Home » Eclipse Projects » Rich Client Platform (RCP) » File type associations
File type associations [message #450685] Wed, 07 June 2006 12:44 Go to next message
Originally posted by: andrew.easter.gmail.com
How exactly does eclipse deal with file type associations. For example...
The plugin.xml file is a simple xml file that happens to describe a particular plugin. Given that this file is only an xml file (.xml extension) how does Eclipse determine:
1) That the icon rendered in the tree should be the plugin editor icon and not just a standard xml file icon.
2) That the PDE editor should be displayed rather than just a simple XML editor when double clicking to edit the file.
I am confused by all of this. How would one, for example, go about editing the plugin.xml file without the PDE editor (i.e. with a standard xml file editor) and, also, what happens if more than one plugin specifies an editor for the same type? (e.g. two WSDL editors).
Thanks for any help anyone can give me,
Andrew
Re: File type associations [message #450686 is a reply to message #450685] Wed, 07 June 2006 12:51 Go to previous messageGo to next message
In addition to above...
It is not just the "plugin.xml" file that launches the PDE editor but also the "build.properties" file and the "MANIFEST.MF" files.
How is this?
Andrew
Re: File type associations [message #450694 is a reply to message #450686] Wed, 07 June 2006 22:57 Go to previous message
Here is an answer to part of your question, but I don't think it addresses everything.
When you plug into the 'org.eclipse.ui.editors' extension-point, one of the things you specify is
the file extension. That means, when Eclipse is asked to open a file of that type, it will use your
editor. (I think there are clever tricky things that happen if more than one editor specifies the
same extension.)
In the Window -> Properties -> (enter text) File Associations you can see what other plugins have
plugged into this extension-point.
There is also Window -> Properties -> (enter text) Content Types -- where you can see that Eclipse
has some secret way of "locking" an association. That I do not get.
HTH,
Paul
Previous Topic:problem locating a file in third part jar
Next Topic:Update site manager does not remove older plugin
Current Time: Fri Oct 31 04:16:10 EDT 2025
Powered by FUDForum. Page generated in 0.27532 seconds
