Re: How do I change a button background color ??? [message #449550 is a reply to message #449544] |
Wed, 26 January 2005 10:14 |
Originally posted by: gilblais.yahoo.com
Matt - thank you, but when I do that I end up with the entire display having
its color changed instead of just the button. Here are the lines of code:
final Button btnCAS = new Button(shell, SWT.NONE);
btnCAS.setSelection(true);
btnCAS.getParent().setBackground(Display.getCurrent().getSys temColor(SWT.COLOR_RED));
"Matthew Ma" <matthew1801@hotmail.com> wrote in message
news:ct7nqn$v56$1@www.eclipse.org...
> Button is inherited from Control, so you can use the setBackground(Color
> color) function - under Control - to change the background color of the
> button.
> Matthew
> "Gil Blais" <gilblais@yahoo.com> wrote in message
> news:ct7n84$sms$1@www.eclipse.org...
>> I cannot seem to display anything but a gray button with black
>> lettering -
>> any help is well appreciated. Thanks, Gil Blias
Re: How do I change a button background color ??? [message #449552 is a reply to message #449550] |
Wed, 26 January 2005 12:55 |
Originally posted by: armin.roth.visana.ch
Hi Gil
Use this instead:
btnCAS.setBackground(Display.getCurrent().getSystemColor(SWT .COLOR_RED));
the .getParent() made you change the buttons parent (the shell you used
for constructing the button) background color.
Be aware of that Display.getCurrent() may deliver null if this code is
running outside of the SWT-Thread.
Kind regards,
Armin Roth
>> button.
>> Matthew
>>> lettering -
Re: How do I change a button background color ??? [message #449720 is a reply to message #449552] |
Fri, 28 January 2005 08:41 |
Hi Armin - thank you, but that result was the same. Here is the code snippet
I am using.
--- cut here ---
package UI;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.SWT;
import org.eclipse.swt.widgets.Button;
public class PB_xxx implements INTERFACES.IF {
new PB_xxx().runTHIS(new String[] { });
void runTHIS(String[] args) {
Display display = new Display();
final Shell shell = new Shell(display);
shell.setSize(395,80);
btnCAS.setText("Contracting Administration Screen");
btnCAS.setForeground(Display.getCurrent().getSystemColor(SWT .COLOR_RED));
// left,top,width,height
btnCAS.setBounds(10, 10, 360, 30);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) display.sleep();
--- end ---
"Armin Roth" <armin.roth@visana.ch> wrote in message
news:ct83vh$jdu$1@www.eclipse.org...
> Hi Gil
> Use this instead:
> Kind regards,
> Armin Roth
>> having its color changed instead of just the button. Here are the lines
>> of code:
>>> button.
>>> Matthew
>>>> lettering -
FUDForum. Page generated in 0.03346 seconds
