Home » Eclipse Projects » Standard Widget Toolkit (SWT) » How to convert a java String into a pointer
How to convert a java String into a pointer [message #450056] |
Mon, 07 February 2005 09:40 |
kite Messages: 34 Registered: July 2009 |
Member |
Hi ,
I have try to use OS class to access my win32 dll , I can successfully for
most case using SendMessage method ,but when I want to wParam as a String
, I cann't. Maybe I need to convert a java string as a pointer (java int)
, anyone know how to convert a java string as a sz String pointer? For
example ,
my dll code snippet is :
case SCI_SETPROPERTY:
props.Set(reinterpret_cast<const char
*>(wParam),reinterpret_cast<const char *>(lParam));
break;
My java code is :
OS.SendMessage(int hwnd,int msg,int wParam,byte[] lParam);
Thanks.
Re: How to convert a java String into a pointer [message #450061 is a reply to message #450056] |
Mon, 07 February 2005 11:55 |
Robert Bacs Messages: 165 Registered: July 2009 |
You need to convert your String object in TCHAR object, just create a TCHAR
object using TCHAR (int codePage, String string, boolean terminate)
constructor, and then when you need a pointer just access the chars member
(for Unicode) or bytes member (for non-Unicode).
Boby
"Kite" <yipeng97@yahoo.com> wrote in message
news:cu7d1n$a4s$1@www.eclipse.org...
> Hi ,
> example ,
> break;
> My java code is :
> Thanks.
Re: How to convert a java String into a pointer [message #450094 is a reply to message #450061] |
Mon, 07 February 2005 20:17 |
Steve Northover Messages: 1636 Registered: July 2009 |
Be warned that you are using internal API that is subject to change. For
example, TCHAR was added around 2.0.
"Robert Bacs" <boby@zerosoft.ro> wrote in message
news:cu7kvl$beg$1@www.eclipse.org...
TCHAR
> Boby
> > Hi ,
for
String
int)
> > example ,
> > break;
> > My java code is :
> > Thanks.
Re: How to convert a java String into a pointer [message #450103 is a reply to message #450061] |
Tue, 08 February 2005 05:05 |
Member |
Hi , Robert
Thanks for your answer. I have try it , but I need a int value to
represent a pointer because OS.SendMessage(int hwnd,int msg,int wParam,int
lParam) method need a int value for wParam , so if no other approach to
do these , we have to modify c++ code.
Thanks.
Robert Bacs wrote:
> Boby
>> Hi ,
>> example ,
>> break;
>> My java code is :
>> Thanks.
Re: How to convert a java String into a pointer [message #450105 is a reply to message #450103] |
Tue, 08 February 2005 10:12 |
If you use the OS from SWT you can call the
SendMessage (int hWnd, int Msg, int wParam, TCHAR lParam)
method (this is much more simple), but if you want to implement yourself the
JNI method then you should do the following:
- declare two native methods:
public static final native int SendMessageA (int hWnd, int Msg, int
wParam, byte [] lParam);
public static final native int SendMessageW (int hWnd, int Msg, int
wParam, char [] lParam); // for unicode version
- declare a Java method:
public static final int SendMessage (int hWnd, int Msg, int wParam,
TCHAR lParam) - this will call the native methods
- in your JNI code you will need to convert your bytearray argument in a
pointer - you will use the GetByteArrayElements() method for this.
If you need help for the above steps you can look at the SWT source code: OS
class and JNI code os.c file.
Hope this helps !
Boby
news:cu9hbj$4hv$1@www.eclipse.org...
> Hi , Robert
> Thanks.
> Robert Bacs wrote:
> > Hi,
TCHAR
member
> > Regards,
> > Boby
> >> Hi ,
for
String
int)
> >> example ,
> >> break;
> >> My java code is :
> >> Thanks.
Re: How to convert a java String into a pointer [message #450441 is a reply to message #450105] |
Sat, 12 February 2005 03:20 |
Member |
Hi ,
Thanks. I have tried all method SendMessage(). My question is not about
lParam , yes , I can use byte[] , TCHAR to pass my java String. But MY
QUESTION IS ABOUT - wParam , how to send a java String as int?
Thanks.
Robert Bacs wrote:
> Hope this helps !
> Boby
>> Hi , Robert
>> Thanks.
>> Robert Bacs wrote:
>> > Hi,
> TCHAR
> member
>> > Regards,
>> > Boby
>> >> Hi ,
> for
> String
> int)
>> >> example ,
>> >> break;
>> >> My java code is :
>> >> Thanks.
Current Time: Sun May 05 14:22:37 GMT 2024
Powered by FUDForum. Page generated in 0.04454 seconds
