Home » Eclipse Projects » Rich Client Platform (RCP) » Resource Perspective diplays nothing...
Resource Perspective diplays nothing... [message #450313] Thu, 01 June 2006 11:24 Go to next message
Originally posted by: cboudjennah.hotmail.com
Hi everybody!I’m developing a RCP application which uses workspaces and I
have a problems: the clients may use the resources perspective (they used
it when we gave them the plug in version of the application…) and now, in
RCP mode, the resource perspective displays NOTHING!!!I don’t understand
why… LCould someone please help me?Thanks by advance!!!
Re: Resource Perspective diplays nothing... [message #450315 is a reply to message #450313] Thu, 01 June 2006 12:32 Go to previous messageGo to next message
C. BOUDJENNAH wrote:
> Hi everybody!I�m developing a RCP application which uses workspaces and
> I have a problems: the clients may use the resources perspective (they
> used it when we gave them the plug in version of the application�) and
> now, in RCP mode, the resource perspective displays NOTHING!!!I don�t
> understand why� LCould someone please help me?Thanks by advance!!!
The resource perspective includes a lot of the org.eclipse.ui plugins,
include org.eclipse.ui.ide. Do you have any errors in your
<workspace>/.metadata/.log file?
Do you include org.eclipse.ui.views, org.eclipse.ui.ide, etc?
Later,
PW
Re: Resource Perspective diplays nothing... [message #450325 is a reply to message #450315] Fri, 02 June 2006 04:52 Go to previous messageGo to next message
I included all those plugins...
But in the log file, I have those errors when I switch to the resources
perspective:
ENTRY org.eclipse.ui 4 4 2006-06-02 10:49:44.812
!MESSAGE Invalid Menu Extension (Path is invalid): goToResource
!ENTRY org.eclipse.ui 4 4 2006-06-02 10:49:44.828
org.eclipse.ui.OpenWorkspaceFile
But I think it comes from tha fact that some plugins are trying to add
actions to some menus which don't exist in my RCP product...don't you
think?
Re: Resource Perspective diplays nothing... [message #450397 is a reply to message #450325] Fri, 02 June 2006 08:36 Go to previous messageGo to next message
> perspective:
> think?
That is what those messages mean, but they are warnings and won't effect
the perspective. They are indicitive of the the fact that you are
missing some plugins, though.
The WorkbenchActionBuilder adds a menu manager for
IWorkbenchActionConstants.M_NAVIGATE ... adding that might get rid of
these warnings.
Later,
PW
Re: Resource Perspective diplays nothing... [message #450399 is a reply to message #450397] Fri, 02 June 2006 08:55 Go to previous messageGo to next message
And about my resources perspective which displays nothing, do you have any
idea?
Re: Resource Perspective diplays nothing... [message #450401 is a reply to message #450399] Fri, 02 June 2006 09:07 Go to previous messageGo to next message
What does a reset perspective on the resource perspective do? What if
you switch your RCP app to a new workspace? (or delete all of your
workspace contents, including the .metadata directory, although make a
backup first).
What are ALL the entries in your error log? Usually the errors at the
beginning lead to the errors at the end.
Later,
PW
Re: Resource Perspective diplays nothing... [message #450403 is a reply to message #450401] Fri, 02 June 2006 09:59 Go to previous messageGo to next message
A reset perspective does nothing, but I think I didn't express myself very
well: my problem is not that the prespective displays nothing: I have all
the views well displayed...But in the Navigator View, I can't see
anything! It is totally empty!!!
My logs when I launch the application and switch to resources perspective
are those:
!SESSION 2006-06-02 15:53:49.531
eclipse.buildId=unknown
java.version=1.5.0_07
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=fr_FR
Command-line arguments: -os win32 -ws win32 -arch x86 -clean
!ENTRY org.eclipse.core.resources 2 10035 2006-06-02 15:53:53.218
!MESSAGE A workspace crash was detected. The previous session did not exit
normally.
!ENTRY org.eclipse.ui 4 4 2006-06-02 15:53:55.843
org.eclipse.ui.edit.text.gotoLastEditPosition
Re: Resource Perspective diplays nothing... [message #450404 is a reply to message #450403] Fri, 02 June 2006 10:23 Go to previous messageGo to next message
Ah, so first of all you have to make sure you have a workspace? Do you
have access to ResourcesPlugin.getWorkspace().getRoot()?
Secondly, you have to update your defaultPageInput() on one of the
advisors to return ResourcesPlugin.getWorkspace().getRoot()
I was told the default input to those kinds of navigators is the
page.getInput(), which is set upon workbench window/page creation time.
Later,
PW
Re: Resource Perspective diplays nothing... [message #450455 is a reply to message #450404] Fri, 02 June 2006 13:53 Go to previous messageGo to next message
> Later,
> PW
Hi Paul,
I have this same problem... I did what you said, and now its appearing the
dots (...) in the navigator view, like when a folder would be visualized.
But instead of the folder I get the error "!MESSAGE Problems occurred when
invoking code from plug-in: "org.eclipse.jface".!STACK 0
org.eclipse.core.runtime.AssertionFailedException: null argument:", and no
image or text is shown.
the .log file is attached bellow.
Do you know why?
Thanks in advance,
Liana
!SESSION 2006-06-02 14:49:25.691
java.version=1.5.0_03
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=pt_BR
Framework arguments: -product org.rise.prototipo -pdelaunch
Command-line arguments: -product org.rise.prototipo -data
D:\eclipseRC6\workspace/../runtime-EclipseApplication -dev
file:D:/eclipseRC6/workspace/.metadata/.plugins/org.eclipse. pde.core/Eclipse
Application/dev.properties -pdelaunch -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.core.resources 2 10035 2006-06-02 14:49:29.598
normally.
!ENTRY org.eclipse.jface 4 2 2006-06-02 14:49:32.973
!MESSAGE Problems occurred when invoking code from plug-in:
!STACK 0
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:84)
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:72)
org.eclipse.ui.internal.navigator.extensions.NavigatorConten tExtension. <init>(NavigatorContentExtension.java:87)
org.eclipse.ui.internal.navigator.NavigatorContentService.ge tExtension(NavigatorContentService.java:842)
org.eclipse.ui.internal.navigator.NavigatorContentService.ge tExtension(NavigatorContentService.java:812)
org.eclipse.ui.internal.navigator.NavigatorContentServiceLab elProvider.findUpdateLabel(NavigatorContentServiceLabelProvi der.java:330)
org.eclipse.ui.internal.navigator.NavigatorContentServiceLab elProvider.updateLabel(NavigatorContentServiceLabelProvider. java:307)
org.eclipse.jface.viewers.DecoratingLabelProvider.updateLabe l(DecoratingLabelProvider.java:345)
org.eclipse.jface.viewers.StructuredViewer.buildLabel(Struct uredViewer.java:2077)
at org.eclipse.jface.viewers.TreeViewer.doUpdateItem(TreeViewer .java:247)
org.eclipse.jface.viewers.AbstractTreeViewer$UpdateItemSafeR unnable.run(AbstractTreeViewer.java:95)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:843)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 9)
org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:840)
org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRun nable.run(StructuredViewer.java:465)
org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct uredViewer.java:1955)
org.eclipse.jface.viewers.AbstractTreeViewer.createTreeItem( AbstractTreeViewer.java:744)
org.eclipse.ui.navigator.CommonViewer.createTreeItem(CommonV iewer.java:116)
org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractT reeViewer.java:722)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.jface.viewers.AbstractTreeViewer.createChildren( AbstractTreeViewer.java:696)
org.eclipse.jface.viewers.TreeViewer.createChildren(TreeView er.java:872)
org.eclipse.jface.viewers.AbstractTreeViewer$5.run(AbstractT reeViewer.java:1277)
org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1323)
org.eclipse.jface.viewers.AbstractTreeViewer.inputChanged(Ab stractTreeViewer.java:1266)
org.eclipse.jface.viewers.ContentViewer.setInput(ContentView er.java:250)
org.eclipse.jface.viewers.StructuredViewer.setInput(Structur edViewer.java:1542)
org.eclipse.ui.navigator.CommonNavigator.createPartControl(C ommonNavigator.java:156)
org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:332)
org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:197)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:566)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:29 0)
at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:52 5)
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:140)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:394)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1144)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1097)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:13 11)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:601)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:532)
org.eclipse.ui.internal.PartSashContainer.createControl(Part SashContainer.java:562)
org.eclipse.ui.internal.PerspectiveHelper.activate(Perspecti veHelper.java:244)
at org.eclipse.ui.internal.Perspective.onActivate(Perspective.j ava:815)
org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPa ge.java:2429)
org.eclipse.ui.internal.WorkbenchWindow$6.run(WorkbenchWindo w.java:2616)
org.eclipse.ui.internal.WorkbenchWindow.setActivePage(Workbe nchWindow.java:2597)
org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(Workben chWindow.java:658)
org.eclipse.ui.internal.Workbench.busyOpenWorkbenchWindow(Wo rkbench.java:795)
org.eclipse.ui.internal.Workbench.doOpenFirstTimeWindow(Work bench.java:1437)
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1388)
org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWin dow(WorkbenchConfigurer.java:190)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:708)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1085)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1847)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.rise.prototipo.toolday.intro.Application.run(Application .java:18)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
!ENTRY org.eclipse.ui 4 4 2006-06-02 14:49:34.691
!MESSAGE Invalid Menu Extension (Path is invalid): converstLineDelimitersTo
!ENTRY org.eclipse.ui 4 4 2006-06-02 14:49:34.801
org.eclipse.ui.edit.text.delimiter.macOS9
org.eclipse.ui.edit.text.delimiter.unix
org.eclipse.ui.edit.text.delimiter.windows
org.eclipse.ui.edit.text.openExternalFile
!ENTRY org.eclipse.ui 4 4 2006-06-02 14:49:34.816
!MESSAGE Invalid Menu Extension (Path is invalid): selectWorkingSets
!ENTRY org.eclipse.ui 4 4 2006-06-02 14:49:34.832
Re: Resource Perspective diplays nothing... [message #450463 is a reply to message #450397] Fri, 02 June 2006 20:02 Go to previous messageGo to next message
>> resources perspective:
>> think?
> these warnings.
> Later,
> PW
There is also some adapter registering that needs to be included in your
RCP startup code to make the Navigator actually show item names. Or
there used to be. Here's a link to one old post about it.
http://dev.eclipse.org/newslists/news.eclipse.platform.rcp/m sg02902.html
You can find others searching this newsgroup for "Navigator"
Re: Resource Perspective diplays nothing... [message #450567 is a reply to message #450404] Mon, 05 June 2006 03:15 Go to previous messageGo to next message
I have access to the ResourcesPlugin.getWorkspace().getRoot() method, but
it returns in my case "R/" which is a disk that doesn't exist...!
About the "defaultPageInput()" method, I don't know in which class you can
find it and overload it...
CB
Re: Resource Perspective diplays nothing... [message #450568 is a reply to message #450463] Mon, 05 June 2006 04:09 Go to previous messageGo to next message
>>> think?
>> these warnings.
>> Later,
>> PW
Thanks!
I watched this and I found this solution: oveload prestartup in my
WokbenchAdvisor with this:
WorkbenchAdapterBuilder.registerAdapters();
super.preStartup();
The problem is that WorkbenchAdapterBuilder is an internal class of
Eclipse and using it is not very clean???:-(
I think I'm going to add a class to my product which does the same thing
and use it...
What do you think about it?
Re: Resource Perspective diplays nothing... [message #450569 is a reply to message #450568] Mon, 05 June 2006 04:17 Go to previous messageGo to next message
>>>> think?
>>> these warnings.
>>> Later,
>>> PW
> Thanks!
> super.preStartup();
> and use it...
I started to add classes to my product to do the same thing as internal
packages of Eclipse, but it seems that I will have to copy almost all of
the org.eclipse.ui.internal.ide.model package... :-(
Does anyone know if there is a "cleaner" way to do that??
C.B.
Re: Resource Perspective diplays nothing... [message #450570 is a reply to message #450455] Mon, 05 June 2006 08:23 Go to previous messageGo to next message
you probably need to override WorkbenchAdvisor#initialize(*) and add:
WorkbenchAdvisor is also where you override getDefaultPageInput().
Check out IDEWorkbenchAdvisor in the org.eclipse.ui.ide plugin.
Later,
PW
Re: Resource Perspective diplays nothing... [message #450571 is a reply to message #450567] Mon, 05 June 2006 08:24 Go to previous messageGo to next message
> but it returns in my case "R/" which is a disk that doesn't exist...!
That's OK, R/ is the root, and IWorkspaceRoot object, it's not a disk or
normal file.
> can find it and overload it...
It's on your WorkbenchAdvisor class.
Later,
PW
Re: Resource Perspective diplays nothing... [message #450664 is a reply to message #450570] Tue, 06 June 2006 15:43 Go to previous message
> Later,
> PW
Hi Paul,
Thanks it works...
however the project icon doesn't appear.
I looked the IDEWorkbenchAdvisor and tried to refer the same icon it does
for the project, but it is not possible because is a internal class.
Do know another way?
Thanks again,
Liana
Previous Topic:How to create empty workbench
Next Topic:About RCP launcher (Eclipse.exe)
Current Time: Tue Nov 04 00:37:59 EST 2025
Powered by FUDForum. Page generated in 0.48294 seconds
