| no scrollbars when expanding section with managedform.reflow() [message #452174] |
Mon, 14 March 2005 20:21   |
Eclipse User  |
I'm using the form programming sample code from the
org.eclipse.ui.forms.examples plugin, and have modified the
MasterDetailsBlock page so that TyepOneDetailsPage contains an expandable
section.  My two code changes are shown with '*' below.
I cannot figure out why expanding the section s1 doesn't result in
scrollbars appearing - I thought the mform.reflow() in my expansion
listener should do that.
Scrollbars *do* appear when I select a new item in the sample's master
part, so there's definitely a scrollable parent in the widget hierarchy, I
just cannot trigger the addition of scrollbars with mform.reflow().  What
should I be calling in the expansion listener?
public void createContents(Composite parent) {
	TableWrapLayout layout = new TableWrapLayout();
	layout.topMargin = 5;
	layout.leftMargin = 5;
	layout.rightMargin = 2;
	layout.bottomMargin = 2;
	parent.setLayout(layout);
	FormToolkit toolkit = mform.getToolkit();
	Section s1 = toolkit.createSection(parent,
		Section.DESCRIPTION|
*		Section.TWISTIE|Section.COMPACT);
	s1.marginWidth = 10;
	s1.setText("Type One Details");
	s1.setDescription("Set the properties of the selected TypeOne object.");
	TableWrapData td = new TableWrapData(TableWrapData.FILL,
	TableWrapData.TOP); td.grabHorizontal = true;
	s1.setLayoutData(td);
	toolkit.createCompositeSeparator(s1); Composite client =
	toolkit.createComposite(s1); GridLayout glayout = new GridLayout();
	glayout.marginWidth = glayout.marginHeight = 0; glayout.numColumns = 2;
	client.setLayout(glayout);
*	s1.addExpansionListener(new ExpansionAdapter() {
		public void expansionStateChanged(ExpansionEvent e) {
			mform.reflow(true);
	... [rest of app is same as sample code]
| Re: no scrollbars when expanding section with managedform.reflow () [message #452292 is a reply to message #452278] |
Wed, 16 March 2005 21:28    |
Eclipse User  |
Thanks Dimitry,
That does the trick.  I spent a lot of hours on this one, and to be
honest, I still don't fully understand the distinctions between reflow(),
layout(), pack(), redraw(), etc., nor how they propagate up/down a
hierarchy of SWT components/forms.  It would be good if somebody in the
know could write a little on these - I have colleagues who have also spent
a lot of time fiddling with reflow() and layout().
I think you're right.  For some reason, the mform.reflow() doesn't affect
the ScrolledComposite.  Seems like a bug to me.
The other curious thing about this is that the expanding section
sends a reflow() up the hierarchy by default, but this also does nothing
to the scrollbars.
For the benefit of others, here're the other things that I tried in my
expansion handler, to no avail:
 // exifSection.layout(true);
 // exifSection.pack(true);
 // exifSection.notifyListeners(SWT.Resize, new Event());
 // mform.reflow(true);
 // mform.getForm().layout();
 // mform.getForm().reflow(true); // This is what mform.reflow() does
 // mform.getForm().redraw();
 // mform.getForm().notifyListeners(SWT.Resize, new Event());
 // parent.getParent().getParent().layout(true);
  ((SharedScrolledComposite)(parent.getParent().getParent())). reflow(true);
FUDForum. Page generated in 0.51970 seconds
