Home » Eclipse Projects » Rich Client Platform (RCP) » whats the best way to update a library plugin?
whats the best way to update a library plugin? [message #448674] Thu, 27 April 2006 21:24 Go to next message
I created a library plugin that only has jar files
in it. Now I want to add new jar files to it. What is the
best way to do that?
thanks,
Re: whats the best way to update a library plugin? [message #449075 is a reply to message #448674] Wed, 10 May 2006 06:53 Go to previous message
Easiest way is just to copy them into the lib/ directory through drag-and-drop, or alternatively use the File -> Import to pull the Jars in.
You'll also need to update the manifest.mf/build.properties to add them to the included jars list; or you can edit it by hand to achieve the same effect.
alex.
Previous Topic:Regarding organizing classes and projects for a RCP Application
Next Topic:Remote Debugging
Current Time: Thu Nov 06 09:09:48 EST 2025
Powered by FUDForum. Page generated in 0.07413 seconds
