CellEditorValidator's returned error message [message #447746] |
Thu, 16 December 2004 23:02 |
Steve Lewis Messages: 2 Registered: July 2009 |
All of the snippets, javadoc, and examples I can find for using a
CellEditor are well constructed and helped me get this far.
Unfortunately, they are fairly trivial and do not demonstrate all of
the available features.
I have a TableViewer up and working, with CellEditors in place where I
want them. The TableView has a number of columns that use
TextCellEditors. In many columns I have a validator in place, as
appropriate to the column.
My problem is that I am having a difficult time determining how to
best collect the error messages that result from invalid inputs. I
haven't seen an example of a CellEditor with an ICellModifier and
ICellValidator that captures the CellEditor.errorMessage for the user.
One solution: I could attach another object (implementing
ICellEditorListener) to each and every editable column, and when an
edit occurs check that column's CellEditor's errorMessage; that
doesn't /feel/ right.
Second solution: Though this behavior is undocumented, and therefore I
consider it unstable, when the ICellEditorValidator returns a non-null
&& non-empty-string error message, the associated modify() method of
the attached ICellModifier is called with a null parameter. I can
detect this behavior, and check the associated CellEditor's error
message, advancing an appropriate user error. I have tested this and
it is working for now, but I don't know what will happen in future
JFace/SWT libs.
Is there a better pattern for listening for and collecting a
CellEditor.errorMessage? What was /intended/ here?
FWIW, below is a snippet of the TableView construction code I am using.
// set up the table and columns
// set up the table viewer
TableViewer viewer = new TableViewer(table);
viewer.getTable().setLayoutData(new GridData(GridData.FILL_BOTH));
// set up the cell editors and cell modifiers
CellEditor[] editors = new CellEditor[table.getColumnCount()];
editors[COLUMN_DISTANCE] = new TextCellEditor(table);
editors[COLUMN_DISTANCE].setValidator(
new ICellEditorValidator()
public String isValid( Object value )
boolean isValid = false;
int dist = StringConverter.asInt( value.toString(), -1);
if (dist >= 1 && dist <= 30)
isValid = true;
return (isValid) ? null : DISTANCE_VALUES_ALLOWED_MESSAGE;
// define the other CellEditors, attach the rest of the validators
// define the viewer's label provider and content provider
tia,
Steve Lewis
Re: CellEditorValidator's returned error message [message #447920 is a reply to message #447746] |
Tue, 21 December 2004 23:10 |
Grant Gayed Messages: 2150 Registered: July 2009 |
Steve, you may get more response if you ask this on the eclipse.platform
newsgroup since that is where jface lives.
Grant
"Steve Lewis" <nepolon@worlddomination.net> wrote in message
news:cpt45j$n62$1@www.eclipse.org...
> JFace/SWT libs.
> isValid = true;
> tia,
> Steve Lewis
FUDForum. Page generated in 0.02632 seconds
