Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Border around disabled Text in Eclipse Form
Border around disabled Text in Eclipse Form [message #446711] |
Wed, 01 December 2004 10:07 |
Timur Shakirov Messages: 3 Registered: July 2009 |
I have a problem to get a border drawn about the disabled Text wigdet
within a subclass of the SectionPart. As long as the Text is enabled,
everithing is OK, but as soon as I disable this widget, the border will
not be drawn. Has anybody seen such a behavior before?
And what should I do to get the borders drawn around the disabled Text
widget?
Usage of functions Section.layout(); Section.redraw(); brings me nothing.
If I create Text using function FormToolkit.createText( Composite,
"SomeText", SWT.BORDER ) I get two borders around enabled Text, and this
in nor exactly what I want.
Some tech. info:
OS: W2K, Eclipse Platform v. 3.01, SWT v. 3.01
Thanks in advance,
Tim
Re: Border around disabled Text in Eclipse Form [message #446832 is a reply to message #446711] |
Fri, 03 December 2004 15:02 |
Steve Northover Messages: 1636 Registered: July 2009 |
Please post a snippet that shows the problem and provide a screen shot.
"Timur Shakirov" <shakirov@epost.de> wrote in message
news:cok548$4pe$1@www.eclipse.org...
> Hello,
> widget?
> Some tech. info:
> Thanks in advance,
> Tim
Re: Border around disabled Text in Eclipse Form [message #449353 is a reply to message #446832] |
Mon, 24 January 2005 04:14 |
Andreas Martin Messages: 6 Registered: July 2009 |
>>Hello,
>>widget?
Hello!
I have the same problem as described. I'm using Eclipse 3.1M4 with
Windows XP. I made a screenshot showing the error:
http://www.perfectwww.de/eigene/schmidt/win_classic_xp.png
On the left hand you see a disabled textbox with XP classic skin (I
think the same effect like in W2K without a border). On the other hand
you see the disabled textbox with correct border with the standard
modern XP skin.
I used the following composite inside an Eclipse Forms standalone
application:
public class DebugForm extends Composite {
private FormToolkit toolkit;
public DebugForm(Composite parent, FormToolkit toolkit, int style) {
super(parent, style);
this.toolkit = toolkit;
createContents(this);
public void createContents(Composite parent) {
GridLayout gridLayout = new GridLayout();
gridLayout.marginWidth = gridLayout.marginHeight = 5;
gridLayout.numColumns = 2;
parent.setLayout(gridLayout);
toolkit.paintBordersFor(parent);
(toolkit.createText(parent, "disabled", SWT.SINGLE)).setEnabled(false);
(toolkit.createText(parent, "enabled", SWT.SINGLE)).setEnabled(true);
Additionaly I found this bug report
https://bugs.eclipse.org/bugs/show_bug.cgi?id=67690 which describes a
similar behaviour.
Andreas Martin
Re: Border around disabled Text in Eclipse Form [message #449444 is a reply to message #449353] |
Mon, 24 January 2005 17:35 |
Looks like a bug on Eclipse forms. They run different code depending on
whether you are running with the XP manifest.
"Andreas Martin" <a.martin@perfectwww.de> wrote in message
news:ct1sm9$84r$1@www.eclipse.org...
> >>Hello,
> >>widget?
> Hello!
> modern XP skin.
> application:
> similar behaviour.
> Andreas Martin
Current Time: Fri Sep 20 14:21:20 GMT 2024
Powered by FUDForum. Page generated in 0.03691 seconds
