Test11743 error [message #45162] |
Thu, 07 August 2008 02:25 |
Originally posted by: 322zx.163.com
When I tested the test11743 ,the result was failed.The errors was
following:
[DEBUG][BuilderUtil.java:276] char set encoding set from default =UTF-8
[DEBUG][Wire.java:83] << "l version='1.0'
encoding='UTF-8'?><soapenv:Envelope
xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/"><soapenv:Body><soapenv:Fault><faultcode>soapenv:Client</faultcode ><faultstring>The
endpoint reference (EPR) for the Operation not found is
http://localhost:9080/axis2/services/xdsrepositoryb and the WSA Action =
urn:anonOutInOp</faultstring><detail
/></soapenv:Fault></soapenv:Body></soapenv:Envelope>"
[DEBUG][AxisEngine.java:116] [MessageContext:
logID=urn:uuid:A2C934E3F6902C8C701218075202493]
receive:urn:uuid:6d65a064-0d60-7404-2132-001d7dab48a4
[DEBUG][Phase.java:269] [MessageContext:
logID=urn:uuid:A2C934E3F6902C8C701218075202493] Checking pre-condition for
Phase "Addressing"
[DEBUG][Phase.java:282] [MessageContext:
logID=urn:uuid:A2C934E3F6902C8C701218075202493] Invoking phase "Addressing"
[DEBUG][Phase.java:289] [MessageContext:
logID=urn:uuid:A2C934E3F6902C8C701218075202493] Invoking Handler
'AddressingBasedDispatcher' in Phase 'Addressing'
[DEBUG][Phase.java:303] [MessageContext:
logID=urn:uuid:A2C934E3F6902C8C701218075202493] Checking post-conditions
for phase "Addressing"
Phase "Security"
logID=urn:uuid:A2C934E3F6902C8C701218075202493] Invoking phase "Security"
for phase "Security"
Phase "PreDispatch"
"PreDispatch"
for phase "PreDispatch"
Phase "Dispatch"
logID=urn:uuid:A2C934E3F6902C8C701218075202493] Invoking phase "Dispatch"
'RequestURIBasedDispatcher' in Phase 'Dispatch'
'SOAPActionBasedDispatcher' in Phase 'Dispatch'
'RequestURIOperationDispatcher' in Phase 'Dispatch'
'SOAPMessageBodyBasedDispatcher' in Phase 'Dispatch'
'HTTPLocationBasedDispatcher' in Phase 'Dispatch'
for phase "Dispatch"
Phase "RMPhase"
logID=urn:uuid:A2C934E3F6902C8C701218075202493] Invoking phase "RMPhase"
for phase "RMPhase"
Phase "OperationInPhase"
"OperationInPhase"
for phase "OperationInPhase"
[DEBUG][Phase.java:315] [MessageContext:
logID=urn:uuid:A2C934E3F6902C8C701218075202493] Invoking flowComplete() in
Phase "RMPhase"
Phase "Dispatch"
[DEBUG][Phase.java:334] [MessageContext:
for Handler 'HTTPLocationBasedDispatcher' in Phase 'Dispatch'
for Handler 'SOAPMessageBodyBasedDispatcher' in Phase 'Dispatch'
for Handler 'RequestURIOperationDispatcher' in Phase 'Dispatch'
for Handler 'SOAPActionBasedDispatcher' in Phase 'Dispatch'
for Handler 'RequestURIBasedDispatcher' in Phase 'Dispatch'
Phase "PreDispatch"
Phase "Security"
Phase "Addressing"
for Handler 'AddressingBasedDispatcher' in Phase 'Addressing'
[ERROR][Source.java:196] Error sending SOAP message to the repository.
Error was Error Sending SOAP Message.
org.eclipse.ohf.ihe.common.ws.OHFSOAPException: Error Sending SOAP
Message. [Caused by org.apache.axis2.AxisFault: The endpoint reference
http://129.6.24.109:9080:9080/axis2/services/xdsrepositoryb and the WSA
Action = urn:anonOutInOp]
at
org.eclipse.ohf.ihe.common.ws.AbstractOHFSOAPSender.executeS end(AbstractOHFSOAPSender.java:251)
at
org.eclipse.ohf.ihe.common.ws.AbstractOHFSOAPSender.send(Abs tractOHFSOAPSender.java:363)
at
org.eclipse.ohf.ihe.common.ws.AbstractOHFSOAPSender.send(Abs tractOHFSOAPSender.java:384)
at
org.eclipse.ohf.ihe.xds.soap.AbstractXDSSoapClient.send(Abst ractXDSSoapClient.java:148)
at
org.eclipse.ohf.ihe.xds.soap.AbstractXDSSoapClient.send(Abst ractXDSSoapClient.java:104)
at org.eclipse.ohf.ihe.xds.source.Source.submit(Source.java:193 )
at
org.eclipse.ohf.ihe.xds.source.test.mesa.Mesa11743.test(Mesa 11743.java:117)
at
org.eclipse.ohf.ihe.xds.source.test.mesa.Mesa11743.main(Mesa 11743.java:135)
Caused by: org.apache.axis2.AxisFault: The endpoint reference (EPR) for
urn:anonOutInOp
at
org.apache.axis2.util.Utils.getInboundFaultFromMessageContex t(Utils.java:486)
at
org.apache.axis2.description.OutInAxisOperationClient.handle Response(OutInAxisOperation.java:343)
at
org.apache.axis2.description.OutInAxisOperationClient.send(O utInAxisOperation.java:389)
at
org.apache.axis2.description.OutInAxisOperationClient.execut eImpl(OutInAxisOperation.java:211)
at
org.apache.axis2.client.OperationClient.execute(OperationCli ent.java:163)
at
org.eclipse.ohf.ihe.common.ws.AbstractOHFSOAPSender.executeS end(AbstractOHFSOAPSender.java:244)
... 7 more
urn:anonOutInOp]
at
at
at
at
at
at
at
urn:anonOutInOp
at
at
at
at
at
at
... 7 more
Re: Test11743 error [message #45324 is a reply to message #45228] |
Fri, 08 August 2008 01:06 |
The endpoint was wrong,while I pointed to the endpoint that you gave me.
The code run successfully.
Thank you!!
Re: Test11743 error [message #45350 is a reply to message #45162] |
Fri, 08 August 2008 01:37 |
Now I was successful to run the test11743,but I have some puzzles.
The note on the Test11743 says that the test is a TLS test£šSECURE
Submission test.£©£¬but I do not use the
https://129.6.24.109:9443/axis2/services/xdsrepositorya,othe rwile I used
the http://129.6.24.109:9443/axis2/services/xdsrepositorya.
The note is here:
* SECURE Submission test using "pre-cooked" metadata.
* Data for this test is in ./resources/sample_files/test1/
* <br>
* Corresponds to Connectathon 2007-2008 Test: 11743
* <br>
http://ihewiki.wustl.edu/wiki/index.php/XDS_Test_Kit_2007-20 08_Test_Descriptions#11743
* <br>
* You must use a TLS enabled server and set the following environmental
variables
* to run this test:
* <li>'javax.net.ssl.keyStore' to the location of your key store
file</li>
* <li>'javax.net.ssl.keyStorePassword' to the password on your key store
file</li>
* <li>'javax.net.ssl.trustStore' to the location of your trust store
file</li>
* <li>'javax.net.ssl.trustStorePassword' to the password of your trust
store file</li>
* @throws Throwable
Re: Test11743 error [message #45443 is a reply to message #45350] |
Fri, 08 August 2008 17:31 |
Matthew Davis Messages: 269 Registered: July 2009 |
This is correct - 11743 is a TLS test. If you were going to submit
these results for pre-Connectathon MESA test grading, it would also
require the output of a mutual TLS handshake between the client and the
server. By using "http" and not "https", the test is the same as test
11746.
If you are interested in testing TLS, we can provide certificates that
(should) work with the NIST server at https://129.6.24.109:9443.
-Matt
> The note is here:
> * SECURE Submission test using "pre-cooked" metadata. * Data
> * <br>
> * <br>
> * <br>
> environmental variables * to run this test:
> file</li>
> store file</li>
> store file</li>
> trust store file</li>
> * @throws Throwable
Re: Test11743 error [message #586526 is a reply to message #45162] |
Thu, 07 August 2008 16:13 |
It looks like you're pointing to an XDS.b endpoint. 11743, as written,
is an XDS.a test. XDS.b requires a well-formed WS-Addressing action,
which is causing the error message. Try using the XDS endpoint:
http://localhost:9080/axis2/services/xdsrepositorya (assuming you're
running the NIST XDS server on your local machine)
-Matt
> following:
> for Phase "Addressing"
> for Phase "Security"
> for Phase "PreDispatch"
> "PreDispatch"
> for Phase "Dispatch"
> for Phase "RMPhase"
> for phase "RMPhase"
> for Phase "OperationInPhase"
> "OperationInPhase"
> in Phase "OperationInPhase"
> in Phase "RMPhase"
> in Phase "Dispatch"
> in Phase "PreDispatch"
> in Phase "Security"
> in Phase "Addressing"
> at
> at
> at
> at
> at
> at
> at
> urn:anonOutInOp
> at
> at
> at
> at
> at
> at
> ... 7 more
> urn:anonOutInOp]
> at
> at
> at
> at
> at
> at
> at
> urn:anonOutInOp
> at
> at
> at
> at
> at
> at
> ... 7 more
Re: Test11743 error [message #586633 is a reply to message #45350] |
11746.
-Matt
> The note is here:
> * <br>
> * <br>
> * <br>
> file</li>
> store file</li>
> store file</li>
> * @throws Throwable
FUDForum. Page generated in 0.03313 seconds
