| ATT: Ms. Irvine - Bug in Eclipse Article: DND [message #447268] |
Sat, 11 December 2004 15:02  |
Dear Ms. Irvine,
I am failing to compile the sample DND code and think there is a bug in that
code, maybe you want to update that article (or am I missing something
here?):
http://www.eclipse.org/articles/Article-SWT-DND/DND-in-SWT.h tml
line 53 of the Drop Target example does not compile (misplaced constructs
error in eclipse).
I can see why the code does not compile, yet the purpose of the mentioned
lined is not quite clear to me.
My guess would be that line 52 should be replaced with the following (could
be wrong, though):
if ((event.operations & DND.DROP_COPY) != 0)) {
instead of :
event.detail = (event.operations & DND.DROP_COPY) != 0) {
/* *********** pasted from the article example code ************
51 public void dragOperationChanged(DropTargetEvent event) {
52 if (event.detail == DND.DROP_DEFAULT) {
53 event.detail = (event.operations & DND.DROP_COPY) != 0) {
// <<<< BAD LINE
54 event.detail = DND.DROP_COPY;
55 } else {
56 event.detail = DND.DROP_NONE;
57 }
58 }
59 // allow text to be moved but files should only be copied
60 if (fileTransfer.isSupportedType(event.currentDataType)){
61 if (event.detail != DND.DROP_COPY) {
62 event.detail = DND.DROP_NONE;
63 }
64 }
65 }
Thank you for the great support and advice in the forums...
Mani Ghamari
| Re: Ms. Irvine - Bug in Eclipse Article: DND [message #447302 is a reply to message #447268] |
Mon, 13 December 2004 08:23  |
You are correct, the code should be:
if ((event.operations & DND.DROP_COPY) != 0) {
} else {
I will fix the article.
At one time I think the code was:
event.detail = (event.operations & DND.DROP_COPY) != 0 ? DND.DROP_COPY :
DND.DROP_NONE;
but this line was too long for the article format and was incorrectly
rearranged into an if statement. Sorry.
"Mani Ghamari" <mani.ghamari@linkast.com> wrote in message
news:cpfjon$gh2$1@www.eclipse.org...
> Dear Ms. Irvine,
> that code, maybe you want to update that article (or am I missing
> something here?):
> error in eclipse).
> (could be wrong, though):
> instead of :
> 53 event.detail = (event.operations & DND.DROP_COPY) != 0) { //
> <<<< BAD LINE
> 55 } else {
> 57 }
> 58 }
> 63 }
> 64 }
> 65 }
> Mani Ghamari
FUDForum. Page generated in 0.04645 seconds
