Home » Eclipse Projects » Rich Client Platform (RCP) » Basic question: view or editor
Basic question: view or editor [message #451282] Tue, 20 June 2006 08:06 Go to next message
Originally posted by: e.dominguez.ticino.com
Hi all,
I have a question. I'm trying to develop an application. Left side I
have my navigator. Right side my 'forms' or pages.
I.ex. in one of this pages i have 3 fields, some buttons, a file choser,
and a table.
What should i use as 'container' for this purpose? a View (i don't
think)? an editorPart? (but needs a File as parameter... why?) what else?
Thank you very much for a response...
kind regards
e. dominguez
Re: Basic question: view or editor [message #451343 is a reply to message #451282] Tue, 20 June 2006 08:53 Go to previous messageGo to next message
We have made use of ViewPart's for this... It depends.
As far as I've understood, the EditorPart does not require the the input
to be an actual file, it just requires that it should implement
IEditorInput. What exactly do you provide as an editor input, is really
up to your editor implementation.
The most obvious downside to having editor is that you can not stack
views and editors in the same tab folder. If you use views OTOH, you run
the risk of having your navigator all over the application window, when
user closes the last details window. You could avoid this probably by
disallowing closing of the "details view" or modifying the presentation
of the workbench.
E. Dominguez kirjutas mulle midagi seesugust:
> Hi all,
> and a table.
> kind regards
> e. dominguez
Roland Tepp
Re: Basic question: view or editor [message #451345 is a reply to message #451343] Tue, 20 June 2006 09:00 Go to previous messageGo to next message
but what's the purpose of editors then?
i had this problem (navigator all over app win)... how to avoid it?
Has someone an example that shows usage of editors (how to open, and so on)?
> of the workbench.
>> Hi all,
>> choser, and a table.
>> kind regards
>> e. dominguez
Re: Basic question: view or editor [message #451351 is a reply to message #451345] Tue, 20 June 2006 10:08 Go to previous messageGo to next message
Think of editors as specialized views that have a lifecycle (saving,
etc...) to them and are displayed in a special area of the perspective.
This implies that editors cannot be stacked etc...
Stefan
> on)?
>> input to be an actual file, it just requires that it should implement
>> really up to your editor implementation.
>> run the risk of having your navigator all over the application window,
>> when user closes the last details window. You could avoid this
>> probably by disallowing closing of the "details view" or modifying the
>> presentation of the workbench.
>>> Hi all,
>>> else?
>>> kind regards
>>> e. dominguez
Re: Basic question: view or editor [message #451358 is a reply to message #451351] Tue, 20 June 2006 11:16 Go to previous messageGo to next message
so what do you suggest to use in my place?
Re: Basic question: view or editor [message #451359 is a reply to message #451358] Tue, 20 June 2006 11:45 Go to previous message
If you have a resource (doesn't have to be a file) that is edited and
needs saving, cancel abilites I would suggest an editor. For all other
cases I would suggest a viewpart. Keep in mind that the viewpart can be
dragged around the workbench and be made into a quickview if desired.
See IEditorInput in the help to see what you have to implement. In the
extension point for your editor don't specify a file extension if you
are not using a file.
Previous Topic:Use classes of a required plugins jar file
Next Topic:Building and Testing a JDOM plugin
Current Time: Sun Oct 26 00:03:14 EDT 2025
Powered by FUDForum. Page generated in 0.03956 seconds
