Home » Eclipse Projects » Rich Client Platform (RCP) » context menu for component within an editor
context menu for component within an editor [message #448853] Fri, 05 May 2006 06:05 Go to next message
I try to create a context menu for only one component (TableViewer)
within an editor. This is the code so far:
(within the editor class)
private void hookContextMenu(Composite composite) {
MenuManager menuMgr = new MenuManager("#PopupMenu",
"de.myEditorId.menu1");
menuMgr.setRemoveAllWhenShown(true);
menuMgr.addMenuListener(new IMenuListener() {
public void menuAboutToShow(IMenuManager manager) {
manager.add(new Separator(IWorkbenchActionConstants.MB_ADDITIONS));
Menu attributeTabMenu = menuMgr.createContextMenu(composite);
attributeTableViewer.getControl().setMenu(attributeTabMenu);
getSite().registerContextMenu("de.myEditorId.menu1", menuMgr,
attributeTableViewer);
And this is the interesting part of the plugin.xml:
<extension
point="org.eclipse.ui.popupMenus">
<viewerContribution
id="de.myEditorId.viewerContribution1"
targetID="de.myEditorId">
<action
class="de.myAction"
enablesFor="*"
icon="icons/attribute_add.gif"
id="de.myAction"
label="Attribut anlegen"
menubarPath="de.myEditorId.menu1/attribute"
style="push"/>
</viewerContribution>
</extension>
Neither is the menu showing, nor is any error message in the log, if I
rightclick the component.
Do I have to configure a corresponding menu in the plugin.xml? Where do
I have to put in the id from the editor and where the id from the menu?
I was wondering if anybody got an example?
Thanks in advance!
Alex
Re: context menu for component within an editor [message #448895 is a reply to message #448853] Sat, 06 May 2006 11:19 Go to previous messageGo to next message
Alexander Grigo wrote:
> Hello,
> <extension
> <viewerContribution
> <action
> class="de.myAction"
> enablesFor="*"
> id="de.myAction"
> style="push"/>
> </extension>
AFAIK, you need to have your target ID match your context menu id that
it was registered with, de.myEditorId.menu1
and your menubarPath is then w.r.t your context menu ... I'd use "additions"
Later,
PW
Re: context menu for component within an editor [message #448975 is a reply to message #448895] Mon, 08 May 2006 07:15 Go to previous message
>> Hello,
>> manager.add(new
>> Separator(IWorkbenchActionConstants.MB_ADDITIONS)); }
>> menuMgr, attributeTableViewer);
>> <extension
>> <viewerContribution
>> <action
>> class="de.myAction"
>> enablesFor="*"
>> id="de.myAction"
>> style="push"/>
>> </extension>
> "additions"
> Later,
> PW
thanks for your help. You were absolutely right. I just put in
"de.myEditorId.menu1" as the targetID and "additions" as the
menubarPath" and it worked.
Alex
Previous Topic:Making another project into a plugin
Next Topic:How to programmatically add a shortcut to the perspective switching bar ...
Current Time: Thu Nov 06 18:04:09 EST 2025
Powered by FUDForum. Page generated in 0.04030 seconds
