Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Removing items from TableTree
Re: Removing items from TableTree [message #448454 is a reply to message #448399] |
Mon, 10 January 2005 16:26 |
Kalman Hazins Messages: 76 Registered: July 2009 |
Member |
Veronika saves the day again ...
Let me restate the question.
I have a bunch of rows from the database, which I am displaying in my table.
I really wanted to display the primary key column (some id) as a hyperlink,
so that when a user clicks on it - he can go to a different screen and view
the row.
Now, my question was once I place a control (hyperlink in my case) into the
table, and then later decide to delete the row from the table, how would I
get to the editor (hyperlink) and delete it.
Are you saying that I would need to keep a reference to the
editors(hyperlinks) in some vector and then loop thru them to find out
which tabletreeitem they are part of and then delete them? There's got to be
a better way of doing this, no?
Thanx,
- Kalman
P.S. I checked out TableTreeViewer and I really like the MVC approach to
displaying and deleting things from the table, but I think I am still going
to have a problem with deleting hyperlinks ...
"Veronika Irvine" <veronika_irvine@oti.com> wrote in message
news:crmukj$aqr$1@www.eclipse.org...
> To remove a TableTreeItem just call dispose on the TableTreeItem.
> You must clean up the TableTreeEditor yourself. If you want to keep the
> same TableTreeEditor for other items, set the item to null
> (TableTreeEditor.setItem(null)) before disposing the TableTreeItem.
> You can get the TableTreeItem associated with a TableTreeEditor using
> TableTreeEditor.getItem.
> "Kalman" <kalman@zikal.com> wrote in message
> news:crmo53$jqk$1@www.eclipse.org...
> > Hi, group.
> > How do I remove items from TableTree? So, say I have a TableTree with 3
> > nodes, which themselves have 3 nodes each. I simply want to delete all
> > nodes
> > under a "root" node when the particular "root" node is clicked.
> > Any ideas?
> > Also, if I am using TableTreeEditor is there a way to know which
> > TableTreeEditor is associated with which TableTreeItem (because when I
> > dispose() of the TableTreetem, the Editor still displays)
> > Any help is appreciated,
> > - Kalman
Re: Removing items from TableTree [message #448542 is a reply to message #448454] |
Tue, 11 January 2005 20:29 |
Veronika Irvine Messages: 1272 Registered: July 2009 |
You could use something like TableTreeItem.setData("TableTreeEditor",
editor) and TableTreeItem.getData("TableTreeEditor") to manage the
association.
news:cruaak$i7o$1@www.eclipse.org...
> table.
> hyperlink,
> view
> the row.
> the
> be
> Thanx,
> - Kalman
> going
>> > Hi, group.
>> > nodes
>> > Any ideas?
>> > - Kalman
Re: Removing items from TableTree [message #448607 is a reply to message #448542] |
Tue, 11 January 2005 22:04 |
Member |
cute ... thanx, that should do it ...
news:cs1d0o$t3n$1@www.eclipse.org...
> association.
> > table.
> > hyperlink,
> > view
> > the row.
> > the
I
to
> > be
> > Thanx,
> > - Kalman
> > going
the
> >> > Hi, group.
3
all
> >> > nodes
> >> > Any ideas?
I
> >> > - Kalman
Current Time: Tue May 14 19:25:10 GMT 2024
Powered by FUDForum. Page generated in 0.04195 seconds
