Home » Archived » BIRT » PDF format with ReportRunner
PDF format with ReportRunner [message #45226] Mon, 13 June 2005 06:36 Go to next message
Originally posted by: juergen.schwarz.gefasoft.de
I tried to generate a report using the ReportRunner but when specifying
the PDF format he tells me that this is not supported (HTML works).
Strangely via the Eclipse plugin it works in PDF.
Anything else I have to specify for the ReportRunenr to make PDF?
Re: PDF format with ReportRunner [message #54143 is a reply to message #45226] Wed, 06 July 2005 03:49 Go to previous messageGo to next message
Originally posted by: Dirk.Ecker.viadee.de
Try to get the following jars in lib of the CVS repository of birt
org.eclipse.birt.report.engine.emitter.fop
- avalon-framework-cvs-20020806.jar
- batik.jar
Then it works!
But I also want to know, what I am doing wrong? Missed a official jar?
Dirk
Re: PDF format with ReportRunner [message #54856 is a reply to message #54143] Thu, 07 July 2005 10:49 Go to previous message
Okay, the correct way is to take the jars from the plugin directory:
org.eclipse.birt.report.engine.emitter.fo\lib
Dirk
Previous Topic:"Newbie" Help -- Development with Milestones / Custom Data Sources
Next Topic:Can't set margins of the master-page
Current Time: Fri Nov 07 01:30:15 EST 2025
Powered by FUDForum. Page generated in 0.04273 seconds
