipping state in another Region R2.
> Clip on R1.
> Fill and draw whatever you need within R1.
> Restore the previous clipping on R2.
> Oh and ... don't forget to dispose R1.
Hi heres a working(in a broken way) snippet showing what I'm trying to do.
Figured it would be more helpful. I'm missing a draw command or something
somewhere. Any pointers? I'm stumped...
import org.eclipse.swt.graphics.*;
import org.eclipse.swt.SWT;
import org.eclipse.swt.widgets.*;
public class testa {
private static int partSegment[][] = new int[][]
new int[] {10,10,70,10,250,20,400,100,600,200,400,250,60,50,10,10},
new int[] {100,60,350,80,370,110,320,150,100,60}
private static Display display;
private static Listener listener;
private static Shell shell;
public static void main(String[] argv) {
display=new Display();
shell=new Shell(display);
shell.setSize(650,670);
shell.setLocation(400,20);
redraw();
shell.open();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ())
display.sleep ();
display.dispose ();
private static void redraw() {
listener = new Listener() {
public void handleEvent(Event event) {
switch (event.type) {
case SWT.Paint: {
Image bufferImage = new Image(display, event.width,
event.height);
GC bufferGC = new GC(bufferImage);
bufferGC.setBackground(new Color(event.display, 0,255,255));
bufferGC.fillRectangle(300,100,50,50);
bufferGC.setLineWidth(2);
bufferGC.setLineCap(SWT.CAP_ROUND);
Region R1=new Region();
for(int i=0;i<2;i++)
if(i==0)
R1.add(partSegment[i]);
else
bufferGC.setBackground(new Color(event.display, 255,0,0));
R1.subtract(partSegment[i]);
bufferGC.getClipping(R1);
R1.dispose();
event.gc.drawImage(bufferImage, 0, 0);
bufferImage.dispose();
break;
case SWT.BUTTON5:{
break;
shell.addListener(SWT.Paint,listener);
shell.redraw();
shell.update();
System.out.println("Done");
| Re: Drawing a polygon doughnut. [message #453301 is a reply to message #453299] |
Mon, 04 April 2005 18:18   |
Tshwala,
You didn't clearly follow the instructions I provided earlier.
I corrected your code.
Use this instead:
-----START-----
new int[]
{10,10,70,15,250,20,400,100,600,200,400,250,60,50},
redraw();
shell.open();
display.sleep ();
display.dispose ();
case SWT.Paint: {
event.height);
0,255,255));
Region R2=new Region();
bufferGC.getClipping(R2);
if(i==0)
else
bufferGC.setClipping(R1);
bufferGC.setBackground(event.display.getSystemColor(SWT.COLO R_RED));
bufferGC.fillRectangle(R1.getBounds());
R1.dispose();
bufferGC.setClipping(R2);
R2.dispose();
break;
case SWT.BUTTON5:{
break;
shell.redraw();
shell.update();
------END------
Also, the following objects need to be disposed:
bufferGC.setBackground(new Color(event.display, 0,255,255)); // COLOR
CREATION
GC bufferGC = new GC(bufferImage); // GC CREATION
... or else you'll end up with no more SWT handles.
| Re: Drawing a polygon doughnut. [message #453450 is a reply to message #453312] |
Tue, 05 April 2005 17:18  |
R2 is needed to preserve and restore any existing clipping state on your
GC. In the context of your app and image's GC, R2 may not be needed but
when you render multiple doughnuts on the same GC and eventually restore
the previous clip state, you would use R2.
In general, be disciplined about restoring a previous state irrespective
of the type of resource (colors, fonts, etc) being used. This is a
standard OS programming rule (especially Win32) and since SWT is
implemented as a thin JNI layer over OS API, you want to make sure you
follow that rule.
- Rohit
Current Time: Mon Oct 27 12:06:07 EDT 2025
Powered by FUDForum. Page generated in 0.27174 seconds
