Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Problems with TreeItem.getItems()
Re: Problems with TreeItem.getItems() [message #449670 is a reply to message #449667] |
Thu, 27 January 2005 17:54 |
Devin Steffler Messages: 7 Registered: July 2009 |
This might be of some help (or part of the problem):
My view has a "refresh" button. When it is clicked, I create a new
ViewContentProvider (identical to the previous content provider, just a new
object) and update the viewer's content provider with it.
Then I want to traverse the TreeItems and set the expanded state based on
information from the previous expanded elements (retrieved via
viewer.getExpandedElements()).
Does setting the content provider to a new ViewContentProvider create any
problems with the TreeViewer, Tree, or the Tree's TreeItems?
Devin Steffler
IBM's Eclipse CDT
Ottawa (Palladium), Ontario, Canada
"Devin Steffler" <devin_steffler@ca.ibm.com> wrote in message
news:ctb7pd$31p$1@www.eclipse.org...
> I created a new view that uses a TreeViewer. I want to traverse through
the
> TreeItems in the Tree and programmatically setExpanded(true) for certain
> TreeItems.
> The Tree contains the items:
> [0]= TreeItem {IASTTranslationUnit} // this should contain several more
> TreeItems underneath it but I can't figure out how to get to them and
> getItems() doesn't seem to work
> [1]= TreeItem {}
> The first TreeItem[0]#setExpanded(true) works fine, but then I want to
> setExpanded(true) for some of the TreeItems underneath it. So I do the
> following:
> TreeItem[0].getItems() to get the TreeItems under that specific TreeItem
> (assuming this is what is supposed to happen based on the spec). Here's
> what the spec says:
> TreeItem#getItems()
> Returns an array of TreeItems which are the direct item children
> of the receiver.
> When I call this, getItems() returns an array of TreeItems that only has
one
> element (the TreeItem[1] above displayed as TreeItem{}).
> Is the TreeItem.getItems() supposed to return the TreeItems that are
> children to the TreeItem? Is this a bug? Are there alternatives that I
> could use? I started looking at using the TableTreeViewer but saw that it
> will be deprecated for Eclipse 3.1M5. Any suggestions?
> Devin Steffler
> IBM's Eclipse CDT
Re: Problems with TreeItem.getItems() [message #449680 is a reply to message #449670] |
Thu, 27 January 2005 21:06 |
Veronika Irvine Messages: 1272 Registered: July 2009 |
Your best source for answers about JFace is the eclipse.platform newsgroup:
news://news.eclipse.org/eclipse.platform
That being said, I think you might need to call the refresh method on the
TreeViewer after you have changed the content provider.
news:ctb9tj$hmn$1@www.eclipse.org...
> new
> Devin Steffler
> IBM's Eclipse CDT
> the
>> TreeItems.
>> [1]= TreeItem {}
>> following:
>> what the spec says:
>> TreeItem#getItems()
>> children
>> of the receiver.
> one
>> it
>> Thanks,
>> Devin Steffler
>> IBM's Eclipse CDT
Re: Problems with TreeItem.getItems() [message #449727 is a reply to message #449680] |
Fri, 28 January 2005 13:56 |
Thanks for your help Veronika. Your suggestion didn't seem to work though.
I'll try posting my problem to eclipse.platform and see what happens.
Here's a copy of the code I'm using (maybe something obvious will jump out
at you :)
public void run() {
// take a snapshot of the current tree expansion
Object[] expandedElements = viewer.getExpandedElements();
// set the new content provider
viewer.setContentProvider(new ViewContentProvider(file));
viewer.refresh(); // suggested to help fix the problem, didn't work
// set the expansion of the new view based on the original snapshot
Tree tree = viewer.getTree();
if (expandedElements.length > 0) {
expandTreeIfNecessary(tree.getItems(), expandedElements);
viewer.refresh();
private void expandTreeIfNecessary(TreeItem[] treeItems, Object[]
expandedElements) {
for (int i=0; i<treeItems.length; i++) {
for (int j=0; j<expandedElements.length; j++) {
// if the items are a "close enough" match then expand the new TreeItem
if (treeItems[i].getData() instanceof TreeObject &&
expandedElements[j] instanceof TreeObject &&
((TreeObject)treeItems[i].getData()).getFilename().equals((( TreeObject)expan
dedElements[j]).getFilename()) &&
((TreeObject)treeItems[i].getData()).toString().equals(((Tre eObject)expanded
Elements[j]).toString())) {
treeItems[i].setExpanded(true);
// determine if children need to be expanded or not
expandTreeIfNecessary(treeItems[i].getItems(), expandedElements);
// the treeItems[i].getItems() seems problematic as it returns a TreeItem[1]
with a null data object
"Veronika Irvine" <veronika_irvine@oti.com> wrote in message
news:ctbl6b$2lb$1@www.eclipse.org...
newsgroup:
> > new
on
any
> > Thanks,
> > Devin Steffler
> > IBM's Eclipse CDT
through
> > the
certain
> >> TreeItems.
> >> [1]= TreeItem {}
> >> following:
TreeItem
Here's
> >> what the spec says:
> >> TreeItem#getItems()
> >> children
> >> of the receiver.
has
> > one
I
> >> it
> >> Thanks,
> >> Devin Steffler
> >> IBM's Eclipse CDT
Current Time: Tue Sep 24 15:54:00 GMT 2024
Powered by FUDForum. Page generated in 0.03040 seconds
