Home » Modeling » TMF (Xtext) » Xtext and error recovery in block-level statements
Re: Xtext and error recovery in block-level statements [message #45553 is a reply to message #45521] |
Wed, 27 May 2009 07:29 |
Sebastian Zarnekow Messages: 3118 Registered: July 2009 |
Hi Shane,
Xtext relies on the error recovery, that comes with Antlr by default.
Currently there is no way to alter this behavior to get better error
recovery for your special case.
Please feel free to file (an) enhancement request(s).
Btw: You may want to try to rewrite your grammar to something like this:
Model :
(outers += Outer )*;
Outer:
'create' 'outer' name = ID
( inners += Inner )*
'end' 'outer' ';'
Inner:
'create' 'inner' name = ID ';'
Note the keyword ';' has been moved into the rules "Outer" and "Inner".
You'll get better error recovery and - at least from my point of view -
the syntax communicates better, how a complete Outer or Inner should
look like.
Don't forget to file the tickets ;-)
Sebastian
Am 27.05.2009 4:02 Uhr, schrieb Shane Beasley:
> Consider the following grammar and input:
> Model :
> ( outers += Outer ';' )* ;
> Outer :
> ( inners += Inner ';' )*
> 'end' 'outer' ;
> Inner : 'create' 'inner' name = ID ;
> create outer Foo TYPO create inner X; create inner Y; end outer;
> create outer Bar create inner X; create inner Y; end outer;
> Because of the unexpected token TYPO, the Outline Pane shows a node for
> Foo but not for Foo/X, Foo/Y, or Bar or its children.
> http://wiki.eclipse.org/Xtext/Documentation mentions error recovery in
> passing, but I don't think it describes anything that would help here.
> I've seen the following technique in ANTLR grammars to recover from
> errors inside the block:
> Outer :
> ( inners += Inner ';' | !'end' )*
> 'end' 'outer' ;
> Unfortunately, Xtext does not accept terminal negation (!'end') in a
> nonterminal rule.
> Are there any other tricks for getting better error recovery, or should
> I just file an enhancement request for the above (or both)? :)
> Thanks!
Re: Xtext and error recovery in block-level statements [message #45702 is a reply to message #45553] |
Thu, 28 May 2009 01:36 |
Shane Beasley Messages: 6 Registered: July 2009 |
ANTLR error recovery is supposed to be powerful, but it obviously needs
help... I guess I need to read up on that.
I did file #278144 about consuming arbitrary tokens ("any" or "any but
these"). However, it occurred to me that it's probably a bad idea for
error recovery, for a lot of reasons -- for one, it doesn't tell Xtext
that it's an error. :)
I was going to file a generic "better error recovery" ticket, but I see
that Sven already did that (#232011) and later marked it "won't fix ->
too generic."
Actually, a related question: Can you point me to anything (docs or the
relevant code) about how Xtext does incremental parsing -- how it
decides which rules to execute and when, etc.? Seems interesting in
general, but also relevant to the task at hand.
> this: [...] Note the keyword ';' has been moved into the rules
Moving the semicolons did improve recovery: It still lost the first
"outer" block, but was able to recover the second one. Maybe that'll
help me figure out how to get it to recover bits of the first block,
too. Thanks for the suggestion. :)
Shane
Re: Xtext and error recovery in block-level statements [message #45732 is a reply to message #45702] |
Thu, 28 May 2009 06:31 |
Hi Shane,
please find my comments inline.
Am 28.05.2009 3:36 Uhr, schrieb Shane Beasley:
> too generic."
It should basically provide the same results as a full parse. We track
the textual modifications in a document, collect them, group them
together and compute the affected part of the parse tree. This
information is combined with lookahead infos from the parse to decide
whether a certain rule / node combination is a valid entry point or not.
After identifying the smallest region, that may be theoretically
reparsed, we try that. A full parse is performed as a fallback strategy
if the partial parsing results in an erroneous model.
I'm afraid there is currently not much documentation about this topic
available, as it is quite internal stuff. We focus more on concepts, the
big picture and customization hooks. But I promise, documentation will
be improved before the galileo release.
Have a look at PartialParsingUtil for implementation details.
>> this: [...] Note the keyword ';' has been moved into the rules "Outer"
>> and "Inner".
Nice to meet you.
> Shane
Sebastian
Current Time: Fri Apr 26 17:59:30 GMT 2024
Powered by FUDForum. Page generated in 0.03238 seconds
